  3. Arduino Pro MICRO Pinout for 8 channel Relay
pro microanalog pin on ppinoutlibrary
15 Posts 7 Posters 10.7k Views 3 Watching
    It has really nothing to do with the MySensors library how you choose to control the GPIOs in the sketch.
    But yes, you can control relays with the analog outputs.
    Remember to power the relays separately though. They are power hungry beasts.
    • P
      P
      Porky6666
      ok i defined Relay 6,7,8 at A0,A1,A2, when i initial send a digitalwrite(high) or low within the sketch and uload that, it gone OK, but when want to change the states at runtime per radio, nothing changed but Relays 1 to 5 are ok.
      example:
      pinMode(3, OUTPUT);
      pinMode(4, OUTPUT);
      pinMode(5, OUTPUT);
      pinMode(6, OUTPUT);
      pinMode(7, OUTPUT);
      pinMode(18, OUTPUT);
      pinMode(19, OUTPUT);
      pinMode(20, OUTPUT);
      digitalWrite(3, HIGH);
      digitalWrite(4, HIGH);
      digitalWrite(5, HIGH);
      digitalWrite(6, HIGH);
      digitalWrite(7, HIGH);
      digitalWrite(18, HIGH);
      digitalWrite(19, HIGH);
      digitalWrite(20, HIGH);
      any idea ?
      Bye Stefan
        wrote on last edited by hek
        You will have to post your sketch code as well if we should be able to help you. Enclose it in ```` to get code formatting.
        • P
          P
          Porky6666
          Ok, thanks
          ""// Example sketch showing how to control physical relays.
          // This example will remember relay state even after power failure.
          //#define SPI_CE 9
          //#define SPI_SS 10 // PB0, pin 8, Digital17
          //#define SPI_MISO 14 // PB3, pin 11, Digital14
          //#define SPI_MOSI 16 // PB2, pin 10, Digital16
          //#define SPI_SCK 15 // PB1, pin 9, Digital15
          //#define MySensor(uint8_t cepin = 9, uint8_t cspin = 10);
          #define RELAY_1 3 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
          #define RELAY_2 4
          #define RELAY_3 5
          #define RELAY_4 6
          #define RELAY_5 7
          #define RELAY_6 18
          #define RELAY_7 19
          #define RELAY_8 20
          #define NUMBER_OF_RELAYS 8 // Total number of attached relays
          #define RELAY_ON 1 // GPIO value to write to turn on attached relay
          //MySensor(uint8_t cepin = 9, uint8_t cspin = 10) gw;
          pinMode(3, OUTPUT);
          pinMode(4, OUTPUT);
          pinMode(5, OUTPUT);
          pinMode(6, OUTPUT);
          pinMode(7, OUTPUT);
          //MySensor(uint8_t cepin=9, uint8_t cspin=10)
          gw.sendSketchInfo("Relay", "1.0");
          // Fetch relay status
          gw.present(sensor, S_LIGHT);
          pinMode(pin, OUTPUT);
          digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
          if (message.type==V_LIGHT) {
          // Change relay state
          // Store state in eeprom
          hekH 1 Reply Last reply
          • P Porky6666
            Ok, thanks
            //#define SPI_CE 9
            #define RELAY_2 4
            #define RELAY_3 5
            #define RELAY_4 6
            #define RELAY_5 7
            #define RELAY_6 18
            #define RELAY_7 19
            #define RELAY_8 20
            pinMode(3, OUTPUT);
            pinMode(4, OUTPUT);
            pinMode(5, OUTPUT);
            pinMode(6, OUTPUT);
            pinMode(7, OUTPUT);
            @Porky6666
            That will ot work as you don't actually use the GPIO-defines you created at the top of your sketch.
            I would probably have created an array with the pins you intend to use and loop over it when initializing and handling the commands from gateway.
            E.g.
            char[] pins = [3,4,5,6,7,18,19,20];
            for (int i=0;i<pins.length;i++) {
                 pinMode(pin[i], OUTPUT);
                 digitalWrite(pin[i], HIGH);
            And likewise when receiving controller commands.
            • P
              P
              Porky6666
              this ist the orginal example from this site, and so it works vor 5 relays.
              #define RELAY_2 4
              #define RELAY_3 5
              #define RELAY_4 6
              #define RELAY_5 7
              //#define RELAY_6 18
              //#define RELAY_7 19
              //#define RELAY_8 20
              #define NUMBER_OF_RELAYS 5 // Total number of attached relays
              but not more.
              On an Arduino Pro Mini
              this sketch works for 6 Relays inkl. D8, i have changed to pro micro
              an i used 2 different new ones same result, 5 Relays working -- externel power supply to the relays, arduino only needs to pull up or pull down.
              bye
              Stefan
              thanks for your help
              • sowardS
                sowardS
                soward
                That sketch only works when the desired output pins are in numerical sequence. Once you need to use a variety of pin numbers in an arbitrary order, you will need to mange them differently.
                Using an array as Hek suggested is no doubt your best option.
                • P
                  P
                  Porky6666
                  Thats a fact i'd. Never known,
                  Thanks for your help.
                  Stefan
                  • Z
                    Z
                    Zeph
                    @Porky6666
                    You can insert 4 spaces at the beginning of each line to show it as code here:
                    include <SPI.h>
                    #define RELAY_2 4
                    #define RELAY_3 5
                    #define RELAY_4 6
                    #define RELAY_5 7
                      sjoerd14
                      Here is the example of the code using an 8 delay board.
                      I used the Analog devices as much as possible because I intend to include 1-wire temp sensors as well.
                      On my (clone) Mini there are 8 analog pins but useable on the bread board because of the location. I will use them in the final perfboard.
                        // Using an Array to define the pin's
                      const int RELAY[] = {A0, A1, A2, A3, A4, 6, 7, 8}; // I/O pins for the relays
                        for (int sensor=1, pin=0; sensor<=NUMBER_OF_RELAYS;sensor++, pin++) {
                          pinMode(RELAY[pin], OUTPUT);
                          digitalWrite(RELAY[pin], gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
                           digitalWrite(RELAY[message.sensor-1], message.getBool()?RELAY_ON:RELAY_OFF);
                      greglG 1 Reply Last reply
                      • S sjoerd14
                        greglG
                        greglG
                        gregl
                        I learned the other day that you can use the "Analog" I/O for one-wire anyway? just treat them as they were digital!
                        • P
                          P
                          Porky6666
                          @sjoerd14
                          Great thx a lot -- is working fine your example.
                          bye
                          Stefan
                          jeylitesJ 1 Reply Last reply
                          • P Porky6666
                            @sjoerd14
                            bye
                            Stefan
                            jeylitesJ
                            jeylitesJ
                            jeylites
                            wrote on last edited by jeylites
                            Hi, I'm trying to create an array of binary switches based on the 8Ch relay script, but I'm having issues setting it up. I don't have much knowledge in array and I was wondering if anyone here could guide me.
                            // digitial I/O pin 3 (BUTTON_PIN below) and GND.
                            const int BUTTON[] = {3, 4, 5};
                            #define NUMBER_OF_BUTTONS 3
                            //#define CHILD_ID 3
                            //#define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
                            Bounce debouncer = Bounce();
                            int oldValue=-1;
                            MyMessage msg(V_TRIPPED);
                              gw.begin();
                              for (int sensor=1, pin=0; sensor<=NUMBER_OF_BUTTONS;sensor++, pin++) {
                             // Setup the button
                              pinMode(BUTTON[pin],INPUT);
                              // Activate internal pull-up
                              digitalWrite(BUTTON[pin],HIGH);
                              debouncer.attach(BUTTON[pin]);
                              debouncer.interval(5);
                              gw.present(sensor, S_DOOR);
                              debouncer.update();
                              // Get the update value
                              int value = debouncer.read();
                              if (value != oldValue) {
                                 // Send in the new value
                                 oldValue = value;
                            • jeylitesJ jeylites
                              int oldValue=-1;
                                gw.begin();
                               // Setup the button
                                debouncer.update();
                                   oldValue = value;
                              jeylitesJ
                              jeylitesJ
                              jeylites
                              In addition to my message above, I'm getting a bunch of errors when I try to compile the above binary sketch. Hope to hear from some one.
