  3. [SOLVED] Sleep dont run
51 Posts 8 Posters 16.6k Views 7 Watching
  • tonnerre33T
    tonnerre33T
    tonnerre33
    @mar.conte said in Sleep dont run:
    Hi, you need to change the SLEEP_TIME value .
    For example :
    SLEEP_TIME = 10000 //Time in milliseconds
    mar.conteM 1 Reply Last reply
    • tonnerre33T tonnerre33
      For example :
      mar.conteM
      mar.conteM
      mar.conte
      @tonnerre33
      If i want sleep forever and wake only pir is high?
      M.C.
      • H
        H
        HarryDutch
        @mar-conte
        What happens if you change your sleep function like this:
        sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), HIGH,0);
        • H HarryDutch
          @mar-conte
          mar.conteM
          mar.conteM
          mar.conte
          @HarryDutch
          I have try...
          Nothing, the mcu dont sleep😭
          M.C.
          H AWIA 2 Replies Last reply
          • mar.conteM mar.conte
            @HarryDutch
            I have try...
            H
            H
            HarryDutch
            @mar.conte A shot in the dark but have you tried to pull down pin 3 in order to prevent this pin is floating? Connect pin 3 to ground with a 10K resistor.
              Hi to all,
              Why my atmega328 in breadboard with official bootloader atmega328 (8mhz internal) qnd rfm69 with pir dont go in sleep?
              I see in serial wich send every
              Tanks
               * Version 1.0 - Henrik Ekblad
              // Enable debug prints
              // #define MY_DEBUG
              #define MY_RADIO_RFM69
              unsigned long SLEEP_TIME = 0; // Sleep time between reports (in milliseconds)
              // Initialize motion message
              	present(CHILD_ID, S_MOTION);
              	// Read digital motion value
              	bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
              	Serial.println(tripped);
              torfinn
              @mar.conte Hi ! Have the same problem with mysensor and NRF24l01. Tried to pull down both pins 4,5 (INT1/2) and even tried just to sleep(10000) without success. My circuit uses 17mA sending and 3,5mA when its supposed to sleep ???
              • T torfinn
                tonnerre33T
                tonnerre33T
                tonnerre33
                @torfinn said in Sleep dont run and @mar-conte :
                Did you mesure the current consumed by the PIR when you are in sleep mode ?
                  @HarryDutch
                  I have try...
                  AWIA
                  AWIA
                  AWI
                  @mar.conte I did some testing and I am experiencing a similar thing.
                  The node powers down (8 uA)with sleep( 5000 ); // sleep only
                  but with
                  sleep(INTERRUPT1, CHANGE, INTERRUPT2, CHANGE, 0 ); // sleep and wait for motion
                  or
                  sleep(INTERRUPT1, FALLING, INTERRUPT2, FALLING, 0 ); // sleep and wait for motion
                  it doesn't (2.5 mA)
                  I will do some additional testing ...:confused:
                    What library version are you using?
                      Hi @mar.conte
                      Could you post the serial output as well?
                      mar.conteM
                      mar.conteM
                      mar.conte
                      @mfalkvidd
                      4 TSM:INIT
                      4 TSF:WUR:MS=0
                      8 TSM:INIT:TSP OK
                      10 TSM:FPAR
                      141 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      2148 !TSM:FPAR:NO REPLY
                      2150 TSM:FPAR
                      2281 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      4288 !TSM:FPAR:NO REPLY
                      4290 TSM:FPAR
                      4421 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      6430 !TSM:FPAR:NO REPLY
                      6432 TSM:FPAR
                      6563 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      8574 !TSM:FPAR:FAIL
                      8577 TSM:FAIL:CNT=1
                      8579 TSM:FAIL:PDT
                      M.C.
                      mfalkviddM gohanG 2 Replies Last reply
                        @mfalkvidd
                        4 TSM:INIT
                        4 TSF:WUR:MS=0
                        8 TSM:INIT:TSP OK
                        10 TSM:FPAR
                        2150 TSM:FPAR
                        4290 TSM:FPAR
                        6432 TSM:FPAR
                        8574 !TSM:FPAR:FAIL
                        8577 TSM:FAIL:CNT=1
                        8579 TSM:FAIL:PDT
                        @mar.conte the node is unable to connect to your gateway so it never enters loop() and therefore never reaches the sleep statement.
                        mar.conteM 2 Replies Last reply
                          mar.conteM
                          mar.conteM
                          mar.conte
                          @mfalkvidd
                          infact i the gw not exist, i try with gw and test again tanks
                          M.C.
                            mar.conteM
                            mar.conteM
                            mar.conte
                            @mfalkvidd
                            what example in mysensors library i try?
                            M.C.
                            • AWIA AWI
                              but with
                              or
                              it doesn't (2.5 mA)
                              @AWI See @tekka post here
                              "For indefinite sleeping, only level IRQ triggers are permitted (see AVR datasheet)."
                              Could you give that a try?
                              AWIA 1 Reply Last reply
                                @mfalkvidd
                                4 TSM:INIT
                                4 TSF:WUR:MS=0
                                8 TSM:INIT:TSP OK
                                10 TSM:FPAR
                                2150 TSM:FPAR
                                4290 TSM:FPAR
                                6432 TSM:FPAR
                                8574 !TSM:FPAR:FAIL
                                8577 TSM:FAIL:CNT=1
                                8579 TSM:FAIL:PDT
                                @mar.conte remember to set node ID
                                  mar.conteM
                                  mar.conteM
                                  mar.conte
                                  @gohan
                                  one example to set node id in motion sketch?
                                  M.C.
                                  • mar.conteM
                                    mar.conteM
                                    mar.conte
                                    wrote on last edited by mar.conte
                                    RESOLVED
                                    I HAVE JUST ONE GATEWAY CONFIGURED WITH RFM69 ON BOARD, THEN I HAVE CONNECTED TO NODE ID MCU WITH PIR AND EVERYTHING WORKS, WHEN THE PIR IS HIGH CURRENT CONSUMED is 2.25 MAH, WHEN IN SLEEP MODE ONLY 30 microamps.
                                    THANKS TO ALL THAT I HAVE HELPED
                                    NODE
                                    #define MY_NODE_ID 1
                                    //#define MY_RADIO_NRF24
                                    GATEWAY
                                    * LEDs (OPTIONAL):
                                    * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
                                    // Enable serial gateway
                                    #define MY_GATEWAY_SERIAL
                                    #if F_CPU == 8000000L
                                    #define MY_BAUD_RATE 38400
                                    // Enable inclusion mode
                                    // Set blinking period
                                    // Flash leds on rx/tx/err
                                    SERIAL OUTPUT NODE
                                    4 TSM:INIT
                                    4 TSF:WUR:MS=0
                                    8 TSM:INIT:TSP OK
                                    10 TSM:INIT:STATID=1
                                    12 TSF:SID:OK,ID=1
                                    14 TSM:FPAR
                                    145 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    1044 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                    1050 TSF:MSG:FPAR OK,ID=0,D=1
                                    2152 TSM:FPAR:OK
                                    2152 TSM:ID
                                    2154 TSM:ID:OK
                                    2156 TSM:UPL
                                    2164 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                    2199 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                    2205 TSF:MSG:PONG RECV,HP=1
                                    2207 TSM:UPL:OK
                                    2209 TSM:READY:ID=1,PAR=0,DIS=1
                                    2263 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                    2287 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    2344 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                                    2404 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    4421 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=OK:Motion Sensor
                                    4483 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                                    4542 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                                    4548 MCO:REG:REQ
                                    4601 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                    4626 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                    4630 MCO:PIM:NODE REG=1
                                    4634 MCO:BGN:STP
                                    4636 MCO:BGN:INIT OK,TSP=1
                                    4689 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
                                    4698 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                                    4702 MCO:SLP:TPD
                                    4704 MCO:SLP:WUP=1
                                    4714 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
                                    4722 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                                    4726 MCO:SLP:TPD
                                    4728 MCO:SLP:WUP=1
                                    4739 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
                                    4747 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                                    4751 MCO:SLP:TPD
                                    4753 MCO:SLP:WUP=1
                                    4763 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
                                    4771 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                                    4775 MCO:SLP:TPD
                                    SERIAL OUTPUT GATEWAY
                                    0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.1.1
                                    0;255;3;0;9;TSM:INIT
                                    0;255;3;0;9;TSF:WUR:MS=0
                                    0;255;3;0;9;TSM:INIT:TSP OK
                                    0;255;3;0;9;TSM:INIT:GW MODE
                                    0;255;0;0;18;2.1.1
                                    0;255;3;0;9;MCO:BGN:STP
                                    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                    1;1;1;0;16;1
                                    TANKS VERY VERY VERY TO ALL
                                    M.C.
                                      RESOLVED
                                      NODE
                                      GATEWAY
                                      * LEDs (OPTIONAL):
                                      SERIAL OUTPUT NODE
                                      4 TSM:INIT
                                      4 TSF:WUR:MS=0
                                      8 TSM:INIT:TSP OK
                                      12 TSF:SID:OK,ID=1
                                      14 TSM:FPAR
                                      2152 TSM:FPAR:OK
                                      2152 TSM:ID
                                      2154 TSM:ID:OK
                                      2156 TSM:UPL
                                      2207 TSM:UPL:OK
                                      4548 MCO:REG:REQ
                                      4634 MCO:BGN:STP
                                      4702 MCO:SLP:TPD
                                      4704 MCO:SLP:WUP=1
                                      4726 MCO:SLP:TPD
                                      4728 MCO:SLP:WUP=1
                                      4751 MCO:SLP:TPD
                                      4753 MCO:SLP:WUP=1
                                      4775 MCO:SLP:TPD
                                      0;255;0;0;18;2.1.1
                                      1;1;1;0;16;1
                                      @mar.conte Great to hear you nailed it!
                                      For others to learn: what did you change to make things work?
                                      gohanG 1 Reply Last reply
                                      • YveauxY Yveaux
                                        @Yveaux I think he added the gateway as he wasn't using one
                                          mar.conteM
                                          mar.conteM
                                          mar.conte
                                          @gohan
                                          Yes of course, add gateway and the loop end , the node attachinterrupt with pir go to sleep when gateway receive
                                          Tanks
                                          M.C.
