  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 257.0k Views 53 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @alexsh1
    If you mean using a nrf24 with lna/pa, with the gateway. Then yes.. I have had it running for some months now.
    Anything in particular that you want to know?
    alexsh1A 1 Reply Last reply
    • tbowmoT tbowmo
      @alexsh1
      alexsh1A
      alexsh1A
      alexsh1
      #212
      @tbowmo yes, that's what I meant
      I am thinking about installing either a normal nrf24l01+ or lna/pa version. I have had some issues with power in the past with the lna/pa transceiver.
      What's your experience? What kind of power supply do you use? How better is the coverage?
      • tbowmoT
        tbowmoT
        tbowmo
        I haven't checked if the coverage is any better with the lna/pa version, compared to standard modules.
        Currently the gateway is connected to a RPI2, which in turn is powered by a 2A powersupply from RS Components
        I haven't had any issues with it yet, but then again.. I mainly receive data from sensor nodes, and not that much sending data to distant nodes from the gateway
        • tbowmoT tbowmo
          alexsh1A
          alexsh1A
          alexsh1
          @tbowmo It is probably not Sensebender topic, but more lna+pa range one.
          I am not sure about my RPi3 as though it is powered by the 3A PSU, I have a USB z-wave stick, three transceivers, one UPS Plco (as HAT) and a 20x4 screen. I lot of power is consumed so not sure adding yet another one. (lna+pa is power hungry during peaks).
          I'll get the nrf24l01+ lna+pa ordered and test the range. In my view rfm69 range is probably better, but I have the rfm69 gateway on moteino with a trace antenna (very small footprint and it is based on ATMega1284P so 128KB sketch flash memory - more than I need).
          @hek - is it the intention to combine rfm69 and nrf24l01+ gateways in one in the future?
          I understand Sensebender GW is ready for it, but it is more a software limitation???
          I am really looking forward to combined GW.
          I also have a separate one for rfm95 so that I can use some remote sensors.
            wrote on last edited by hek
            #215
            No, I haven't heard of any near plans in the core team about doing multi radio/sub-network support in 2.0.
            This requires some extra thoughts and would probably only fit on SAMD/ESP nodes.
              alexsh1A
              alexsh1A
              alexsh1
              @hek Which is good as the Sensebender GW is based on SAMD! So it is ready to be the first 2-in-1 GW.
              Anyway, keep on doing a great work! I'll patiently wait until the combined GW is there.
              • NiklasON
                NiklasON
                NiklasO
                wrote on last edited by NiklasO
                #217
                Ordered from ITEAD. Nice to get rid of this stuff:
                Just nudging anything result in problems. ;-)
                Time to fire up the 3D-printer.
                • NiklasON
                  NiklasON
                  NiklasO
                  #218
                  Aaaand, it's up! Very good fit (the box).
                  The box on top is just me trying out different colors of the case. ;)
                  The one on top has better look. Different brands of PLA.
                  • nick van alstN
                    nick van alstN
                    nick van alst
                    @NiklasO that looks very good!
                    Are you willing to share your design files with us?
                    i just ordered my gateway to get rid of cables and lose components :D a case would really make it complete!
                      @NiklasO
                      great :+1:
                      @nick-van-alst
                      you can get enclosure design files here https://www.mysensors.org/hardware/sensebender-gateway (on page bottom)
                      I designed different variants so pick which one you need.
                      • M meddie
                        Ok i just connected the W5100 and NRF24 Module and uploaded the GatewayW5100 Sketch and when the upload is done after reset i dont get any output on serial monitor.
                        The orange, green and red led are lighting.
                        When i upload the SensebenderGatewaySerial then i get output on serial monitor. It think the problem must be the w5100. But what going wrong?
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @meddie said in 💬 Sensebender Gateway:
                        @meddie Did you figure out what the problem is? I have exactly the same issue
                        M tbowmoT 2 Replies Last reply
                        • alexsh1A alexsh1
                          meddie
                          @alexsh1
                          hi, yes it was very simple :-D the gateway has worked fine in this time, i thought that when nothing shown in serial monitor that the gateway dont work, but it did it, after i connected the gateway to FHEM (my controller) i saw that FHEM connects t mys Gateway.
                          So it worked all the time
                          Greets Eddie
                          • alexsh1A alexsh1
                            tbowmoT
                            tbowmoT
                            tbowmo
                            @alexsh1
                            Have you tried to enable the debug output in the GatewayW5100 example? I think it is disabled by default, due to the limited memory on the small atmega 328p
                            • tbowmoT tbowmo
                              @alexsh1
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @tbowmo
                              Yes, I did
                              • alexsh1A
                                alexsh1A
                                alexsh1
                                #225
                                I am running Arduino IDE 1.8.1 on Windows 10
                                Arduino AVR 1.6.18
                                Arduino SAMD 1.6.12
                                MySensors SAMD 1.0.5
                                EDIT: I have tried to upload the default sketch on macbook with Arduino IDE 1.6.2
                                It is still the same - no debug info in the terminal
                                • alexsh1A
                                  alexsh1A
                                  alexsh1
                                  #226
                                  OK, I did manage to get debug working partially.
                                  The gateway reads messages, but does not work as the gateway
                                  0;255;3;0;9;MCO:BGN:STP
                                  0;255;3;0;9;TSF:MSG:READ,10-10-0,s=1,c=1,t=17,pt=5,l=4,sg=0:348
                                  0;255;3;0;9;TSF:MSG:READ,26-10-0,s=3,c=1,t=24,pt=5,l=4,sg=0:51219479
                                  0;255;3;0;9;TSF:MSG:READ,10-10-0,s=1,c=1,t=24,pt=5,l=4,sg=0:51219482
                                  0;255;3;0;9;TSF:MSG:READ,11-11-0,s=2,c=1,t=37,pt=7,l=5,sg=0:1717.62
                                  0;255;3;0;9;TSF:MSG:READ,11-11-0,s=0,c=1,t=37,pt=7,l=5,sg=0:5338.44
                                  0;255;3;0;9;TSF:MSG:READ,11-11-0,s=3,c=1,t=37,pt=7,l=5,sg=0:10.75
                                  0;255;3;0;9;TSF:MSG:READ,11-11-0,s=3,c=1,t=37,pt=7,l=5,sg=0:10.76
                                  0;255;3;0;9;TSF:MSG:READ,11-11-0,s=4,c=1,t=37,pt=4,l=4,sg=0:880
                                  0;255;3;0;9;TSF:MSG:READ,6-6-0,s=2,c=1,t=1,pt=7,l=5,sg=0:64.8
                                  0;255;3;0;9;TSF:MSG:READ,6-6-0,s=0,c=1,t=4,pt=7,l=5,sg=0:1015
                                  I never had a message:
                                  Gateway startup complete.
                                  EDIT: Self-test with SensebenderSerial sketch gives me this:
                                  Sensebender GateWay test routine
                                  Mysensors core version : 2.1.1
                                  GateWay sketch version : 0.2
                                  - > SHA204 Failed to wakeup SHA204
                                  - > SD CARD SD CARD did not initialize!
                                   -> EEPROM PASSED
                                  -> analog : 38 Failed
                                  tbowmoT 1 Reply Last reply
                                  • alexsh1A alexsh1
                                     -> EEPROM PASSED
                                    tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @alexsh1
                                    Could you check the soldering of the samd?
                                    SD card fails, if you haven't inserted a card, when running the self test.
                                    • tbowmoT tbowmo
                                      @alexsh1
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      #228
                                      @tbowmo
                                      I do not have the SD card so that's fine
                                      The samd looks fine - no bridges etc
                                      I can try to re-solder it with a hot fan
                                      Do you think samd may be at fault even though the serial GW is working?
                                      Unfortunately, I do not have another Ethernet w5100 to try it. Probably have to order a new one
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @alexsh1
                                        I know that @Anticimex had problems with one of the pre-production samples that we got from China, with various problems, that was solved with "reflowing" the samd with a hot air gun.. So it was just a thought, that it could be a bad solder joint..
                                        The W5100 is using it's own dedicated SPI port, so even though that the radio works, doesn't mean that there couldn't be any solder problems around the samd pins for W5100.
                                        We have 3 different SPI ports in use on the gateway, one for the MysX connector, one for radio / sdcard, and one for W5100..
                                        • tbowmoT tbowmo
                                          @alexsh1
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @tbowmo I do not have the oven to reflow the whole board, but can mount / unmount or re-work certain components 0805 or 0603. Below this it is a pain in the a***
                                          Another observation - The GW behaves like this with or without W5100 mounted.
                                          Seems like an SPI problem to me. How can I wire W5100 to MYSX please and what shall I can in the sketch please? Thank for your help - very much appreciate it
                                          AnticimexA 1 Reply Last reply
