  3. Node doesn't work without repeater
17 Posts 4 Posters 3.6k Views 4 Watching
  • TigroenotT Offline
    TigroenotT Offline
    Tigroenot
    wrote on last edited by Tigroenot
    Hello everybody!
    Please, I need an inspiration!
    I've got several nodes around my appartment: three temp/humidity sensors, double relay, door.
    I have built another relay node to hack my ikea floor lamp. It's working fine, and it has a default repeater feature. Now I have built another door sensor. It is a MySensors Stable node with MYS 1.3 bootloader. It's working through the node 10 (floor lamp). When I turn the lamp off to get rid of the repeater node the new door sensor (node 2) stops working. If I reboot it manually it doesn't find parent (I want it to be the gateway). I tried to assign manual parent ID 0 but it doesn't help.
    How do I make it work without the repeater? I want it to work in another room.
    P.S. I tried to clear eeprom, then flash the firmware, assign parent ID manually, rebooting it without repeater turned on, rebooted it near another repeater (double relay). Oh, I forgot to tell, the gateway is closer to the node then the repeater node 10.
    • TigroenotT Tigroenot
      Hello everybody!
      sundberg84S Offline
      sundberg84S Offline
      @Tigroenot - sounds like the right steps... strange.
      Any code or serial output from the node so we can see what happens when it boots?
      TigroenotT 2 Replies Last reply
      • sundberg84S sundberg84
        TigroenotT Offline
        TigroenotT Offline
        Tigroenot
        @sundberg84 thanks for quick response.
        Here is the serial output of the node when the repeater node 10 is on:
        0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0-beta
        4 TSM:INIT
        4 TSF:WUR:MS=0
        12 TSM:INIT:TSP OK
        14 TSF:SID:OK,ID=2
        16 TSM:FPAR
        53 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        1507 TSF:MSG:READ,10-10-2,s=255,c=3,t=8,pt=1,l=1,sg=0:1
        1513 TSF:MSG:FPAR OK,ID=10,D=2
        2060 TSM:FPAR:OK
        2060 TSM:ID
        2062 TSM:ID:OK
        2064 TSM:UPL
        2068 TSF:MSG:SEND,2-2-10-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
        2125 TSF:MSG:READ,0-10-2,s=255,c=3,t=25,pt=1,l=1,sg=0:2
        2131 TSF:MSG:PONG RECV,HP=2
        2136 TSM:UPL:OK
        2136 TSM:READY:ID=2,PAR=10,DIS=2
        2142 TSF:MSG:SEND,2-2-10-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        2191 TSF:MSG:READ,0-10-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        2199 TSF:MSG:SEND,2-2-10-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.1.0-beta
        2209 TSF:MSG:SEND,2-2-10-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:10
        2342 TSF:MSG:READ,0-10-2,s=255,c=3,t=6,pt=0,l=1,sg=0:M
        2351 TSF:MSG:SEND,2-2-10-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=OK:Binary Sensor
        2361 TSF:MSG:SEND,2-2-10-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
        2371 TSF:MSG:SEND,2-2-10-0,s=3,c=0,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
        2377 MCO:REG:REQ
        2396 TSF:MSG:SEND,2-2-10-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
        2500 TSF:MSG:READ,0-10-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
        2506 MCO:PIM:NODE REG=1
        2508 MCO:BGN:STP
        2510 MCO:BGN:INIT OK,TSP=1
        2514 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
        2519 MCO:SLP:TPD
        2521 MCO:SLP:WUP=-1
        2525 TSF:MSG:SEND,2-2-10-0,s=3,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:1
        2533 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
        2539 MCO:SLP:TPD
        2539 MCO:SLP:WUP=-1
        2545 TSF:MSG:SEND,2-2-10-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:100
        2553 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
        2557 MCO:SLP:TPD
        2560 MCO:SLP:WUP=1
        2562 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
        2568 MCO:SLP:TPD
        2570 MCO:SLP:WUP=-1
        2572 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
        2578 MCO:SLP:TPD
        2578 MCO:SLP:WUP=-1
        2582 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
        2586 MCO:SLP:TPD```
          TigroenotT Offline
          TigroenotT Offline
          Tigroenot
          @sundberg84 Adn here is the serial output of the node 2 when the repeater node 10 is off:
          Here is the serial output of the node 2 when the repeater node 10 is off:
          4 TSM:INIT
          4 TSF:WUR:MS=0
          12 TSM:INIT:TSP OK
          14 TSF:SID:OK,ID=2
          16 TSM:FPAR
          2060 !TSM:FPAR:NO REPLY
          2062 TSM:FPAR
          2099 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          4108 !TSM:FPAR:NO REPLY
          4110 TSM:FPAR
          4147 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          6156 !TSM:FPAR:NO REPLY
          6158 TSM:FPAR
          6195 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          8204 !TSM:FPAR:FAIL
          8206 TSM:FAIL:CNT=1
          8208 TSM:FAIL:PDT
          18212 TSM:FAIL:RE-INIT
          18214 TSM:INIT
          18221 TSM:INIT:TSP OK
          18225 TSF:SID:OK,ID=2
          18227 TSM:FPAR
          18264 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          20273 !TSM:FPAR:NO REPLY
          20275 TSM:FPAR
          20312 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          22321 !TSM:FPAR:NO REPLY
          22323 TSM:FPAR
          22360 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          24369 !TSM:FPAR:NO REPLY
          24371 TSM:FPAR
          24408 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          26417 !TSM:FPAR:FAIL
          26419 TSM:FAIL:CNT=2
          26421 TSM:FAIL:PDT
          36425 TSM:FAIL:RE-INIT```
            TigroenotT Offline
            Tigroenot
            Please, explain it to me, shouldn't the node find another parent if the repeater is offline? Shouldn't the gateway reply to FPAR request? The range is really not the issue because I've got a PA+LNA nrf module on the gateway, and it is 4 meters away from the node 2.
            Maybe I should move to the stable branch? :)
              sundberg84S Offline
              sundberg84S Offline
              @Tigroenot said in Node doesn't work without repeater:
              It should - and I think the limit (was before atleast) is 6 failed messages and the it should search a new way/route.
              It looks like it does try to find a new way (2-2-255 instead of 2-2-10) but doesnt get a reply. Maybe the routing table in the GW still is going trhough the repeater?
              TigroenotT 1 Reply Last reply
                TigroenotT Offline
                TigroenotT Offline
                Tigroenot
                @sundberg84 said in Node doesn't work without repeater:
                The repeater is fisically off. I can see the routing table through the MYSController. Tried to clear it - doesn't seem to work.
                Here is another attempt. I downloaded the latest stable 2.1.1 and here is the output:
                4 TSM:INIT
                4 TSF:WUR:MS=0
                12 TSM:INIT:TSP OK
                14 TSF:SID:OK,ID=2
                16 TSM:FPAR
                16 TSM:FPAR:STATP=0
                18 TSM:ID
                20 TSM:ID:OK
                20 TSM:UPL
                59 !TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                2066 TSM:UPL
                2103 !TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                4112 TSM:UPL
                4149 !TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                6158 TSM:UPL
                6195 !TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                8204 !TSM:UPL:FAIL
                475289 TSM:FPAR
                475291 TSM:FPAR:STATP=0
                475293 TSM:ID
                475295 TSM:ID:OK
                475297 TSM:UPL
                475334 !TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                475770 TSF:MSG:READ,12-12-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                475779 TSF:MSG:BC
                477343 TSM:UPL
                477380 !TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                477872 TSF:MSG:READ,12-12-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                477878 TSF:MSG:BC
                479389 TSM:UPL
                479426 !TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                479977 TSF:MSG:READ,12-12-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                479983 TSF:MSG:BC
                481435 TSM:UPL
                481472 !TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                483481 !TSM:UPL:FAIL```
                  TigroenotT Offline
                  Tigroenot
                    If you bring the node closer to the gateway? Maybe it is not able to reach it without the repeater
                      sundberg84S Offline
                      sundberg84S Offline
                      @Tigroenot it looks like you have alot of :NACK which means you have a range problem (or power) and the node with ID 2 does not get a reply (ack) from the GW. Still my last question - even if you clear the routing table/eeprom in the node it might that it takes a while for th gw to update its routing table? Im not sure how this works "behind the scenes" since im not of a coding guy,
                        TigroenotT Offline
                        Tigroenot
                        The range is not the issue because I tried to move it closer to the gateway, but untill I power on the repeater node it didn't work.
                        I sent C_INTERNAL, I_DEBUG, E to node 10, is has reset it's ID and became no 11, and after that nodes 2 and 12 starter to work through node 11. Damn it. I reset the ID of node 2, it became node 8 and continued to work through node 11. Sh*t!
                        Now I've got two nodes that just want that bloody repeater node 11 and don't want to deal with the filthy gateway :)
                          Did you restarted the gateway so that all nodes presented again? It is actually kind of weird since quite some people had issues about the nodes trying to connect to low signal gateway even if repeater had better signal.
                            TigroenotT Offline
                            TigroenotT Offline
                            Tigroenot
                            @gohan said in Node doesn't work without repeater:
                            Not only have I restarted the gateway, I have reinstalled it, now it's latest development branch.
                            Now I have built one more node, burned the same 1.3 MYSBootloader, and it doesn't show up on the network at all. Static parent ID and set node ID don't do a thing.
                            314689 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            316700 !TSM:FPAR:NO REPLY
                            316702 TSM:FPAR
                            The gateway works normally, it gets the data from similar nodes that are further that this new one... I'm very confused...
                            Maybe it's somethig to do with the nrf chanels? MYSBootloader? All my nodes are the same...
                              NRF channels can be manually defined if you want to try (default channel is something like 76, I set it to 10 to move it away from wifi frequencies), but if you change the values in the MyConfig.h file you will get the same settings an all builds (just remember it will get overwritten if you up\downgrade the library. I am taking for granted you have capacitors on the radio vcc, right? Did you try to swap radios around, just to see if anything happens?
                                TigroenotT Offline
                                Tigroenot
                                Well, what I did is swaped the radio on the gateway, added capacitors (10-200uf), swaped the nrf chip on the nodes (nrf+ and nrf), added 1M resistor to the node for radio back compatibility, moved nodes closer to the gateway and further from it, flashed the repeater node (now it's node 10 again) with repeater function disabled.
                                In the end, I've got three new nodes that talk to controller ONLY through repeater node (the repeater node is further from the gateway then the new nodes). Clearing the routing table on the repeater node doesn't help, erasing eeprom of the repeater node makes it change the node ID and after restarting the other nodes they bind to the repeater again.
                                Strange thing is that the node 10 is with MYSBootloader (which has nrf chanel 76 set) and it talks straight to the gateway. The nodes (8,12,13) have the same bootloader and nrf chanel set to 76 and are not recognised by the gateway as soon as there is no repeater node 10.
                                  I am out of options.... I am calling for @hek help :D
                                  • hekH Offline
                                    hekH Offline
                                    Try setting
                                    on the gateway
                                    The gateway might be SCREAMING so high that the node doesn't pick up the answer.
                                    11.9k
                                    113.3k
