  3. 💬 MDMSNode "Power"
💬 MDMSNode "Power"
arduinoatsha204ahlk-pm01mysensorsdc-dcnrf24l01atmega328prelayrfm69acs711
33 Posts 7 Posters 11.1k Views 5 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/362/MDMSNode-Power
      Samuel235
      Is there any chance we could see the .brd file or at least give us some sort of dimensions for the physical product here.
      MySensors 2.1.1
      kalinaK 1 Reply Last reply
      • S Samuel235
        kalinaK
        kalinaK
        kalina
        @Samuel235 said in 💬 MDMSNode "Power":
        This is pcb size picture:
        And this is enclosure link.
          Samuel235
          Awesome, might be beneficial to add to the openhardware description too.
          MySensors 2.1.1
          • S Samuel235
            kalinaK
            kalinaK
            kalina
            @Samuel235 I agree, it will be done.
            S 1 Reply Last reply
            • kalinaK kalina
              Samuel235
              @kalina - Perfect, I notice you have published design files for the rest of your designs but not this. Can't help but wonder why....
              MySensors 2.1.1
              • S Samuel235
                kalinaK
                kalinaK
                kalina
                @Samuel235 Because I have already found mistake with ACS711 connection... i will upload source files later, don't worry :)
                • kalinaK kalina
                  Samuel235
                  @kalina I Look forward to seeing the files ;)
                  Do you design your boards to a certain sizing to fit in certain containers/enclosures or do you just size your boards according to the contained hardware?
                  I've recently noticed that there isn't much price difference from say a 50 x 50mm to a 100 x 100mm board. When i started to get boards made, there were 50 x 50mm prototyping board packages that were much cheaper than the 100mm counterparts. This opens up a much more interesting scope for products made here now.
                  MySensors 2.1.1
                  • S Samuel235
                    kalinaK
                    kalinaK
                    kalina
                    @Samuel235 Firstly I choose the type of device that I want to design, then I look for suitable enclosure. Further work involves the placement of everything in the enclosure. In addition to that, I always use 3D modeling for appreciating the ability to do the task.
                    • kalinaK kalina
                      Samuel235
                      @kalina - It's always nice to see how other people work :) Thank you for sharing your methods.
                      MySensors 2.1.1
                      • kalinaK
                        kalinaK
                        kalina
                        I have received pcbs and i am waiting for components now for device testing.
                        PCBWAY.com sent me pcbs in less than 2 weeks, as always super quality, thanks to them!
                        • kalinaK kalina
                          Samuel235
                          @kalina - I can't recommend PCBWay.com enough to people considering their price point, they're pretty high quality. Hope to see the tests completed without issue for you :)
                          MySensors 2.1.1
                          • S Samuel235
                            kalinaK
                            kalinaK
                            kalina
                            Thanks! But for the first release it sounds extremely optimistic :bowtie:
                            • kalinaK kalina
                              Samuel235
                              @kalina - We can be positive ;)
                              MySensors 2.1.1
                              • kalinaK
                                kalinaK
                                kalina
                                Luckily, the device has started up without problems. Yesterday I tested it, even the kettle worked through the device (9A). Now I can share the source files of the project (already are refreshed).
                                3_1495287454163_MDMSNode_Power_11.jpg 2_1495287454163_MDMSNode_Power_10.jpg 1_1495287454163_MDMSNode_Power_9.jpg 0_1495287454163_MDMSNode_Power_8.jpg
                                S sundberg84S 2 Replies Last reply
                                • kalinaK kalina
                                  Samuel235
                                  @kalina - I knew you could do it o.O
                                  MySensors 2.1.1
                                  • kalinaK kalina
                                    sundberg84S
                                    sundberg84S
                                    @kalina what is the purpose of the vias on the AC traces? Thermal relief from the components on the other side?
                                    • sundberg84S sundberg84
                                      kalinaK
                                      kalinaK
                                      kalina
                                      @sundberg84, vias connect the AC traces on the TOP and BOT layers (see picture). This was done for reduce resistance of the conductors and distribute the heat caused by the flow of large currents through them.
                                      • J
                                        J
                                        JWB
                                        Kalina,
                                        What CAD program are you using for this project? The board file does not seem to be Eagle or KiCad.
                                        • J JWB
                                          Kalina,
                                          kalinaK
                                          kalinaK
                                          kalina
                                          @JWB said in 💬 MDMSNode "Power":
                                          I use Altium Designer.
