  3. Leaf Wetness
Leaf Wetness
45 Posts 9 Posters 39.2k Views 3 Watching
  • epierreE epierre
    some returns:
    • from Sept 11th to 15th, the batteries (3*1.5V) went from 4.5V to 3.2 as mesured today, it stopped emitting on sept 15th
    • the leaf sensor shows heavy signs of oxydation without any rain during the period... this is a real problem with all those copies around... that is not a very viable solution...
    I've seen another product from Spain at Liebllium that I guess I will test for I haven't found any other item...
    You're definitely not the first to report this.... I've read many negative reviews of these cheap sensors.
    epierreE 1 Reply Last reply
    • YveauxY Yveaux
      epierreE
      epierreE
      epierre
      @Yveaux but finding good one seems to be .... very difficult... I've spoken of immersive gold... will try to see if those are better....
      z-wave - Vera -> Domoticz
      • epierreE epierre
        some returns:
        @epierre any idea why your sensor lasted this short?
        How often did it report its value to the gateway? Was it sleeping in between? Any other sensors connected?
        • YveauxY Yveaux
          epierreE
          epierreE
          epierre
          @Yveaux several ideas:
          • it reported every 10000
          • it has no other sensor (this was my first try on batteries...)
          • I had an AMS1117 in entry but I didn't needed it
          • I haven't hacked the 3.3V core with the websites @a-lurker ideas
          I'm waiting for the batteries from my other post because using so fast batteries is not environment friendly...
          Has there been simulation of energy usage for those arduini ? e.g. for a spark core it isadvertized at 500mW
          • epierreE
            epierreE
            epierre
            I've finally received from cooking hacks the leaf wetness sensor board that should be better than the one from china...
            It is the one from hobby boards:
            I guess I can recycle the lectronic from the cheap one on this one ?
              It doesn't look much different that the china-ones. Is it gold-plated or something?
              • epierreE
                epierreE
                epierre
                yes it is, from the hobby board site it is $2, but it is a quarter the china's size.
                sorry I missed your point, it is gold plated, immersion gold.
                • epierreE
                  epierreE
                  epierre
                  Ok, so I made some adjustments from my last try:
                  • hobbyboard immersion gold sensor
                  • I kept the comparator from the other sensor to facilitate work with the arduino
                  • I've added a 18650 LiOn battery (5000mAh) to have an extended life cycle
                  Here is the sketch:
                  https://github.com/empierre/arduino/blob/master/LeafWetnessSensor.ino
                  What I can say, is that it is very sensitive. It is now outside live in the cold.
                  This could be used for a leak sensor easily.
                  • epierreE
                    epierreE
                    epierre
                    so my 5000mAh lasted outside... 4 days... btw I didn't remove all leds from the comparator that could be an improvement and the outside weather is quite cold.
                    I had a reading every 30 secs, way to quick surely...
                    @hek is there a way to power the radio only when necessary ? I guess the gw.sleep could be a gw.sleep and a gw.wakeup and manage the delay outside ?
                    hekH 1 Reply Last reply
                    • epierreE epierre
                      wrote on last edited by hek
                      @epierre
                      gw.sleep() sleeps the radio as well. What do you mean by power down radio? Like cutting power using digital pin?
                        @epierre
                        epierreE
                        epierreE
                        epierre
                        @hek said:
                        @epierre
                        yes, now you combine sleep for the radio and delay, what I mean is to have loop() run without radio, and if a transmission is needed to have a command that power it.
                        If you have a long dry period, a device on battery will consume a lot of power having the radion on and off, if it is always off until a sensor finds something, that would save more power, no ?
                        • RJ_MakeR
                          RJ_MakeR
                          RJ_Make
                          Wake only on interrupt?
                          RJ_Make
                          • epierreE
                            epierreE
                            epierre
                            In my idea, a value above 0 would mean sending the info, an interrupt could be generated this way ?
                            • elisavetgrigE
                              elisavetgrigE
                              elisavetgrig
                              Hey,
                              I am a newbie (in the forum) and in the arduino/sensors development. I bought the Leaf Wetness from cooking-hacks.com. Can I connected it to my Arduino via Analog input? Is it easy?
                              SparkmanS 1 Reply Last reply
                              • elisavetgrigE elisavetgrig
                                Hey,
                                SparkmanS
                                SparkmanS
                                Sparkman
                                @elisavetgrig Welcome to the forum. The answer is yes to both questions. Given that the sensor is a resistive element, you need to build a voltage divider. Google "voltage divider" Arduino and you'll find lots of examples.
                                Al
                                • FotoFieberF
                                  FotoFieberF
                                  FotoFieber
                                  Measuring the current with DC doesn't seem to be the ideal solution:
                                  thread
                                  • FotoFieberF FotoFieber
                                    thread
                                    SparkmanS
                                    SparkmanS
                                    Sparkman
                                    @FotoFieber That thread is regarding soil moisture measurements which is different than leaf wetness. For soil, capacitive is the best way to go IMHO.
                                    Al
                                    • FotoFieberF
                                      FotoFieberF
                                      FotoFieber
                                      AC Statement ☺
                                      • elisavetgrigE
                                        elisavetgrigE
                                        elisavetgrig
                                        ok...Thank you... I will try the "voltage divider" and I will see what will happen!
                                        • elisavetgrigE
                                          elisavetgrigE
                                          elisavetgrig
                                          wrote on last edited by elisavetgrig
                                          #29
