  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 256.7k Views 53 Watching
  • F Fabien
    Yes ! Itead send me the gateway today
    alexsh1A
    alexsh1A
    alexsh1
    @Fabien said in 💬 Sensebender Gateway:
    I have got mine today. Very quick
    • tbowmoT tbowmo
      @Sander-Teunissen
      The hardware supports both NRF and RFM69 at the same time, they share the same SPI bus, but has separate chip select lines etc.
      Unfortunately the MySensors library doesn't support multiple transports, so this time it's the software that limits things.
      FotoFieberF
      FotoFieberF
      FotoFieber
      @tbowmo
      The fact, that MySensors doesn't support more then one radio, was the reason for me not to order the sensebender gateway.
      I am working on a gateway⁄controller based on an arduino due, which supports at least up to 3 serial gateways via hardware serial. It handles ID and time (synced with ntp) requests and does pub/sub to mqtt with readable topics.(inspired by the old mqtt client gateway)
      alexsh1A 1 Reply Last reply
      • FotoFieberF FotoFieber
        @tbowmo
        alexsh1A
        alexsh1A
        alexsh1
        @FotoFieber this is a software limitation. Hardware wise I do not see why Sensebender GW cannot handle two (nrf24l01+ and rfm69/rfm95) GWs at the same time
        • alexsh1A alexsh1
          FotoFieberF
          FotoFieberF
          FotoFieber
          @alexsh1
          The question is: will the software restriction be solved? If not, I do not care if it is a software or a hardware restriction. :)
          • tbowmoT
            tbowmoT
            tbowmo
            @FotoFieber
            Well, you need to hack the core anyways, if you want to accomplish your goal.
            You could also help out with the core development, so we can get support for multiple transport on one gateway ;)
            • tbowmoT tbowmo
              @FotoFieber
              FotoFieberF
              FotoFieberF
              FotoFieber
              @tbowmo
              No, I don't have to hack the core. I use the serial API. From an architectural point of view, I don't see the need to change anything in MySensors. A serial controller can be built for under 20€ Including the radio. Why should I add complexity to support more than one radio support with one cpu in MySensors, if I can have the functipnality with the abstraction layer of the serial API? Please keep MySensors s simple as possible.
              AnticimexA tbowmoT alexsh1A 3 Replies Last reply
                @tbowmo
                AnticimexA
                AnticimexA
                Anticimex
                @FotoFieber simple for who? Simplicity also involve maintenance and code complexity. What about testability and regression testing? Nobody gets paid for maintaining mysensors.
                  @tbowmo
                  tbowmoT
                  tbowmoT
                  tbowmo
                  @FotoFieber
                  But you ditched the sensebender Gateway, as it doesn't support multiple radios at the same time? Now you are saying that you would keep it as one radio per gateway?
                  This doesn't make sense :)
                  • tbowmoT tbowmo
                    @FotoFieber
                    FotoFieberF
                    FotoFieberF
                    FotoFieber
                    @tbowmo
                    Maybe the design of the sensebender gateway doesn't make sense to my architectural viewpoint....
                      @alexsh1
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @FotoFieber This is a question for the MySensors dev team. Sensebender can handle both radios. Currently, there is a software restriction.
                        @tbowmo
                        alexsh1A
                        alexsh1A
                        alexsh1
                        #98
                        @FotoFieber No, you do have to hack the core if you want both radios to be handled properly, i.e. to handle message queues with corresponding radios. For example, sending a message is done via rfm69 only and not via nrf24l01+
                        • AnticimexA
                          AnticimexA
                          Anticimex
                          The architecture we use would place this kind of situation to the controller to solve. One gw per network. So one gw for nrf and one for rfm.
                          HW is cheap, and library should be kept simple.
                          • AnticimexA Anticimex
                            FotoFieberF
                            FotoFieberF
                            FotoFieber
                            @Anticimex
                            One gateway per radio, that is what I think is best. :+1:
                            What I try to do, is to implement a controller with arduino due for up to three serial gateways. If there would be a solution for ethernet&rfm69 I may not have invested time in this. :laughing:
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @FotoFieber
                              Well sensebender GW supports rfm69 with ethernet ;)
                              FotoFieberF alexsh1A 2 Replies Last reply
                              • tbowmoT tbowmo
                                @FotoFieber
                                FotoFieberF
                                FotoFieberF
                                FotoFieber
                                @tbowmo
                                Yes, that is really nice. :+1:
                                My other goal was to have a new MQTTClientGateway, as it existed with MySensors 1.1 (which is not only a gateway, but a controller too). It would have been really painful to add it to MySensors 2.1.x, as I would have to patch core files. It is much easier, to throw hardware at it. :laughing:
                                • tbowmoT tbowmo
                                  @FotoFieber
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @tbowmo More practical question. I have received the GW and it already has MySensors 2.1.0 software. Excellent service by Itead. Can you please help me how to map LEDs in the GW sketch? I can see that they are connected to pins 38, 41, 42, 39, 40 as LED1, LED2, LED3, LED4 and LED5. Thanks
                                  tbowmoT 1 Reply Last reply
                                  • alexsh1A alexsh1
                                    tbowmoT
                                    tbowmoT
                                    tbowmo
                                    #104
                                    @alexsh1
                                    you should be able to use LED_BLUE, LED_GREEN etc. defines (or even just LED_1, LED_2..) in your sketch, to access the different LED's on board the gateway. That is, if you are using the SenseBender GW hardware support files in arduino (installation instructions are here https://github.com/mysensors/ArduinoBoards)
                                    Also, look at the board definition files, located here https://github.com/mysensors/ArduinoHwSAMD/blob/master/variants/mysensors_gw/variant.cpp
                                    and here https://github.com/mysensors/ArduinoHwSAMD/blob/master/variants/mysensors_gw/variant.h
                                    • tbowmoT tbowmo
                                      @alexsh1
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @tbowmo Excellent links, many thanks. BTW the board is working with the standard arduino samd, the problem I suppose comes with things LEDs.
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @alexsh1
                                        You might be able to compile with the standard arduino zero BSP files. But the IO mapping is not the same at all.. I have swapped some pins to make routing a bit easier. Also the SPI channels are configured a bit differently than the standard arduino, if I remember right. So I will advise to use the mysensors gateway BSP files..
                                        • tbowmoT tbowmo
                                          @alexsh1
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          #107
                                          @tbowmo it is already done. Thanks to your link I have now Sensebender Gateway board added.
                                          Waiting for an ethernet board now, it has stuck in the post
