  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 256.7k Views 53 Watching
  • tbowmoT tbowmo
    @Sander-Teunissen
    The hardware supports both NRF and RFM69 at the same time, they share the same SPI bus, but has separate chip select lines etc.
    Unfortunately the MySensors library doesn't support multiple transports, so this time it's the software that limits things.
    FotoFieberF
    FotoFieberF
    FotoFieber
    @tbowmo
    The fact, that MySensors doesn't support more then one radio, was the reason for me not to order the sensebender gateway.
    I am working on a gateway⁄controller based on an arduino due, which supports at least up to 3 serial gateways via hardware serial. It handles ID and time (synced with ntp) requests and does pub/sub to mqtt with readable topics.(inspired by the old mqtt client gateway)
    alexsh1A 1 Reply Last reply
    • FotoFieberF FotoFieber
      @tbowmo
      alexsh1A
      alexsh1A
      alexsh1
      @FotoFieber this is a software limitation. Hardware wise I do not see why Sensebender GW cannot handle two (nrf24l01+ and rfm69/rfm95) GWs at the same time
      • alexsh1A alexsh1
        FotoFieberF
        FotoFieberF
        FotoFieber
        @alexsh1
        The question is: will the software restriction be solved? If not, I do not care if it is a software or a hardware restriction. :)
        • tbowmoT
          tbowmoT
          tbowmo
          @FotoFieber
          Well, you need to hack the core anyways, if you want to accomplish your goal.
          You could also help out with the core development, so we can get support for multiple transport on one gateway ;)
          • tbowmoT tbowmo
            @FotoFieber
            FotoFieberF
            FotoFieberF
            FotoFieber
            @tbowmo
            No, I don't have to hack the core. I use the serial API. From an architectural point of view, I don't see the need to change anything in MySensors. A serial controller can be built for under 20€ Including the radio. Why should I add complexity to support more than one radio support with one cpu in MySensors, if I can have the functipnality with the abstraction layer of the serial API? Please keep MySensors s simple as possible.
            AnticimexA tbowmoT alexsh1A 3 Replies Last reply
              @tbowmo
              AnticimexA
              AnticimexA
              Anticimex
              @FotoFieber simple for who? Simplicity also involve maintenance and code complexity. What about testability and regression testing? Nobody gets paid for maintaining mysensors.
                @tbowmo
                tbowmoT
                tbowmoT
                tbowmo
                @FotoFieber
                But you ditched the sensebender Gateway, as it doesn't support multiple radios at the same time? Now you are saying that you would keep it as one radio per gateway?
                This doesn't make sense :)
                • tbowmoT tbowmo
                  @FotoFieber
                  FotoFieberF
                  FotoFieberF
                  FotoFieber
                  @tbowmo
                  Maybe the design of the sensebender gateway doesn't make sense to my architectural viewpoint....
                    @alexsh1
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @FotoFieber This is a question for the MySensors dev team. Sensebender can handle both radios. Currently, there is a software restriction.
                      @tbowmo
                      alexsh1A
                      alexsh1A
                      alexsh1
                      #98
                      @FotoFieber No, you do have to hack the core if you want both radios to be handled properly, i.e. to handle message queues with corresponding radios. For example, sending a message is done via rfm69 only and not via nrf24l01+
                      • AnticimexA
                        AnticimexA
                        Anticimex
                        The architecture we use would place this kind of situation to the controller to solve. One gw per network. So one gw for nrf and one for rfm.
                        HW is cheap, and library should be kept simple.
                        • AnticimexA Anticimex
                          FotoFieberF
                          FotoFieberF
                          FotoFieber
                          @Anticimex
                          One gateway per radio, that is what I think is best. :+1:
                          What I try to do, is to implement a controller with arduino due for up to three serial gateways. If there would be a solution for ethernet&rfm69 I may not have invested time in this. :laughing:
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @FotoFieber
                            Well sensebender GW supports rfm69 with ethernet ;)
                            FotoFieberF alexsh1A 2 Replies Last reply
                            • tbowmoT tbowmo
                              @FotoFieber
                              FotoFieberF
                              FotoFieberF
                              FotoFieber
                              @tbowmo
                              Yes, that is really nice. :+1:
                              My other goal was to have a new MQTTClientGateway, as it existed with MySensors 1.1 (which is not only a gateway, but a controller too). It would have been really painful to add it to MySensors 2.1.x, as I would have to patch core files. It is much easier, to throw hardware at it. :laughing:
                              • tbowmoT tbowmo
                                @FotoFieber
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @tbowmo More practical question. I have received the GW and it already has MySensors 2.1.0 software. Excellent service by Itead. Can you please help me how to map LEDs in the GW sketch? I can see that they are connected to pins 38, 41, 42, 39, 40 as LED1, LED2, LED3, LED4 and LED5. Thanks
                                tbowmoT 1 Reply Last reply
                                • alexsh1A alexsh1
                                  tbowmoT
                                  tbowmoT
                                  tbowmo
                                  #104
                                  @alexsh1
                                  you should be able to use LED_BLUE, LED_GREEN etc. defines (or even just LED_1, LED_2..) in your sketch, to access the different LED's on board the gateway. That is, if you are using the SenseBender GW hardware support files in arduino (installation instructions are here https://github.com/mysensors/ArduinoBoards)
                                  Also, look at the board definition files, located here https://github.com/mysensors/ArduinoHwSAMD/blob/master/variants/mysensors_gw/variant.cpp
                                  and here https://github.com/mysensors/ArduinoHwSAMD/blob/master/variants/mysensors_gw/variant.h
                                  • tbowmoT tbowmo
                                    @alexsh1
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @tbowmo Excellent links, many thanks. BTW the board is working with the standard arduino samd, the problem I suppose comes with things LEDs.
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @alexsh1
                                      You might be able to compile with the standard arduino zero BSP files. But the IO mapping is not the same at all.. I have swapped some pins to make routing a bit easier. Also the SPI channels are configured a bit differently than the standard arduino, if I remember right. So I will advise to use the mysensors gateway BSP files..
                                      • tbowmoT tbowmo
                                        @alexsh1
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        #107
                                        @tbowmo it is already done. Thanks to your link I have now Sensebender Gateway board added.
                                        Waiting for an ethernet board now, it has stuck in the post
                                        • F
                                          F
                                          Fabien
                                          @tbowmo : Did you try to use this board with platformio ?
