  3. [SOLVED] Sleep dont run
51 Posts 8 Posters 15.4k Views 7 Watching
  • mar.conteM Offline
    mar.conteM Offline
    mar.conte
    Hi to all,
    Why my atmega328 in breadboard with official bootloader atmega328 (8mhz internal) qnd rfm69 with pir dont go in sleep?
    I see in serial wich send every
    Tanks
     * Version 1.0 - Henrik Ekblad
    // Enable debug prints
    // #define MY_DEBUG
    #define MY_RADIO_RFM69
    unsigned long SLEEP_TIME = 0; // Sleep time between reports (in milliseconds)
    // Initialize motion message
    	present(CHILD_ID, S_MOTION);
    	// Read digital motion value
    	bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
    	Serial.println(tripped);
    M.C.
    mfalkviddM T 2 Replies Last reply
    • mar.conteM mar.conte
      Hi to all,
      Tanks
      // #define MY_DEBUG
      Hi @mar.conte
      Could you post the serial output as well?
      mar.conteM 1 Reply Last reply
      • tonnerre33T Offline
        tonnerre33T Offline
        tonnerre33
        @mar.conte said in Sleep dont run:
        Hi, you need to change the SLEEP_TIME value .
        For example :
        SLEEP_TIME = 10000 //Time in milliseconds
        • tonnerre33T tonnerre33
          For example :
          mar.conteM Offline
          mar.conteM Offline
          mar.conte
          @tonnerre33
          If i want sleep forever and wake only pir is high?
          M.C.
          • H Offline
            H Offline
            HarryDutch
            @mar-conte
            What happens if you change your sleep function like this:
            sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), HIGH,0);
            • H HarryDutch
              @mar-conte
              mar.conteM Offline
              mar.conteM Offline
              mar.conte
              @HarryDutch
              I have try...
              Nothing, the mcu dont sleep😭
              M.C.
              H A 2 Replies Last reply
                @HarryDutch
                I have try...
                H Offline
                H Offline
                HarryDutch
                @mar.conte A shot in the dark but have you tried to pull down pin 3 in order to prevent this pin is floating? Connect pin 3 to ground with a 10K resistor.
                  Hi to all,
                  Tanks
                  // #define MY_DEBUG
                  T Offline
                  T Offline
                  torfinn
                  @mar.conte Hi ! Have the same problem with mysensor and NRF24l01. Tried to pull down both pins 4,5 (INT1/2) and even tried just to sleep(10000) without success. My circuit uses 17mA sending and 3,5mA when its supposed to sleep ???
                  • T torfinn
                    tonnerre33T Offline
                    tonnerre33T Offline
                    tonnerre33
                    @torfinn said in Sleep dont run and @mar-conte :
                    Did you mesure the current consumed by the PIR when you are in sleep mode ?
                      @HarryDutch
                      I have try...
                      A Offline
                      A Offline
                      AWI
                      @mar.conte I did some testing and I am experiencing a similar thing.
                      The node powers down (8 uA)with sleep( 5000 ); // sleep only
                      but with
                      sleep(INTERRUPT1, CHANGE, INTERRUPT2, CHANGE, 0 ); // sleep and wait for motion
                      or
                      sleep(INTERRUPT1, FALLING, INTERRUPT2, FALLING, 0 ); // sleep and wait for motion
                      it doesn't (2.5 mA)
                      I will do some additional testing ...:confused:
                      Y 1 Reply Last reply
                        What library version are you using?
                          Hi @mar.conte
                          mar.conteM Offline
                          mar.conteM Offline
                          mar.conte
                          @mfalkvidd
                          4 TSM:INIT
                          4 TSF:WUR:MS=0
                          8 TSM:INIT:TSP OK
                          10 TSM:FPAR
                          141 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          2148 !TSM:FPAR:NO REPLY
                          2150 TSM:FPAR
                          2281 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          4288 !TSM:FPAR:NO REPLY
                          4290 TSM:FPAR
                          4421 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          6430 !TSM:FPAR:NO REPLY
                          6432 TSM:FPAR
                          6563 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          8574 !TSM:FPAR:FAIL
                          8577 TSM:FAIL:CNT=1
                          8579 TSM:FAIL:PDT
                          M.C.
                          mfalkviddM gohanG 2 Replies Last reply
                            @mfalkvidd
                            4 TSM:INIT
                            4 TSF:WUR:MS=0
                            8 TSM:INIT:TSP OK
                            10 TSM:FPAR
                            2150 TSM:FPAR
                            4290 TSM:FPAR
                            6432 TSM:FPAR
                            8574 !TSM:FPAR:FAIL
                            8577 TSM:FAIL:CNT=1
                            8579 TSM:FAIL:PDT
                            @mar.conte the node is unable to connect to your gateway so it never enters loop() and therefore never reaches the sleep statement.
                            mar.conteM 2 Replies Last reply
                              mar.conteM Offline
                              mar.conteM Offline
                              mar.conte
                              @mfalkvidd
                              infact i the gw not exist, i try with gw and test again tanks
                              M.C.
                                mar.conteM Offline
                                mar.conteM Offline
                                mar.conte
                                @mfalkvidd
                                what example in mysensors library i try?
                                M.C.
                                • A AWI
                                  but with
                                  or
                                  it doesn't (2.5 mA)
                                  Y Offline
                                  Y Offline
                                  @AWI See @tekka post here
                                  "For indefinite sleeping, only level IRQ triggers are permitted (see AVR datasheet)."
                                  Could you give that a try?
                                  A 1 Reply Last reply
                                    @mfalkvidd
                                    4 TSM:INIT
                                    4 TSF:WUR:MS=0
                                    8 TSM:INIT:TSP OK
                                    10 TSM:FPAR
                                    2150 TSM:FPAR
                                    4290 TSM:FPAR
                                    6432 TSM:FPAR
                                    8574 !TSM:FPAR:FAIL
                                    8577 TSM:FAIL:CNT=1
                                    8579 TSM:FAIL:PDT
                                    @mar.conte remember to set node ID
                                      mar.conteM Offline
                                      mar.conteM Offline
                                      mar.conte
                                      @gohan
                                      one example to set node id in motion sketch?
                                      M.C.
                                        mar.conteM Offline
                                        mar.conte
                                        wrote on last edited by mar.conte
                                        RESOLVED
                                        I HAVE JUST ONE GATEWAY CONFIGURED WITH RFM69 ON BOARD, THEN I HAVE CONNECTED TO NODE ID MCU WITH PIR AND EVERYTHING WORKS, WHEN THE PIR IS HIGH CURRENT CONSUMED is 2.25 MAH, WHEN IN SLEEP MODE ONLY 30 microamps.
                                        THANKS TO ALL THAT I HAVE HELPED
                                        NODE
                                        #define MY_NODE_ID 1
                                        //#define MY_RADIO_NRF24
                                        GATEWAY
                                        * LEDs (OPTIONAL):
                                        * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
                                        // Enable serial gateway
                                        #define MY_GATEWAY_SERIAL
                                        #if F_CPU == 8000000L
                                        #define MY_BAUD_RATE 38400
                                        // Enable inclusion mode
                                        // Set blinking period
                                        // Flash leds on rx/tx/err
                                        SERIAL OUTPUT NODE
                                        4 TSM:INIT
                                        4 TSF:WUR:MS=0
                                        8 TSM:INIT:TSP OK
                                        10 TSM:INIT:STATID=1
                                        12 TSF:SID:OK,ID=1
                                        14 TSM:FPAR
                                        145 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        1044 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                        1050 TSF:MSG:FPAR OK,ID=0,D=1
                                        2152 TSM:FPAR:OK
                                        2152 TSM:ID
                                        2154 TSM:ID:OK
                                        2156 TSM:UPL
                                        2164 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                        2199 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                        2205 TSF:MSG:PONG RECV,HP=1
                                        2207 TSM:UPL:OK
                                        2209 TSM:READY:ID=1,PAR=0,DIS=1
                                        2263 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                        2287 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                        2344 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                                        2404 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                        4421 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=OK:Motion Sensor
                                        4483 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                                        4542 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                                        4548 MCO:REG:REQ
                                        4601 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                        4626 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                        4630 MCO:PIM:NODE REG=1
                                        4634 MCO:BGN:STP
                                        4636 MCO:BGN:INIT OK,TSP=1
                                        4689 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
                                        4698 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                                        4702 MCO:SLP:TPD
                                        4704 MCO:SLP:WUP=1
                                        4714 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
                                        4722 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                                        4726 MCO:SLP:TPD
                                        4728 MCO:SLP:WUP=1
                                        4739 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
                                        4747 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                                        4751 MCO:SLP:TPD
                                        4753 MCO:SLP:WUP=1
                                        4763 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
                                        4771 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                                        4775 MCO:SLP:TPD
                                        SERIAL OUTPUT GATEWAY
                                        0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.1.1
                                        0;255;3;0;9;TSM:INIT
                                        0;255;3;0;9;TSF:WUR:MS=0
                                        0;255;3;0;9;TSM:INIT:TSP OK
                                        0;255;3;0;9;TSM:INIT:GW MODE
                                        0;255;0;0;18;2.1.1
                                        0;255;3;0;9;MCO:BGN:STP
                                        0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                        1;1;1;0;16;1
                                        TANKS VERY VERY VERY TO ALL
                                        M.C.
                                          RESOLVED
                                          NODE
                                          GATEWAY
                                          * LEDs (OPTIONAL):
                                          SERIAL OUTPUT NODE
                                          4 TSM:INIT
                                          4 TSF:WUR:MS=0
                                          8 TSM:INIT:TSP OK
                                          12 TSF:SID:OK,ID=1
                                          14 TSM:FPAR
                                          2152 TSM:FPAR:OK
                                          2152 TSM:ID
                                          2154 TSM:ID:OK
                                          2156 TSM:UPL
                                          2207 TSM:UPL:OK
                                          4548 MCO:REG:REQ
                                          4634 MCO:BGN:STP
                                          4702 MCO:SLP:TPD
                                          4704 MCO:SLP:WUP=1
                                          4726 MCO:SLP:TPD
                                          4728 MCO:SLP:WUP=1
                                          4751 MCO:SLP:TPD
                                          4753 MCO:SLP:WUP=1
                                          4775 MCO:SLP:TPD
                                          0;255;0;0;18;2.1.1
                                          1;1;1;0;16;1
                                          Y Offline
                                          Y Offline
                                          @mar.conte Great to hear you nailed it!
                                          For others to learn: what did you change to make things work?
                                          gohanG 1 Reply Last reply
                                          12.1k
