  3. DHT22 verify issue.
DHT22 verify issue.
12 Posts 3 Posters 6.1k Views 3 Watching
  • BrydenB Bryden
    Using the raw code from the Mysensors example I'm getting errors trying to verify the code.
    Haven't changed a single bit of the raw code.
     * Version 1.0: Henrik EKblad
     * sensor using a DHT11/DHT-22.
    // Enable debug prints
    //#define MY_RS485
    #define DHT_DATA_PIN 3
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 60000;
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
        nNoUpdatesHum++;
      sleep(UPDATE_INTERVAL);
    Getting the following errors
    sketch_mar01a:73: error: no matching function for call to 'DHT::DHT()'
    DHT dht;
    Any help recommended?
    Welcome to the MySensors community @Bryden !
    You'll need to install the dht library, as described on https://www.mysensors.org/build/humidity
    See also these threads
    https://forum.mysensors.org/topic/5865/could-use-a-bid-help-to-get-started
    https://forum.mysensors.org/post/47706
    https://forum.mysensors.org/post/47130
    https://forum.mysensors.org/post/48860
    • BrydenB
      BrydenB
      Bryden
      wrote on last edited by Bryden
      I have the DHT sensor library installed under recommended libraries and can run the DHTtester code no problems.
      I have uploaded the sketch to my nodemcu and its working fine and can see the results via serial monitor
      as shown here
      #include <DHT_U.h>
      // Example testing sketch for various DHT humidity/temperature sensors
      // Written by ladyada, public domain
      #include "DHT.h"
      #define DHTPIN 2     // what digital pin we're connected to
      // Uncomment whatever type you're using!
      //#define DHTTYPE DHT11   // DHT 11
      #define DHTTYPE DHT22   // DHT 22  (AM2302), AM2321
      //#define DHTTYPE DHT21   // DHT 21 (AM2301)
      // Connect pin 1 (on the left) of the sensor to +5V
      // NOTE: If using a board with 3.3V logic like an Arduino Due connect pin 1
      // to 3.3V instead of 5V!
      // Connect pin 2 of the sensor to whatever your DHTPIN is
      // Connect pin 4 (on the right) of the sensor to GROUND
      // Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
      // Initialize DHT sensor.
      // Note that older versions of this library took an optional third parameter to
      // tweak the timings for faster processors.  This parameter is no longer needed
      // as the current DHT reading algorithm adjusts itself to work on faster procs.
      DHT dht(DHTPIN, DHTTYPE);
        Serial.begin(9600);
        Serial.println("DHTxx test!");
        dht.begin();
        // Wait a few seconds between measurements.
        delay(2000);
        // Reading temperature or humidity takes about 250 milliseconds!
        // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
        float h = dht.readHumidity();
        // Read temperature as Celsius (the default)
        float t = dht.readTemperature();
        // Read temperature as Fahrenheit (isFahrenheit = true)
        float f = dht.readTemperature(true);
        // Check if any reads failed and exit early (to try again).
        if (isnan(h) || isnan(t) || isnan(f)) {
          Serial.println("Failed to read from DHT sensor!");
          return;
        // Compute heat index in Fahrenheit (the default)
        float hif = dht.computeHeatIndex(f, h);
        // Compute heat index in Celsius (isFahreheit = false)
        float hic = dht.computeHeatIndex(t, h, false);
        Serial.print("Humidity: ");
        Serial.print(h);
        Serial.print(" %\t");
        Serial.print("Temperature: ");
        Serial.print(t);
        Serial.print(" *C ");
        Serial.print(f);
        Serial.print(" *F\t");
        Serial.print("Heat index: ");
        Serial.print(hic);
        Serial.print(hif);
        Serial.println(" *F");
      Ill have a read through your recommended threads to see what else I can troubleshoot.
      I also tried looking at others projects and examples but didn't see much code
      • BrydenB
        BrydenB
        Bryden
        seems to be fixed after I deleted and reinstalled the DHT library several time.
        Thanks mfalkvidd
        • BrydenB
          BrydenB
          Bryden
          Ok so I got it all working, somewhat.
          Im running a NodeMCU with wifi to MQTT with the below sketch. (note removed the header of the code to protect private info, I have had the MQTT/ESP part working fine with other sensors/actuators)
          #include <ESP8266WiFi.h>
          // DHT22
          #define DHT_DATA_PIN 4
          float lastTemp;
          float lastHum;
          bool metric = true;
          DHT dht;
              if (!metric) {
              nNoUpdatesTemp = 0;
              #ifdef MY_DEBUG
              nNoUpdatesTemp++;
              lastHum = humidity;
              nNoUpdatesHum = 0;
              #ifdef MY_DEBUG
              nNoUpdatesHum++;
          Basically a copy paste of what on the mysensors page, however this code fails reading the DHT22/am2302 sensor Im using.
          If I use the DHT_Test code supplied with the mysensors master library, everything works fine, same pin, not even re powering the device, flashed it many times, and I'm stuck.
          #include "DHT.h"
          DHT dht;
            Serial.begin(9600);
            Serial.println();
            Serial.println("Status\tHumidity (%)\tTemperature (C)\t(F)");
            dht.setup(2); // data pin 2
            Serial.print(dht.getStatusString());
            Serial.print("\t");
            Serial.print(humidity, 1);
            Serial.print("\t\t");
            Serial.print(temperature, 1);
            Serial.println(dht.toFahrenheit(temperature), 1);
          • BrydenB Bryden
            // DHT22
            float lastTemp;
            float lastHum;
            bool metric = true;
            DHT dht;
                if (!metric) {
                nNoUpdatesTemp = 0;
                #ifdef MY_DEBUG
                nNoUpdatesTemp++;
                lastHum = humidity;
                nNoUpdatesHum = 0;
                #ifdef MY_DEBUG
                nNoUpdatesHum++;
            #include "DHT.h"
            DHT dht;
              Serial.begin(9600);
              Serial.println();
              Serial.print("\t");
            @Bryden when the reading fails, what is the result? No reading at all? Incorrect temperature?
            • BrydenB
              BrydenB
              Bryden
              Its serial printing "Failed reading temperature from DHT" and "Failed reading humidity from DHT" as per the void loop in the sketch.
              I can run DHT_Test, and it works fine, serial printing OK 1.0 25.8 47.3 (or what ever the temp and humidity is) then immediately upload the mysensor sketch and get the failed reading returns.
              AWIA 1 Reply Last reply
              • BrydenB Bryden
                AWIA
                AWIA
                AWI
                @Bryden try to replace sleep() with wait(). I cannot get sleep to work well on an esp8266.
                BrydenB 1 Reply Last reply
                • AWIA AWI
                  BrydenB
                  BrydenB
                  Bryden
                  @AWI said in DHT22 verify issue.:
                  Well @AWI thats just weird, Its working now, I'm not much of a programmer, But something as little as changing a sleep command to wait fixed the issue is weird as hell.
                  Have you got any explanation or should I just blame the angry pixies getting in a huff.
                  You have well earned your hero member status.
                  • BrydenB Bryden
                    @Bryden on ESP8266, the MySensors sleep function always returns immediately. That causes the code to try to read data from the sensor too soon.
                    From what I understand, the reason that sleep doesn't sleep on ESP8266 is that the ESP8266 requires a full reboot when it wakes up from sleep, which usually isn't what people want when calling sleep.
                    But people don't want immediate return either. I don't know what reasoning was behind designing the MySensors sleep function on ESP8266 but i assume there was a compelling reason to let sleep() return immediately.
                    Maybe a more logical choice would be to let sleep() on ESP8266 do what wait() does?
                    • BrydenB
                      BrydenB
                      Bryden
                      I suppose I could remove the sleep / wait function all together seems as it's going to run off mains and not a battery, which is what I would assume people wanted a sleep function for altogether.
                      • BrydenB Bryden
                        AWIA
                        AWIA
                        AWI
                        @Bryden The wait() function is a MySensors replacement of the standard delay() in c++. The "added value" here is that wait() lets you listen to incoming messages while doing nothing. Unless you want some activity during waiting for a next reading (like blinking a led or so) I think wait() is rather usefull ;-)
