  3. Arduino Pro MICRO Pinout for 8 channel Relay
pro microanalog pin on ppinoutlibrary
15 Posts 7 Posters 10.4k Views 3 Watching
  • P Offline
    P Offline
    Porky6666
    does the Library Support using on Pro Micro Analog Inputs A0 A1 A2 A3
    as Digital Output for More Relay steering up to 8 Relays ?
    Greetings from Germany
    Stefan
    • H Offline
      H Offline
      It has really nothing to do with the MySensors library how you choose to control the GPIOs in the sketch.
      But yes, you can control relays with the analog outputs.
      Remember to power the relays separately though. They are power hungry beasts.
      • P Offline
        P Offline
        Porky6666
        ok i defined Relay 6,7,8 at A0,A1,A2, when i initial send a digitalwrite(high) or low within the sketch and uload that, it gone OK, but when want to change the states at runtime per radio, nothing changed but Relays 1 to 5 are ok.
        example:
        pinMode(3, OUTPUT);
        pinMode(4, OUTPUT);
        pinMode(5, OUTPUT);
        pinMode(6, OUTPUT);
        pinMode(7, OUTPUT);
        pinMode(18, OUTPUT);
        pinMode(19, OUTPUT);
        pinMode(20, OUTPUT);
        digitalWrite(3, HIGH);
        digitalWrite(4, HIGH);
        digitalWrite(5, HIGH);
        digitalWrite(6, HIGH);
        digitalWrite(7, HIGH);
        digitalWrite(18, HIGH);
        digitalWrite(19, HIGH);
        digitalWrite(20, HIGH);
        any idea ?
        Bye Stefan
        • H Offline
          H Offline
          wrote on last edited by hek
          You will have to post your sketch code as well if we should be able to help you. Enclose it in ```` to get code formatting.
          • P Offline
            P Offline
            Porky6666
            Ok, thanks
            ""// Example sketch showing how to control physical relays.
            // This example will remember relay state even after power failure.
            //#define SPI_CE 9
            //#define SPI_SS 10 // PB0, pin 8, Digital17
            //#define SPI_MISO 14 // PB3, pin 11, Digital14
            //#define SPI_MOSI 16 // PB2, pin 10, Digital16
            //#define SPI_SCK 15 // PB1, pin 9, Digital15
            //#define MySensor(uint8_t cepin = 9, uint8_t cspin = 10);
            #define RELAY_1 3 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
            #define RELAY_2 4
            #define RELAY_3 5
            #define RELAY_4 6
            #define RELAY_5 7
            #define RELAY_6 18
            #define RELAY_7 19
            #define RELAY_8 20
            #define NUMBER_OF_RELAYS 8 // Total number of attached relays
            #define RELAY_ON 1 // GPIO value to write to turn on attached relay
            //MySensor(uint8_t cepin = 9, uint8_t cspin = 10) gw;
            pinMode(3, OUTPUT);
            pinMode(4, OUTPUT);
            pinMode(5, OUTPUT);
            pinMode(6, OUTPUT);
            pinMode(7, OUTPUT);
            //MySensor(uint8_t cepin=9, uint8_t cspin=10)
            gw.sendSketchInfo("Relay", "1.0");
            // Fetch relay status
            gw.present(sensor, S_LIGHT);
            pinMode(pin, OUTPUT);
            digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
            if (message.type==V_LIGHT) {
            // Change relay state
            // Store state in eeprom
            H 1 Reply Last reply
            • P Porky6666
              Ok, thanks
              //#define SPI_CE 9
              #define RELAY_2 4
              #define RELAY_3 5
              #define RELAY_4 6
              #define RELAY_5 7
              #define RELAY_6 18
              #define RELAY_7 19
              #define RELAY_8 20
              pinMode(3, OUTPUT);
              pinMode(4, OUTPUT);
              pinMode(5, OUTPUT);
              pinMode(6, OUTPUT);
              pinMode(7, OUTPUT);
              H Offline
              H Offline
              @Porky6666
              That will ot work as you don't actually use the GPIO-defines you created at the top of your sketch.
              I would probably have created an array with the pins you intend to use and loop over it when initializing and handling the commands from gateway.
              E.g.
              char[] pins = [3,4,5,6,7,18,19,20];
              for (int i=0;i<pins.length;i++) {
                   pinMode(pin[i], OUTPUT);
                   digitalWrite(pin[i], HIGH);
              And likewise when receiving controller commands.
              • P Offline
                P Offline
                Porky6666
                this ist the orginal example from this site, and so it works vor 5 relays.
                #define RELAY_2 4
                #define RELAY_3 5
                #define RELAY_4 6
                #define RELAY_5 7
                //#define RELAY_6 18
                //#define RELAY_7 19
                //#define RELAY_8 20
                #define NUMBER_OF_RELAYS 5 // Total number of attached relays
                but not more.
                On an Arduino Pro Mini
                this sketch works for 6 Relays inkl. D8, i have changed to pro micro
                an i used 2 different new ones same result, 5 Relays working -- externel power supply to the relays, arduino only needs to pull up or pull down.
                bye
                Stefan
                thanks for your help
                • S Offline
                  soward
                  That sketch only works when the desired output pins are in numerical sequence. Once you need to use a variety of pin numbers in an arbitrary order, you will need to mange them differently.
                  Using an array as Hek suggested is no doubt your best option.
                  • P Offline
                    P Offline
                    Porky6666
                    Thats a fact i'd. Never known,
                    Thanks for your help.
                    Stefan
                    • Z Offline
                      Z Offline
                      Zeph
                      @Porky6666
                      You can insert 4 spaces at the beginning of each line to show it as code here:
                      include <SPI.h>
                      #define RELAY_2 4
                      #define RELAY_3 5
                      #define RELAY_4 6
                      #define RELAY_5 7
                      • S Offline
                        sjoerd14
                        Here is the example of the code using an 8 delay board.
                        I used the Analog devices as much as possible because I intend to include 1-wire temp sensors as well.
                        On my (clone) Mini there are 8 analog pins but useable on the bread board because of the location. I will use them in the final perfboard.
                          // Using an Array to define the pin's
                        const int RELAY[] = {A0, A1, A2, A3, A4, 6, 7, 8}; // I/O pins for the relays
                          for (int sensor=1, pin=0; sensor<=NUMBER_OF_RELAYS;sensor++, pin++) {
                            pinMode(RELAY[pin], OUTPUT);
                            digitalWrite(RELAY[pin], gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
                             digitalWrite(RELAY[message.sensor-1], message.getBool()?RELAY_ON:RELAY_OFF);
                        greglG 1 Reply Last reply
                        • S sjoerd14
                          greglG Offline
                          greglG Offline
                          gregl
                          I learned the other day that you can use the "Analog" I/O for one-wire anyway? just treat them as they were digital!
                          • P Offline
                            P Offline
                            Porky6666
                            @sjoerd14
                            Great thx a lot -- is working fine your example.
                            bye
                            Stefan
                            jeylitesJ 1 Reply Last reply
                            • P Porky6666
                              @sjoerd14
                              bye
                              Stefan
                              jeylitesJ Offline
                              jeylitesJ Offline
                              jeylites
                              wrote on last edited by jeylites
                              Hi, I'm trying to create an array of binary switches based on the 8Ch relay script, but I'm having issues setting it up. I don't have much knowledge in array and I was wondering if anyone here could guide me.
                              // digitial I/O pin 3 (BUTTON_PIN below) and GND.
                              const int BUTTON[] = {3, 4, 5};
                              #define NUMBER_OF_BUTTONS 3
                              //#define CHILD_ID 3
                              //#define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
                              Bounce debouncer = Bounce();
                              int oldValue=-1;
                              MyMessage msg(V_TRIPPED);
                                gw.begin();
                                for (int sensor=1, pin=0; sensor<=NUMBER_OF_BUTTONS;sensor++, pin++) {
                               // Setup the button
                                pinMode(BUTTON[pin],INPUT);
                                // Activate internal pull-up
                                digitalWrite(BUTTON[pin],HIGH);
                                debouncer.attach(BUTTON[pin]);
                                debouncer.interval(5);
                                gw.present(sensor, S_DOOR);
                                debouncer.update();
                                // Get the update value
                                int value = debouncer.read();
                                if (value != oldValue) {
                                   // Send in the new value
                                   oldValue = value;
                              • jeylitesJ jeylites
                                int oldValue=-1;
                                  gw.begin();
                                 // Setup the button
                                  debouncer.update();
                                     oldValue = value;
                                jeylitesJ Offline
                                jeylitesJ Offline
                                jeylites
                                In addition to my message above, I'm getting a bunch of errors when I try to compile the above binary sketch. Hope to hear from some one.
                                12.1k
