  3. 💬 MySWeMosGWShield - WeMos Mini MySensors Gateway Shield
contest2017rfm69wemosesp8266mysensorsgatewaynrf24l01
40 Posts 10 Posters 15.4k Views 8 Watching
  • G
    G
    gloob
    I did also receive all parts today and did solder an NRF24L01+PA+LNA WiFi Gateway. Everything runs fine from the beginning. Thanks.
    • G
      G
      gloob
      Did you test this module with a RFM69HW module?
      I don't get a connection between two modules.
      I did solder all pads of the RFM69 but I don't think this should cause me problem.
      • E
        E
        emc2
        Yes and no.
        I tried with a RFM69 and I did not got any errors / complains on the serial log, but I do not have any other RFM devices to test with (still waiting for radio modules, probably lost again...)
        • G
          G
          gloob
          Thank you for the feedback.
          I'm getting closer to a "solution".
          I did try an other library for the communication to an RFM69 and I can read the internal temperature and the register values. So the wiring of the chip is correct.
          Now I have to find out why MySensors has problems.
          • E
            E
            emc2
            I answered to your other topic, but I think that's because you are not defining the IRQ and CS pins in your sketch.
            Have a try by using the provided sketch on the Gateway, or define the pins on yours, it should hopefully fix your problem.
            • G
              G
              gloob
              Could you solve the problem that the gateway is not working with the RFM69? Is it related to the MySensors library and the ESP?
              • E
                E
                emc2
                I think I did.
                Could you test by making sure you add / have the following lines in your sketch:
                #define MY_RF69_IRQ_PIN D2  // GPIO 4
                #define MY_RF69_IRQ_NUM D2  // GPIO 4
                #define MY_RF69_SPI_CS  D8  // GPIO 15
                It seems that the automatic definition of MY_RF69_IRQ_NUM was not working properly (I think on esp8266 platform it was supposed to be automatically defined as equal to MY_RF69_IRQ_PIN but I guess it was not the case)
                Right now I have it working, both gateway and sensor compiled with MySensors 2.1.1.
                I updated the default sketch, adding the missing line, and it's now available on github.
                Let me know how it goes for you.
                • E
                  E
                  emc2
                  @gloob Did you had time to test on your side and can confirm that everything is working correctly?
                  • G
                    G
                    gloob
                    Currently I don't have a WeMos to test everything. I will come back to thins topic once I receive my WeMos from china. But you solution sounds good to me, as I did test the PCB with some other software and it was working without any problems. So it must be a problem related to the configuration and not to the wiring of the PCB itself.
                    • Nca78N
                      Hello, I just ordered from PCBs.io.
                      Thank you for the design @emc2 !
                      • Cliff KarlssonC
                        Cliff KarlssonC
                        Cliff Karlsson
                        Ok, this is a really stupid question but how do I use this with for example Domoticz? Do I still need to connect it to the usb-port or do I connect using MQTT or some other way?
                          @Cliff-Karlsson add it as an MySensors ethernet gateway.
                          • Cliff KarlssonC
                            Cliff KarlssonC
                            Cliff Karlsson
                            Ok, I just soldered two of the shield using smd nrf-radios but I only got alot of errors from the serial monitor. Also the boards got hot as hell after a minute. The wemos was really hot and the nrf was untuchable.
                            I through that had done something wrong with the first shield so I soldered another but it was also as hot as the first.
                            And should I enter the SSID and password for my home wifi-network or should I use the sketch to create a new? I tried both with no success as I got some default network called aitinker or similar both times.
                            • E
                              E
                              emc2
                              It should not get hot at all. The Wemos can get a few °C above room temperature but definitively not "hot as hell"
                              It happened to me once, when I had some solder joints between 2 pins of the NRF. You may want to test with a multimeter if, when the WeMos is unplugged, you have any shorts between adjacent pins.
                              A picture of the soldered board may help too.
                              Best way is to edit the example sketch by adding your Wifi credentials on it before uploading them.
                              • Nca78N
                                Hello, After soldering the radio and before connecting to power you should use a multimeter in "continuity" mode and make sure you have no contact between adjacent pins of the radio. I never connect a circuit using SMD nrf24 without having done this test.
                                • Cliff KarlssonC
                                  Cliff KarlssonC
                                  Cliff Karlsson
                                  @Nca78 said in 💬 MySWeMosGWShield:
                                  Ok, I have tried several times now soldering/resoldreing the radio with same result. Continuity, that means direct contact? I get several hundreds of ohms between a few of the pads but it does not "beep" anywhere :)
                                  Can something in my sketch cause this or is it 100% hardware issue?
                                  This is what I am using:
                                  // ** WiFi and network configuration **
                                  #define MY_ESP8266_SSID "My SSID"
                                  #define MY_ESP8266_PASSWORD "My password"
                                  #define MY_ESP8266_HOSTNAME "MySWeMosGWNRF"
                                  // Enable UDP communication
                                  //#define MY_USE_UDP
                                  #define MY_IP_GATEWAY_ADDRESS 192,168,178,1
                                  #define MY_PORT 5003
                                  // ** OTA updates configuration **
                                  // Enable OTA updates for ESP8266 based gateway
                                  #define ESP8266_OTA
                                  // Define password for OTA updates (recommended but optional)
                                  //#define ESP8266_OTA_PASSWORD "MySuperSecretOTAPassword"
                                  // ** MySensors Radio configuration **
                                  // RF24 settings
                                  // Use custom RF24 channel (default 76)
                                  //#define MY_RF24_CHANNEL 42
                                  // Decrease RF24 power transmission, useful to test in case of Tx problems.
                                  // If your problem is fixed consider adding the 5V to 3.3V voltage regulator
                                  // RF69 settings
                                  // RFM69 Frequency, default = 868MHz
                                  #define MY_RFM69_FREQUENCY RF69_868MHZ // RFM69 frequency to use (RF69_433MHZ for 433MHz, RF69_868MHZ for 868MHz or RF69_915MHZ for 915MHz)
                                  // RFM69 Network ID. Use the same for all nodes that will talk to each other, default = 100
                                  //#define MY_RFM69_NETWORKID     42
                                  // Disable this if you're not running the RFM69HW model (RFM69HW is recommended on the gateway for better coverage)
                                  #define MY_IS_RFM69HW
                                  // ** Mysensors additional functions **
                                  // Enable inclusion mode
                                  //#define MY_INCLUSION_MODE_BUTTON_PIN  D3  // GPIO 0
                                  // Software signing settings
                                  //#define MY_SIGNING_SOFT
                                  //#define MY_SIGNING_SOFT_RANDOMSEED_PIN A0
                                  // Hardware signing settings (currently unsupported?)
                                  //#define MY_SIGNING_ATSHA204
                                  //#define MY_SIGNING_ATSHA204_PIN D0  // GPIO 16
                                  // General signing settings
                                  // Enable this if you want destination node to sign all messages sent to this gateway.
                                  // Enable node whitelisting
                                  // Flash leds on rx/tx/err
                                  // Set blinking period
                                  // LED_BUILTIN, the on board LED is used (D4, GPIO 2)
                                  #define MY_DEFAULT_ERR_LED_PIN LED_BUILTIN // Error led pin
                                  #define MY_DEFAULT_RX_LED_PIN  LED_BUILTIN // Receive led pin
                                  #define MY_DEFAULT_TX_LED_PIN  LED_BUILTIN // Transmit led pin
                                  // You probably don't need to edit below //
                                  Nca78N 1 Reply Last reply
                                    #define ESP8266_OTA
                                    // RF24 settings
                                    // RF69 settings
                                    @Cliff-Karlsson said in 💬 MySWeMosGWShield:
                                    You've got your answer here. You should have MOhms especially between Vcc and GND pins where I have infinite resistance.
                                    • Cliff KarlssonC
                                      Cliff KarlssonC
                                      Cliff Karlsson
                                      another stupid question, do I need the capacitator on the radio-side for it to work?
                                      • E
                                        E
                                        emc2
                                        It should indeed "beep" between all the pins.
                                        NRF modules are also very fragile, once incorrectly plugged they are usually definitively toasted. So even if you desoldered and then resoldered them correctly it is unlikely they will work correctly.
                                        Yes you need the capacitor radio side, it's the only required component, everything else is optional. It don't have to be 4.7µF, anything between 4.7 and 47µF will do, as stated in the assembly instructions.
                                        • Cliff KarlssonC
                                          Cliff KarlssonC
                                          Cliff Karlsson
                                          I have got some strange issue when using RFM69HW. I modified the sketch by chosing RFM instead of NRF, and also uncommented the line "MY_IS_RMF69HW"
                                          Everything looks like it is working when using the serial console, the wemos gets an ip and I can add it to domoticz. But after a couple of minutes it stops working. Same if I power it from mobile charger directly, works a while then dies. I have tried with different Wemos and it is the same. Can a faulty radio cause this or could it be something other?
