  3. 💬 Button size radionode with sensors swarm extension
atsha204aflashhumidityrf69lightuv lightbatterymysensortemperatureota
189 Posts 28 Posters 75.4k Views 25 Watching
    was it possible to buy this board assembled from you?
    KoreshK
    KoreshK
    Koresh
    @Cliff-Karlsson The local factory starts assembly today (button size node, insertable switch node, wall socket insertable node and mini relay box). ETA is one-two week (max).
    This board is avaliable with two radios - rfm69hw and rfm69cw (with adapter shown below). Price will be the same. Which radio is preferred for you? If you plan to use this board with battery I suggest to use rfm69cw module to extend battery life (it has lower but enouogh power and works down to ~2V).
    Miroslav KadaněM 1 Reply Last reply
    • Cliff KarlssonC
      Cliff KarlssonC
      Cliff Karlsson
      @Koresh said in 💬 Button size radionode with sensors swarm extension:
      rfm69cw
      yes rfm69cw is fine, as I understand it will still be compatible with rfm69(H)W gateway?. Also are you using 868 MHz band or any other?
      I don't remember where I read the prices, could you give them again? And can you buy the atmega/rfm -board separate from the sensorboard or do I have to buy them as a set?
        Will it be available preassembled? :)
        KoreshK 1 Reply Last reply
          KoreshK
          KoreshK
          Koresh
          @gohan Yes. Of course :smile:
          • KoreshK
            KoreshK
            Koresh
            Unfortunately I can't open my ebay shop right now. While I'm trying to open it, you can buy this board here: https://www.ebid.net/eu/for-sale/arduino-ide-compatible-coincell-powered-controller-rfm69cw-hcw-433-mhz-radio-156694991.htm
              Best of luck for your shop :+1:
              • bjornhallbergB
                bjornhallbergB
                bjornhallberg
                wrote on last edited by bjornhallberg
                #29
                Great! One question though, is everything already soldered and if so is there an option to for 868MHz?
                gohanG 1 Reply Last reply
                  @bjornhallberg if you want you can just order pcb and build your own node
                    bjornhallbergB
                    bjornhallbergB
                    bjornhallberg
                    @gohan Yeah I could but I'm just too lazy :-) There are a lot of components to source from AliExpress before anyone can build these boards. It would take months even if there aren't any errors in the BOM or lost packages from China.
                      @bjornhallberg since @Koresh is still in the early production stage, I think he can manage to make a few with a different radio, given of course he has the 866 mhz modules available 😁
                        bjornhallbergB
                        bjornhallbergB
                        bjornhallberg
                        #33
                        @gohan Thankfully I do have some CW 868 radios (~5 left) available that I bought ahead of time. I think everyone can solder the radio to the board by hand and so I personally would prefer that @Koresh would consider selling the parts separately.
                        • Cliff KarlssonC
                          Cliff KarlssonC
                          Cliff Karlsson
                          If possible I would also like the option to chose 868 Mhz or be able to buy board without radio.
                            KoreshK
                            KoreshK
                            Koresh
                            @Cliff-Karlsson
                            @bjornhallberg
                            I have some assembled boards without the radio. You can buy them here https://www.ebid.net/eu/for-sale/arduino-ide-compatible-coincell-powered-controller-ready-for-rfm69cw-hcw-radio-156711327.htm . I just reminding this board has a rfm69HCW footprint but you can solder rfm69CW modules with the pcb adapter which I made. Of course I will supply the adapter with the main board.
                            • KoreshK Koresh
                              @Cliff-Karlsson
                              @bjornhallberg
                              bjornhallbergB
                              bjornhallbergB
                              bjornhallberg
                              @Koresh Thanks! Great solution with the adapter board as well, you really do think of everything. Do you have the other boards without radio as well? Specifically the Switch Controller?
                                KoreshK
                                KoreshK
                                Koresh
                                @bjornhallberg
                                I have some insertable switch boards without radio. I planned to solder nrf24 into them but can sell them without radio too (it supports only cw modules). Will put up for sale soon.
                                • KoreshK Koresh
                                  @bjornhallberg
                                  bjornhallbergB
                                  bjornhallbergB
                                  bjornhallberg
                                  @Koresh Sounds great! Oh and btw, any idea how customs will handle the packages, any chance of taxes and customs fees? You're outside of the EU customs union right?
                                    KoreshK
                                    KoreshK
                                    Koresh
                                    wrote on last edited by Koresh
                                    #39
                                    @bjornhallberg I do not know exactly, but I don't think there should be any fees. Try to find out tomorrow.
                                    • alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @Koresh I got one of boards and would like to add Si1132-A10-GMR. What else I need to add? C8?
                                      Why are you not using this sensor on your board?
                                      • alexsh1A alexsh1
                                        KoreshK
                                        KoreshK
                                        Koresh
                                        @alexsh1 yes, you should solder the sensor and the bypass capacitor. I have a lot of si1132 sensors, but I can't find the correct library. Almost promo videos of commertial sensors based on the si1132 shows incorrect data ))) It shows correct UV and IR level, but incorrect visible light value. So I decided to not solder this sensor yet.
                                        alexsh1A 1 Reply Last reply
                                        • alexsh1A
                                          alexsh1A
                                          alexsh1
                                          #42
                                          @Koresh I would only use it for UV so this is good for me.
                                          No need to use a lib:
                                          // Distributed with a free-will license.
                                          // Use it any way you want, profit or free, provided it fits in the licenses of its associated works.
                                          // SI1132
                                          // This code is designed to work with the SI1132_I2CS I2C Mini Module available from ControlEverything.com.
                                          // https://www.controleverything.com/content/Light?sku=SI1132_I2CS#tabs-0-product_tabset-2
                                          #include<Wire.h>
                                          // SI1132 I2C address is 0x60(96)
                                          #define Addr 0x60
                                          int response = 0;
                                            // Initialise I2C communication as MASTER
                                            Wire.begin();
                                            // Initialise Serial Communication, Baud rate = 9600
                                            Serial.begin(9600);
                                            // Enable UVindex measurement coefficients
                                            // Start I2C Transmission
                                            Wire.beginTransmission(Addr);
                                            // Select COFF-1 register
                                            Wire.write(0x13);
                                            // Default value
                                            Wire.write(0x29);
                                            // Stop I2C Transmission
                                            Wire.endTransmission();
                                            // Select COFF-2 register
                                            Wire.write(0x14);
                                            // Default value
                                            Wire.write(0x89);
                                            // Select COFF-3 register
                                            Wire.write(0x15);
                                            // Default value
                                            Wire.write(0x02);
                                            // Select COFF-4 register
                                            Wire.write(0x16);
                                            // Default value
                                            Wire.write(0x00);
                                            // Select PARAM_WR register
                                            Wire.write(0x17);
                                            // Enable uv, Visible, IR
                                            Wire.write(0xF0);
                                            // Select command register
                                            Wire.write(0x18);
                                            // Select CHLIST register in RAM
                                            Wire.write(0x01 | 0xA0);
                                            delay(10);
                                            // Select PARAM_RD register
                                            Wire.write(0x2E);
                                            // Request 1 byte of data
                                            Wire.requestFrom(Addr, 1);
                                            // Read 1 byte of data
                                            response = Wire.read();
                                            // Select HW_KEY register
                                            Wire.write(0x07);
                                            // Default value
                                            Wire.write(0x17);
                                            Wire.write(0x17);
                                            // Small IR photodiode
                                            Wire.write(0x00);
                                            // Select COMMAND register
                                            Wire.write(0x18);
                                            // Select ALS_IR_ADCMUX register in RAM
                                            Wire.write(0x0E | 0xA0);
                                            delay(10);
                                            Wire.write(0x2E);
                                            Wire.write(0x17);
                                            // Set ADC Clock divided / 1
                                            Wire.write(0x00);
                                            Wire.write(0x18);
                                            // Select ALS_IR_ADC_GAIN register in RAM
                                            Wire.write(0x1E | 0xA0);
                                            delay(10);
                                            Wire.write(0x2E);
                                            Wire.write(0x17);
                                            // Set 511 ADC Clock
                                            Wire.write(0x70);
                                            Wire.write(0x18);
                                            // Select ALS_IR_ADC_COUNTER register in RAM
                                            Wire.write(0x1D | 0xA0);
                                            delay(10);
                                            Wire.write(0x2E);
                                            Wire.write(0x17);
                                            Wire.write(0x00);
                                            Wire.write(0x18);
                                           // Select ALS_VIS_ADC_GAIN register in RAM
                                            Wire.write(0x11 | 0xA0);
                                            delay(10);
                                            Wire.write(0x2E);
                                            Wire.write(0x17);
                                            // High Signal Range
                                            Wire.write(0x20);
                                            Wire.write(0x18);
                                            // Select ALS_IR_ADC_MISC register in RAM
                                            Wire.write(0x1F | 0xA0);
                                            delay(10);
                                            Wire.write(0x2E);
                                            Wire.write(0x17);
                                            Wire.write(0x70);
                                            Wire.write(0x18);
                                            // Select ALS_VIS_ADC_COUNTER register in RAM
                                            Wire.write(0x10 | 0xA0);
                                            delay(10);
                                            Wire.write(0x2E);
                                            Wire.write(0x17);
                                            Wire.write(0x20);
                                            Wire.write(0x18);
                                            // Select ALS_VIS_ADC_MISC register in RAM
                                            Wire.write(0x12 | 0xA0);
                                            delay(10);
                                            Wire.write(0x2E);
                                            delay(300);
                                            unsigned int data[4];
                                            Wire.write(0x18);
                                            // Start ALS conversion
                                            Wire.write(0x0E);
                                            delay(500);
                                            // Select data register
                                            Wire.write(0x22);
                                            // Request 4 byte of data
                                            Wire.requestFrom(Addr, 4);
                                            // Read 4 bytes of data
                                            // visible lsb, visible msb, ir lsb, ir msb
                                            if (Wire.available() == 4)
                                              data[0] = Wire.read();
                                              data[1] = Wire.read();
                                              data[2] = Wire.read();
                                              data[3] = Wire.read();
                                            float visible = (data[1] * 256.0 + data[0]);
                                            float ir = (data[3] * 256 + data[2]);
                                            Wire.write(0x2C);
                                            // Request 2 bytes of data
                                            Wire.requestFrom(Addr, 2);
                                            // Read 2 bytes of data
                                            // uv lsb, uv msb
                                            if (Wire.available() == 2)
                                            // Convert the data
                                            float uv = (data[1] * 256 + data[0]);
                                            // Output data to screen
                                            Serial.print("Visible Light of Source : ");
                                            Serial.print(visible);
                                            Serial.println(" lux");
                                            Serial.print("IR Of Source : ");
                                            Serial.print(ir);
                                            Serial.print("UV Of the Source : ");
                                            Serial.print(uv);
                                            delay(500);
