  3. 💬 Button size radionode with sensors swarm extension
atsha204aflashhumidityrf69lightuv lightbatterymysensortemperatureota
189 Posts 28 Posters 75.4k Views 25 Watching
  • AnticimexA Anticimex
    Aah, ok then :) I have given up on trying to keep track of all the boards now so I won't dispute your claim. But @scalz also rock some awesome small ones. But it is open source hardware. Everybody can share and pick the aspects of the various boards they like the most.
    Do you have a link to where the radio can be sourced and some reference to footprint specifications?
    KoreshK
    KoreshK
    Koresh
    wrote on last edited by Koresh
    It is not a dispute, I hope :) It was sarcasm. When I designed previous board I really needed relatively small universal board with rfm69...
    Can you a little clarify what do you mean? Schamatic of rfm69 module?
    AnticimexA 1 Reply Last reply
    • KoreshK Koresh
      AnticimexA
      AnticimexA
      Anticimex
      I mean a link to where the module can be bought, and a link to some datasheet or similar, where the specification for the module footprint is so that it can be possible to make footprint in open source cad tools like kicad. Your design files looks like Altium.
      Of course you are welcome to contribute a footprint to the MySensors kicad repositories on github :)
      KoreshK 1 Reply Last reply
        KoreshK
        KoreshK
        Koresh
        Thanks! Clear now :) I will try convert all sourses to open formats and add more information to projects (documentation, design notes and components information) asap.
          @Koresh
          hihihi, me too, was for fun, i knew it was about the node! like i said, i like your boards but i do mine. i was saying this because i've improved my previous multisensors design, for smaller and cheaper. but i've quitted 8bits 328 serie..for my others projects too.
          Keep the good work.
          • scalzS scalz
            @Koresh
            Keep the good work.
            @scalz said:
            @Koresh
            What did you switch to?
            • KoreshK Koresh
              @Nca78 said:
              Really a nice sensor !
              What software design file are these ?
              Do not worry, I will share software source code.
              @scalz
              It was about original board (21x21mm) :smirk:
              Thank you but I was just asking for the name of the design software to have a closer look at the board. Altium it seems so I can't have a look at your routing :(
              Was curious to see the details closer as you seem to squeeze 2 routes through the corner of the atmega, I can't do that with my current settings.
              • Nca78N Nca78
                KoreshK
                KoreshK
                Koresh
                This board was routed according 5mil width/5mil clearance rules.
                • GertSandersG
                  GertSandersG
                  GertSanders
                  Always impressed by the quality of your designs @koresh !
                  • O
                    O
                    Omemanti
                    Hey, looks great!
                    is it possible tot get some Eagle files?
                    Thnx!
                    • Cliff KarlssonC
                      Cliff KarlssonC
                      Cliff Karlsson
                      was it possible to buy this board assembled from you?
                        KoreshK
                        KoreshK
                        Koresh
                        @Cliff-Karlsson The local factory starts assembly today (button size node, insertable switch node, wall socket insertable node and mini relay box). ETA is one-two week (max).
                        This board is avaliable with two radios - rfm69hw and rfm69cw (with adapter shown below). Price will be the same. Which radio is preferred for you? If you plan to use this board with battery I suggest to use rfm69cw module to extend battery life (it has lower but enouogh power and works down to ~2V).
                        Miroslav KadaněM 1 Reply Last reply
                        • Cliff KarlssonC
                          Cliff KarlssonC
                          Cliff Karlsson
                          @Koresh said in 💬 Button size radionode with sensors swarm extension:
                          rfm69cw
                          yes rfm69cw is fine, as I understand it will still be compatible with rfm69(H)W gateway?. Also are you using 868 MHz band or any other?
                          I don't remember where I read the prices, could you give them again? And can you buy the atmega/rfm -board separate from the sensorboard or do I have to buy them as a set?
                            Will it be available preassembled? :)
                              KoreshK
                              KoreshK
                              Koresh
                              @gohan Yes. Of course :smile:
                              • KoreshK
                                KoreshK
                                Koresh
                                Unfortunately I can't open my ebay shop right now. While I'm trying to open it, you can buy this board here: https://www.ebid.net/eu/for-sale/arduino-ide-compatible-coincell-powered-controller-rfm69cw-hcw-433-mhz-radio-156694991.htm
                                  Best of luck for your shop :+1:
                                  • bjornhallbergB
                                    bjornhallbergB
                                    bjornhallberg
                                    wrote on last edited by bjornhallberg
                                    #29
                                    Great! One question though, is everything already soldered and if so is there an option to for 868MHz?
                                    gohanG 1 Reply Last reply
                                      @bjornhallberg if you want you can just order pcb and build your own node
                                        bjornhallbergB
                                        bjornhallbergB
                                        bjornhallberg
                                        @gohan Yeah I could but I'm just too lazy :-) There are a lot of components to source from AliExpress before anyone can build these boards. It would take months even if there aren't any errors in the BOM or lost packages from China.
                                          @bjornhallberg since @Koresh is still in the early production stage, I think he can manage to make a few with a different radio, given of course he has the 866 mhz modules available 😁
