  3. Leaf Wetness
Leaf Wetness
45 Posts 9 Posters 39.2k Views 3 Watching
  • epierreE
    epierreE
    epierre
    yes it is, from the hobby board site it is $2, but it is a quarter the china's size.
    sorry I missed your point, it is gold plated, immersion gold.
    z-wave - Vera -> Domoticz
    • epierreE
      epierreE
      epierre
      Ok, so I made some adjustments from my last try:
      • hobbyboard immersion gold sensor
      • I kept the comparator from the other sensor to facilitate work with the arduino
      • I've added a 18650 LiOn battery (5000mAh) to have an extended life cycle
      Here is the sketch:
      https://github.com/empierre/arduino/blob/master/LeafWetnessSensor.ino
      What I can say, is that it is very sensitive. It is now outside live in the cold.
      This could be used for a leak sensor easily.
      • epierreE
        epierreE
        epierre
        so my 5000mAh lasted outside... 4 days... btw I didn't remove all leds from the comparator that could be an improvement and the outside weather is quite cold.
        I had a reading every 30 secs, way to quick surely...
        @hek is there a way to power the radio only when necessary ? I guess the gw.sleep could be a gw.sleep and a gw.wakeup and manage the delay outside ?
        hekH 1 Reply Last reply
        • epierreE epierre
          wrote on last edited by hek
          @epierre
          gw.sleep() sleeps the radio as well. What do you mean by power down radio? Like cutting power using digital pin?
          epierreE 1 Reply Last reply
            @epierre
            epierreE
            epierreE
            epierre
            @hek said:
            @epierre
            yes, now you combine sleep for the radio and delay, what I mean is to have loop() run without radio, and if a transmission is needed to have a command that power it.
            If you have a long dry period, a device on battery will consume a lot of power having the radion on and off, if it is always off until a sensor finds something, that would save more power, no ?
            • RJ_MakeR
              RJ_MakeR
              RJ_Make
              Wake only on interrupt?
              RJ_Make
              • epierreE
                epierreE
                epierre
                In my idea, a value above 0 would mean sending the info, an interrupt could be generated this way ?
                • elisavetgrigE
                  elisavetgrigE
                  elisavetgrig
                  Hey,
                  I am a newbie (in the forum) and in the arduino/sensors development. I bought the Leaf Wetness from cooking-hacks.com. Can I connected it to my Arduino via Analog input? Is it easy?
                  SparkmanS 1 Reply Last reply
                  • elisavetgrigE elisavetgrig
                    Hey,
                    SparkmanS
                    SparkmanS
                    Sparkman
                    @elisavetgrig Welcome to the forum. The answer is yes to both questions. Given that the sensor is a resistive element, you need to build a voltage divider. Google "voltage divider" Arduino and you'll find lots of examples.
                    Al
                    • FotoFieberF
                      FotoFieberF
                      FotoFieber
                      Measuring the current with DC doesn't seem to be the ideal solution:
                      thread
                      • FotoFieberF FotoFieber
                        thread
                        SparkmanS
                        SparkmanS
                        Sparkman
                        @FotoFieber That thread is regarding soil moisture measurements which is different than leaf wetness. For soil, capacitive is the best way to go IMHO.
                        Al
                        • FotoFieberF
                          FotoFieberF
                          FotoFieber
                          AC Statement ☺
                          • elisavetgrigE
                            elisavetgrigE
                            elisavetgrig
                            ok...Thank you... I will try the "voltage divider" and I will see what will happen!
                            • elisavetgrigE
                              elisavetgrigE
                              elisavetgrig
                              wrote on last edited by elisavetgrig
                              #29
                              • elisavetgrigE
                                elisavetgrigE
                                elisavetgrig
                                Did you mean something like the figure above? Or I only need to connect one resistor to one wire and the other wire to another pin in the Arduino?
                                  SparkmanS
                                  SparkmanS
                                  Sparkman
                                  @elisavetgrig You're missing the connections to a voltage source and ground. You also only need one resistor as the wetness sensor is the 2nd resistor in the voltage divider circuit. Take a look at this: http://homepage.cs.uri.edu/faculty/hamel/workshops/as220-sept-09/sensors-voltage-dividers.html.
                                  Al
                                  • elisavetgrigE
                                    elisavetgrigE
                                    elisavetgrig
                                    You are right! I thought that I missing something... always there are Data connection, VCC connection and GND.. and I had only one! I made another dummy scheme... Is that better?leaf wetness.jpg
                                      SparkmanS
                                      SparkmanS
                                      Sparkman
                                      @elisavetgrig Take a look at the second diagram of the link I posted. Right now you show the GND pin connected to the Analog pin and Vcc is also connected to the same spot, so that's not going to work.
                                      Al
                                      • elisavetgrigE
                                        elisavetgrigE
                                        elisavetgrig
                                        I based in the second diagram... i think that I understand it... resistorss-leaf wet.png
                                          SparkmanS
                                          SparkmanS
                                          Sparkman
                                          @elisavetgrig As I mentioned a few posts ago and how it's shown in the diagram on that link, is that you only need one resistor. The leaf wetness sensor becomes the other resistor in the circuit. In your last diagram, you have both the terminals of the wetness sensor connected to ground. Think of the wetness sensor as a resistor, with each of the terminals representing one leg of a regular resistor.
                                          Al
