  3. [SOLVED] Sleep dont run
51 Posts 8 Posters 16.6k Views 7 Watching
  • H
    H
    HarryDutch
    @mar-conte
    What happens if you change your sleep function like this:
    sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), HIGH,0);
    mar.conteM 1 Reply Last reply
    • H HarryDutch
      @mar-conte
      mar.conteM
      mar.conteM
      mar.conte
      @HarryDutch
      I have try...
      Nothing, the mcu dont sleep😭
      M.C.
      H AWIA 2 Replies Last reply
      • mar.conteM mar.conte
        @HarryDutch
        I have try...
        H
        H
        HarryDutch
        @mar.conte A shot in the dark but have you tried to pull down pin 3 in order to prevent this pin is floating? Connect pin 3 to ground with a 10K resistor.
          Hi to all,
          Why my atmega328 in breadboard with official bootloader atmega328 (8mhz internal) qnd rfm69 with pir dont go in sleep?
          I see in serial wich send every
          Tanks
           * Version 1.0 - Henrik Ekblad
          // Enable debug prints
          // #define MY_DEBUG
          #define MY_RADIO_RFM69
          unsigned long SLEEP_TIME = 0; // Sleep time between reports (in milliseconds)
          // Initialize motion message
          	present(CHILD_ID, S_MOTION);
          	// Read digital motion value
          	bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
          	Serial.println(tripped);
          torfinn
          @mar.conte Hi ! Have the same problem with mysensor and NRF24l01. Tried to pull down both pins 4,5 (INT1/2) and even tried just to sleep(10000) without success. My circuit uses 17mA sending and 3,5mA when its supposed to sleep ???
          • T torfinn
            tonnerre33T
            tonnerre33T
            tonnerre33
            @torfinn said in Sleep dont run and @mar-conte :
            Did you mesure the current consumed by the PIR when you are in sleep mode ?
              @HarryDutch
              I have try...
              AWIA
              AWIA
              AWI
              @mar.conte I did some testing and I am experiencing a similar thing.
              The node powers down (8 uA)with sleep( 5000 ); // sleep only
              but with
              sleep(INTERRUPT1, CHANGE, INTERRUPT2, CHANGE, 0 ); // sleep and wait for motion
              or
              sleep(INTERRUPT1, FALLING, INTERRUPT2, FALLING, 0 ); // sleep and wait for motion
              it doesn't (2.5 mA)
              I will do some additional testing ...:confused:
                What library version are you using?
                  Hi @mar.conte
                  Could you post the serial output as well?
                  mar.conteM
                  mar.conteM
                  mar.conte
                  @mfalkvidd
                  4 TSM:INIT
                  4 TSF:WUR:MS=0
                  8 TSM:INIT:TSP OK
                  10 TSM:FPAR
                  141 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  2148 !TSM:FPAR:NO REPLY
                  2150 TSM:FPAR
                  2281 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  4288 !TSM:FPAR:NO REPLY
                  4290 TSM:FPAR
                  4421 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  6430 !TSM:FPAR:NO REPLY
                  6432 TSM:FPAR
                  6563 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  8574 !TSM:FPAR:FAIL
                  8577 TSM:FAIL:CNT=1
                  8579 TSM:FAIL:PDT
                  M.C.
                  mfalkviddM gohanG 2 Replies Last reply
                    @mfalkvidd
                    4 TSM:INIT
                    4 TSF:WUR:MS=0
                    8 TSM:INIT:TSP OK
                    10 TSM:FPAR
                    2150 TSM:FPAR
                    4290 TSM:FPAR
                    6432 TSM:FPAR
                    8574 !TSM:FPAR:FAIL
                    8577 TSM:FAIL:CNT=1
                    8579 TSM:FAIL:PDT
                    @mar.conte the node is unable to connect to your gateway so it never enters loop() and therefore never reaches the sleep statement.
                    mar.conteM 2 Replies Last reply
                      mar.conteM
                      mar.conteM
                      mar.conte
                      @mfalkvidd
                      infact i the gw not exist, i try with gw and test again tanks
                      M.C.
                        mar.conteM
                        mar.conteM
                        mar.conte
                        @mfalkvidd
                        what example in mysensors library i try?
                        M.C.
                        • AWIA AWI
                          but with
                          or
                          it doesn't (2.5 mA)
                          @AWI See @tekka post here
                          "For indefinite sleeping, only level IRQ triggers are permitted (see AVR datasheet)."
                          Could you give that a try?
                          AWIA 1 Reply Last reply
                            @mfalkvidd
                            4 TSM:INIT
                            4 TSF:WUR:MS=0
                            8 TSM:INIT:TSP OK
                            10 TSM:FPAR
                            2150 TSM:FPAR
                            4290 TSM:FPAR
                            6432 TSM:FPAR
                            8574 !TSM:FPAR:FAIL
                            8577 TSM:FAIL:CNT=1
                            8579 TSM:FAIL:PDT
                            @mar.conte remember to set node ID
                              mar.conteM
                              mar.conteM
                              mar.conte
                              @gohan
                              one example to set node id in motion sketch?
                              M.C.
                              • mar.conteM
                                mar.conteM
                                mar.conte
                                wrote on last edited by mar.conte
                                RESOLVED
                                I HAVE JUST ONE GATEWAY CONFIGURED WITH RFM69 ON BOARD, THEN I HAVE CONNECTED TO NODE ID MCU WITH PIR AND EVERYTHING WORKS, WHEN THE PIR IS HIGH CURRENT CONSUMED is 2.25 MAH, WHEN IN SLEEP MODE ONLY 30 microamps.
                                THANKS TO ALL THAT I HAVE HELPED
                                NODE
                                #define MY_NODE_ID 1
                                //#define MY_RADIO_NRF24
                                GATEWAY
                                * LEDs (OPTIONAL):
                                * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
                                // Enable serial gateway
                                #define MY_GATEWAY_SERIAL
                                #if F_CPU == 8000000L
                                #define MY_BAUD_RATE 38400
                                // Enable inclusion mode
                                // Set blinking period
                                // Flash leds on rx/tx/err
                                SERIAL OUTPUT NODE
                                4 TSM:INIT
                                4 TSF:WUR:MS=0
                                8 TSM:INIT:TSP OK
                                10 TSM:INIT:STATID=1
                                12 TSF:SID:OK,ID=1
                                14 TSM:FPAR
                                145 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                1044 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                1050 TSF:MSG:FPAR OK,ID=0,D=1
                                2152 TSM:FPAR:OK
                                2152 TSM:ID
                                2154 TSM:ID:OK
                                2156 TSM:UPL
                                2164 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                2199 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                2205 TSF:MSG:PONG RECV,HP=1
                                2207 TSM:UPL:OK
                                2209 TSM:READY:ID=1,PAR=0,DIS=1
                                2263 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                2287 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                2344 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                                2404 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                4421 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=OK:Motion Sensor
                                4483 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                                4542 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                                4548 MCO:REG:REQ
                                4601 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                4626 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                4630 MCO:PIM:NODE REG=1
                                4634 MCO:BGN:STP
                                4636 MCO:BGN:INIT OK,TSP=1
                                4689 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
                                4698 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                                4702 MCO:SLP:TPD
                                4704 MCO:SLP:WUP=1
                                4714 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
                                4722 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                                4726 MCO:SLP:TPD
                                4728 MCO:SLP:WUP=1
                                4739 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
                                4747 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                                4751 MCO:SLP:TPD
                                4753 MCO:SLP:WUP=1
                                4763 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
                                4771 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                                4775 MCO:SLP:TPD
                                SERIAL OUTPUT GATEWAY
                                0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.1.1
                                0;255;3;0;9;TSM:INIT
                                0;255;3;0;9;TSF:WUR:MS=0
                                0;255;3;0;9;TSM:INIT:TSP OK
                                0;255;3;0;9;TSM:INIT:GW MODE
                                0;255;0;0;18;2.1.1
                                0;255;3;0;9;MCO:BGN:STP
                                0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                1;1;1;0;16;1
                                TANKS VERY VERY VERY TO ALL
                                M.C.
                                  RESOLVED
                                  NODE
                                  GATEWAY
                                  * LEDs (OPTIONAL):
                                  SERIAL OUTPUT NODE
                                  4 TSM:INIT
                                  4 TSF:WUR:MS=0
                                  8 TSM:INIT:TSP OK
                                  12 TSF:SID:OK,ID=1
                                  14 TSM:FPAR
                                  2152 TSM:FPAR:OK
                                  2152 TSM:ID
                                  2154 TSM:ID:OK
                                  2156 TSM:UPL
                                  2207 TSM:UPL:OK
                                  4548 MCO:REG:REQ
                                  4634 MCO:BGN:STP
                                  4702 MCO:SLP:TPD
                                  4704 MCO:SLP:WUP=1
                                  4726 MCO:SLP:TPD
                                  4728 MCO:SLP:WUP=1
                                  4751 MCO:SLP:TPD
                                  4753 MCO:SLP:WUP=1
                                  4775 MCO:SLP:TPD
                                  0;255;0;0;18;2.1.1
                                  1;1;1;0;16;1
                                  @mar.conte Great to hear you nailed it!
                                  For others to learn: what did you change to make things work?
                                  gohanG 1 Reply Last reply
                                  • YveauxY Yveaux
                                    @Yveaux I think he added the gateway as he wasn't using one
                                      mar.conteM
                                      mar.conteM
                                      mar.conte
                                      @gohan
                                      Yes of course, add gateway and the loop end , the node attachinterrupt with pir go to sleep when gateway receive
                                      Tanks
                                      M.C.
                                      • T
                                        torfinn
                                        Hi ! Just wanted to add that this also solved it for me. I had problem with properly registering on the gateway ( due to chips was used on old version earlier ). After finding this post I tried the https://www.mysensors.org/build/debug#clearing-eeprom and it fixed problem. Looking at 40uA sleeping now :-)
                                        • YveauxY Yveaux
                                          AWIA
                                          AWIA
                                          AWI
                                          @Yveaux said in [SOLVED] Sleep dont run:
                                          Thanks @Yveaux I thought I was losing it...:relaxed: Tried different options:
                                          sleep(INTERRUPT1, LOW, 0 ); // sleep and wait for motion :+1:
                                          sleep(INTERRUPT1, LOW, 5000 ); // sleep and wait for 5 secs :+1:
                                          sleep(INTERRUPT1, CHANGE, 0 ); // sleep and wait for motion :-1:
                                          but for the last op tion @mar-conte reported succes :confused: how come?
                                          My understanding is:
                                          • deep sleep: only LOW
                                          • timed sleep: LOW, CHANGE, RISING, FALLING
                                            or...?
