  3. [SOLVED] Sleep dont run
51 Posts 8 Posters 16.6k Views 7 Watching
  • T torfinn
    @mar.conte Hi ! Have the same problem with mysensor and NRF24l01. Tried to pull down both pins 4,5 (INT1/2) and even tried just to sleep(10000) without success. My circuit uses 17mA sending and 3,5mA when its supposed to sleep ???
    tonnerre33T
    tonnerre33T
    tonnerre33
    @torfinn said in Sleep dont run and @mar-conte :
    Did you mesure the current consumed by the PIR when you are in sleep mode ?
    • mar.conteM mar.conte
      @HarryDutch
      I have try...
      Nothing, the mcu dont sleep😭
      AWIA
      AWIA
      AWI
      @mar.conte I did some testing and I am experiencing a similar thing.
      The node powers down (8 uA)with sleep( 5000 ); // sleep only
      but with
      sleep(INTERRUPT1, CHANGE, INTERRUPT2, CHANGE, 0 ); // sleep and wait for motion
      or
      sleep(INTERRUPT1, FALLING, INTERRUPT2, FALLING, 0 ); // sleep and wait for motion
      it doesn't (2.5 mA)
      I will do some additional testing ...:confused:
        What library version are you using?
          Hi @mar.conte
          Could you post the serial output as well?
          mar.conteM
          mar.conteM
          mar.conte
          @mfalkvidd
          4 TSM:INIT
          4 TSF:WUR:MS=0
          8 TSM:INIT:TSP OK
          10 TSM:FPAR
          141 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          2148 !TSM:FPAR:NO REPLY
          2150 TSM:FPAR
          2281 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          4288 !TSM:FPAR:NO REPLY
          4290 TSM:FPAR
          4421 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          6430 !TSM:FPAR:NO REPLY
          6432 TSM:FPAR
          6563 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          8574 !TSM:FPAR:FAIL
          8577 TSM:FAIL:CNT=1
          8579 TSM:FAIL:PDT
          M.C.
          mfalkviddM gohanG 2 Replies Last reply
            @mfalkvidd
            4 TSM:INIT
            4 TSF:WUR:MS=0
            8 TSM:INIT:TSP OK
            10 TSM:FPAR
            2150 TSM:FPAR
            4290 TSM:FPAR
            6432 TSM:FPAR
            8574 !TSM:FPAR:FAIL
            8577 TSM:FAIL:CNT=1
            8579 TSM:FAIL:PDT
            @mar.conte the node is unable to connect to your gateway so it never enters loop() and therefore never reaches the sleep statement.
            mar.conteM 2 Replies Last reply
              mar.conteM
              mar.conteM
              mar.conte
              @mfalkvidd
              infact i the gw not exist, i try with gw and test again tanks
              M.C.
                mar.conteM
                mar.conteM
                mar.conte
                @mfalkvidd
                what example in mysensors library i try?
                M.C.
                • AWIA AWI
                  but with
                  or
                  it doesn't (2.5 mA)
                  @AWI See @tekka post here
                  "For indefinite sleeping, only level IRQ triggers are permitted (see AVR datasheet)."
                  Could you give that a try?
                  AWIA 1 Reply Last reply
                    @mfalkvidd
                    4 TSM:INIT
                    4 TSF:WUR:MS=0
                    8 TSM:INIT:TSP OK
                    10 TSM:FPAR
                    2150 TSM:FPAR
                    4290 TSM:FPAR
                    6432 TSM:FPAR
                    8574 !TSM:FPAR:FAIL
                    8577 TSM:FAIL:CNT=1
                    8579 TSM:FAIL:PDT
                    @mar.conte remember to set node ID
                    mar.conteM 1 Reply Last reply
                      mar.conteM
                      mar.conteM
                      mar.conte
                      @gohan
                      one example to set node id in motion sketch?
                      M.C.
                      • mar.conteM
                        mar.conteM
                        mar.conte
                        wrote on last edited by mar.conte
                        RESOLVED
                        I HAVE JUST ONE GATEWAY CONFIGURED WITH RFM69 ON BOARD, THEN I HAVE CONNECTED TO NODE ID MCU WITH PIR AND EVERYTHING WORKS, WHEN THE PIR IS HIGH CURRENT CONSUMED is 2.25 MAH, WHEN IN SLEEP MODE ONLY 30 microamps.
                        THANKS TO ALL THAT I HAVE HELPED
                        NODE
                         * Version 1.0 - Henrik Ekblad
                        // Enable debug prints
                        #define MY_NODE_ID 1
                        //#define MY_RADIO_NRF24
                        #define MY_RADIO_RFM69
                        unsigned long SLEEP_TIME = 0; // Sleep time between reports (in milliseconds)
                        // Initialize motion message
                        	present(CHILD_ID, S_MOTION);
                        	// Read digital motion value
                        	bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
                        	Serial.println(tripped);
                        GATEWAY
                        * LEDs (OPTIONAL):
                        * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
                        // Enable serial gateway
                        #define MY_GATEWAY_SERIAL
                        #if F_CPU == 8000000L
                        #define MY_BAUD_RATE 38400
                        // Enable inclusion mode
                        // Set blinking period
                        // Flash leds on rx/tx/err
                        SERIAL OUTPUT NODE
                        4 TSM:INIT
                        4 TSF:WUR:MS=0
                        8 TSM:INIT:TSP OK
                        10 TSM:INIT:STATID=1
                        12 TSF:SID:OK,ID=1
                        14 TSM:FPAR
                        145 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        1044 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                        1050 TSF:MSG:FPAR OK,ID=0,D=1
                        2152 TSM:FPAR:OK
                        2152 TSM:ID
                        2154 TSM:ID:OK
                        2156 TSM:UPL
                        2164 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                        2199 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                        2205 TSF:MSG:PONG RECV,HP=1
                        2207 TSM:UPL:OK
                        2209 TSM:READY:ID=1,PAR=0,DIS=1
                        2263 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                        2287 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                        2344 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                        2404 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                        4421 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=OK:Motion Sensor
                        4483 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                        4542 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                        4548 MCO:REG:REQ
                        4601 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                        4626 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                        4630 MCO:PIM:NODE REG=1
                        4634 MCO:BGN:STP
                        4636 MCO:BGN:INIT OK,TSP=1
                        4689 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
                        4698 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                        4702 MCO:SLP:TPD
                        4704 MCO:SLP:WUP=1
                        4714 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
                        4722 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                        4726 MCO:SLP:TPD
                        4728 MCO:SLP:WUP=1
                        4739 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
                        4747 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                        4751 MCO:SLP:TPD
                        4753 MCO:SLP:WUP=1
                        4763 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
                        4771 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                        4775 MCO:SLP:TPD
                        SERIAL OUTPUT GATEWAY
                        0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.1.1
                        0;255;3;0;9;TSM:INIT
                        0;255;3;0;9;TSF:WUR:MS=0
                        0;255;3;0;9;TSM:INIT:TSP OK
                        0;255;3;0;9;TSM:INIT:GW MODE
                        0;255;0;0;18;2.1.1
                        0;255;3;0;9;MCO:BGN:STP
                        0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=0,l=1,sg=0:1
                        1;1;1;0;16;1
                        TANKS VERY VERY VERY TO ALL
                        M.C.
                          RESOLVED
                          NODE
                          GATEWAY
                          * LEDs (OPTIONAL):
                          SERIAL OUTPUT NODE
                          4 TSM:INIT
                          4 TSF:WUR:MS=0
                          8 TSM:INIT:TSP OK
                          12 TSF:SID:OK,ID=1
                          14 TSM:FPAR
                          2152 TSM:FPAR:OK
                          2152 TSM:ID
                          2154 TSM:ID:OK
                          2156 TSM:UPL
                          2207 TSM:UPL:OK
                          4548 MCO:REG:REQ
                          4634 MCO:BGN:STP
                          4702 MCO:SLP:TPD
                          4704 MCO:SLP:WUP=1
                          4726 MCO:SLP:TPD
                          4728 MCO:SLP:WUP=1
                          4751 MCO:SLP:TPD
                          4753 MCO:SLP:WUP=1
                          4775 MCO:SLP:TPD
                          0;255;0;0;18;2.1.1
                          1;1;1;0;16;1
                          @mar.conte Great to hear you nailed it!
                          For others to learn: what did you change to make things work?
                          gohanG 1 Reply Last reply
                          • YveauxY Yveaux
                            @Yveaux I think he added the gateway as he wasn't using one
                              mar.conteM
                              mar.conteM
                              mar.conte
                              @gohan
                              Yes of course, add gateway and the loop end , the node attachinterrupt with pir go to sleep when gateway receive
                              Tanks
                              M.C.
                              • T
                                torfinn
                                Hi ! Just wanted to add that this also solved it for me. I had problem with properly registering on the gateway ( due to chips was used on old version earlier ). After finding this post I tried the https://www.mysensors.org/build/debug#clearing-eeprom and it fixed problem. Looking at 40uA sleeping now :-)
                                • YveauxY Yveaux
                                  AWIA
                                  AWIA
                                  AWI
                                  @Yveaux said in [SOLVED] Sleep dont run:
                                  Thanks @Yveaux I thought I was losing it...:relaxed: Tried different options:
                                  sleep(INTERRUPT1, LOW, 0 ); // sleep and wait for motion :+1:
                                  sleep(INTERRUPT1, LOW, 5000 ); // sleep and wait for 5 secs :+1:
                                  sleep(INTERRUPT1, CHANGE, 0 ); // sleep and wait for motion :-1:
                                  but for the last op tion @mar-conte reported succes :confused: how come?
                                  My understanding is:
                                  • deep sleep: only LOW
                                  • timed sleep: LOW, CHANGE, RISING, FALLING
                                    or...?
                                  • mar.conteM
                                    mar.conteM
                                    mar.conte
                                    Hello everyone, I do not understand why ATmega328 powered with an Arduino board without MCU with 3v3 volts when ba consumes 30 microamps in sleep imvece atmega if the power is two batteries 1,5 knows when he goes to sleep consumes 420 microamps, I'm not understanding nothing seemed that just consumed my project with pir and ATMEga
                                    M.C.
                                      AWIA
                                      AWIA
                                      AWI
                                      @mar.conte I'm sorry but can you try to rephrase your question?
                                      • mar.conteM
                                        mar.conteM
                                        mar.conte
                                        Why the same configuration atmega+pir+rfm69 with ftdi power consumption is 30 microampere and with 2 1,5 AA is 420 microampere?
                                        M.C.
                                          @mar.conte how did you made the measurements?
