  2. Announcements
  3. 💬 FOTA (Wireless Programming)
wirelessupdateover the airsensebenderfotafirmware over the airwireless programming
130 Posts 46 Posters 81.9k Views 44 Watching
    I can't figure out this step:
    Go to Arduino Ide, in Board Manager, choose SensebenderMicro if you want to use DualOptiboot bootloader OTA. Or choose Arduino Mini pro MYSBootloader
    I cant find any sensbender board when searching the boards manager, I also tried downloading the 2.0 directly but cant find any boards there either. How should I do this?
    @Cliff-Karlsson
    https://github.com/mysensors/ArduinoBoards
    • Cliff KarlssonC
      Cliff KarlssonC
      Cliff Karlsson
      Thanks, but now I get this error in Arduino IDE when burning the bootloader:
      avrdude: warning: cannot set sck period. please check for usbasp firmware update.
      ***failed;
      avrdude: WARNING: invalid value for unused bits in fuse "efuse", should be set to 1 according to datasheet
      This behaviour is deprecated and will result in an error in future version
      You probably want to use 0xfe instead of 0x06 (double check with your datasheet first).
      Is this still ok?
      • Cliff KarlssonC
        Cliff KarlssonC
        Cliff Karlsson
        And this happens when I try to upoad a sketch to the board:
        Sketch uses 16,796 bytes (54%) of program storage space. Maximum is 30,720 bytes.
        Global variables use 739 bytes (36%) of dynamic memory, leaving 1,309 bytes for local variables. Maximum is 2,048 bytes.
        avrdude: stk500_paged_load(): (a) protocol error, expect=0x10, resp=0x90
        avrdude: stk500_cmd(): protocol error
        avr_read(): error reading address 0x0137
        read operation not supported for memory "flash"
        avrdude: failed to read all of flash memory, rc=-2
        the selected serial port avrdude: failed to read all of flash memory, rc=-2
        • A
          Alex B Goode
          Fellows, let me ask you about the procedure of switching controllers during OTA.
          My sensors are connected to a serial gateway, which is operated by a controller.
          In my case the controller is Domoticz server hosted by Raspberry Pi2.
          So if I want to initiate updating one of my nodes over the air then I need to... stop my current controller on my Raspberry Pi2 and... start a new gateway on a Windows machine with MYSControler, wait when all nodes will re-discover the new gateway and connect, and then use MYSControler to do all updates I need?
          TakeroT 1 Reply Last reply
          • A Alex B Goode
            TakeroT
            TakeroT
            Takero
            @Alex-B-Goode Yes this is the Way. If you dont like to disconnect the Gateway from Pi you Can use my procedure was i wrote some posts before. If the nodes discovered One time you dont need to wait again. MYScontroller save the discovered nodes.
            • W
              W
              Werwolfx
              +1 Where is located MYSBootloader for MySensors 2.0?
              and where is a linux version?
              • seeersS
                seeersS
                seeers
                is it possible or planned to do a OTA update over RS485 (with external flash using DualOptiBoot) ?
                • seeersS seeers
                  @seeers see partial answer in https://forum.mysensors.org/topic/5751/ota-programming-over-wire-rs-485/2
                  • maghacM
                    maghacM
                    maghac
                    Has any attempted to use a usbip client on Windows to use with MYSController and access the GW?
                    usbip is another technology for sharing USB ports over TCP/IP networks, similar to virtualhere. I am using it to access a USB device connected to a rPi2 from a linux box.
                    • nick van alstN
                      nick van alstN
                      nick van alst
                      Is the sensbender micro already preloaded with the Dualoptiboot bootloader?
                      • mfalkviddM
                        #42
                        @nick-van-alst https://forum.mysensors.org/topic/5939/is-the-sensbender-micro-already-preloaded-with-the-dualoptiboot-bootloader
                        • maghacM
                          maghacM
                          maghac
                          I'd like to try this on my Pro Mini clone, but unfortunately I find the instructions very confusing.
                          What are fuses and why do I need to change them? To what do I need to change them?
                          I cannot see "Arduino Mini pro MYSBootloader" in Boards.
                          I am using Mysensors 2.1.
                          • maghacM maghac
                            sundberg84S
                            sundberg84S
                            #44
                            @maghac - https://forum.mysensors.org/topic/3018/tutorial-how-to-burn-1mhz-8mhz-bootloader-using-arduino-ide-1-6-5-r5 here is a good tutorial how to burn a bootloader. You need to select a bootloader you want to use. They all have different properties. The fuses are burned when you burn the bootloader. The wirelsess programming tutorial is found here: https://www.mysensors.org/about/ota
                              The suggested bootloader programmers in the article work with all Arduino Mini pro, UNO, MEGA and so on? I have searched around Aliexpress for "USBASP" but it seems they support only windows 7 and the common description is " USBASP USBISP AVR Programmer USB ATMEGA8 ATMEGA128" so it's kind of confusing for me
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                They should work with all of the "old" AVR line of atmel processors (attiny, atmega)
                                If you go with newer processors like atsam procssor line, you need to have a CMSIS adapter instead.
                                Btw. they should work on both windows and linux (and newer versions of windows as well)
                                • H
                                  H
                                  hiddenuser
                                  Hi there,
                                  I have a RPI running my gateway(/dev/ttyUSB020) and domoticz is running on the rpi too. How do I used MYSBootloader to push sketches to my sensors?
                                  gohanG 1 Reply Last reply
                                  • H hiddenuser
                                    Hi there,
                                    @hiddenuser https://www.mysensors.org/about/ota
                                    Then I suggest you configure the gateway as an ethernet gateway and use myscontroller to assign the firmware to the nodes
                                    • B
                                      B
                                      bilbolodz
                                      It's not quite clear for my how to use MYSBootloader for OTA. I'm running Domoticz as a controller (on RPI) and my gateway also is running on RPI (NRF on GPIO). Should have I one more arduino gateway connected to Windows machine running MYSController? As far I know there could be only one gateway in mysensors network.
                                        You just connect myscontroller to the gateway running on the RPI if it is configured as ethernet
                                        maghacM 1 Reply Last reply
                                          maghacM
                                          maghacM
                                          maghac
                                          I installed mycontroller.org for this purpose (OTA updates).
                                          I have a MQTT gateway running on a NodeMCU, which connects to my MQTT server (mosquitto running on a ubuntu server) via wifi. This setup works very well, and I don't have to keep anything running on my desktop machine (which is a windows 10 box) while the OTA updates are being pushed out (which takes ages, since they are running on battery and only wake up once every few hours).
