  3. Leaf Wetness
Leaf Wetness
45 Posts 9 Posters 39.2k Views 3 Watching
  • epierreE
    epierreE
    epierre
    Ok, so I made some adjustments from my last try:
    • hobbyboard immersion gold sensor
    • I kept the comparator from the other sensor to facilitate work with the arduino
    • I've added a 18650 LiOn battery (5000mAh) to have an extended life cycle
    Here is the sketch:
    https://github.com/empierre/arduino/blob/master/LeafWetnessSensor.ino
    What I can say, is that it is very sensitive. It is now outside live in the cold.
    This could be used for a leak sensor easily.
    z-wave - Vera -> Domoticz
    • epierreE
      epierreE
      epierre
      so my 5000mAh lasted outside... 4 days... btw I didn't remove all leds from the comparator that could be an improvement and the outside weather is quite cold.
      I had a reading every 30 secs, way to quick surely...
      @hek is there a way to power the radio only when necessary ? I guess the gw.sleep could be a gw.sleep and a gw.wakeup and manage the delay outside ?
      hekH 1 Reply Last reply
      • epierreE epierre
        wrote on last edited by hek
        @epierre
        gw.sleep() sleeps the radio as well. What do you mean by power down radio? Like cutting power using digital pin?
        epierreE 1 Reply Last reply
          @epierre
          epierreE
          epierreE
          epierre
          @hek said:
          @epierre
          yes, now you combine sleep for the radio and delay, what I mean is to have loop() run without radio, and if a transmission is needed to have a command that power it.
          If you have a long dry period, a device on battery will consume a lot of power having the radion on and off, if it is always off until a sensor finds something, that would save more power, no ?
          • RJ_MakeR
            RJ_MakeR
            RJ_Make
            Wake only on interrupt?
            RJ_Make
            • epierreE
              epierreE
              epierre
              In my idea, a value above 0 would mean sending the info, an interrupt could be generated this way ?
              • elisavetgrigE
                elisavetgrigE
                elisavetgrig
                Hey,
                I am a newbie (in the forum) and in the arduino/sensors development. I bought the Leaf Wetness from cooking-hacks.com. Can I connected it to my Arduino via Analog input? Is it easy?
                SparkmanS 1 Reply Last reply
                • elisavetgrigE elisavetgrig
                  Hey,
                  SparkmanS
                  SparkmanS
                  Sparkman
                  @elisavetgrig Welcome to the forum. The answer is yes to both questions. Given that the sensor is a resistive element, you need to build a voltage divider. Google "voltage divider" Arduino and you'll find lots of examples.
                  Al
                  • FotoFieberF
                    FotoFieberF
                    FotoFieber
                    Measuring the current with DC doesn't seem to be the ideal solution:
                    thread
                    • FotoFieberF FotoFieber
                      thread
                      SparkmanS
                      SparkmanS
                      Sparkman
                      @FotoFieber That thread is regarding soil moisture measurements which is different than leaf wetness. For soil, capacitive is the best way to go IMHO.
                      Al
                      • FotoFieberF
                        FotoFieberF
                        FotoFieber
                        AC Statement ☺
                        • elisavetgrigE
                          elisavetgrigE
                          elisavetgrig
                          ok...Thank you... I will try the "voltage divider" and I will see what will happen!
                          • elisavetgrigE
                            elisavetgrigE
                            elisavetgrig
                            wrote on last edited by elisavetgrig
                            #29
                            • elisavetgrigE
                              elisavetgrigE
                              elisavetgrig
                              Did you mean something like the figure above? Or I only need to connect one resistor to one wire and the other wire to another pin in the Arduino?
                                SparkmanS
                                SparkmanS
                                Sparkman
                                @elisavetgrig You're missing the connections to a voltage source and ground. You also only need one resistor as the wetness sensor is the 2nd resistor in the voltage divider circuit. Take a look at this: http://homepage.cs.uri.edu/faculty/hamel/workshops/as220-sept-09/sensors-voltage-dividers.html.
                                Al
                                • elisavetgrigE
                                  elisavetgrigE
                                  elisavetgrig
                                  You are right! I thought that I missing something... always there are Data connection, VCC connection and GND.. and I had only one! I made another dummy scheme... Is that better?leaf wetness.jpg
                                    SparkmanS
                                    SparkmanS
                                    Sparkman
                                    @elisavetgrig Take a look at the second diagram of the link I posted. Right now you show the GND pin connected to the Analog pin and Vcc is also connected to the same spot, so that's not going to work.
                                    Al
                                    • elisavetgrigE
                                      elisavetgrigE
                                      elisavetgrig
                                      I based in the second diagram... i think that I understand it... resistorss-leaf wet.png
                                        SparkmanS
                                        SparkmanS
                                        Sparkman
                                        @elisavetgrig As I mentioned a few posts ago and how it's shown in the diagram on that link, is that you only need one resistor. The leaf wetness sensor becomes the other resistor in the circuit. In your last diagram, you have both the terminals of the wetness sensor connected to ground. Think of the wetness sensor as a resistor, with each of the terminals representing one leg of a regular resistor.
                                        Al
                                        • elisavetgrigE
                                          elisavetgrigE
                                          elisavetgrig
                                          OK... So I need only one resister... I think that "Scheme 2" is closer to the solution... images ofs.jpg
