  3. PIR am312
PIR am312
96 Posts 13 Posters 76.1k Views 10 Watching
  • sundberg84S sundberg84
    @AWI - Could you see what happened below 3.3v? Ie, using 2xAA ?
    AWIA
    AWIA
    AWI
    @sundberg84 I turned the voltage down to 2.6V and it was still fully functional. Did not test noise sensitivity (disassembled the test set-up) The sensor is specified to 2.7V, the LDO (HT-7530) has a typical voltage drop of 100mV in normal operation.
    Seems to be very small (< 5mV) when Vin is below 3V.
    Conclusion: looks good for 2AA alkaline.:ribbon:
    • AWIA AWI
      @NeverDie It looks like its in specification. My "lab" is not that big... I could easily detect around 5 meters through the open door ;-)
      @AWI said in PIR am312:
      FWIW, when I click on your specification link, all I get is "Access Denied". Is it just me, or can anyone else here click through to it?
      AWIA K 2 Replies Last reply
        AWIA
        AWIA
        AWI
        @NeverDie The "specification" is a link back into this forum (https://forum.mysensors.org/topic/6658/pir-sensors/18) so you should be able to access it...
          K
          K
          kontrollable
          @NeverDie Same here, access denied!
            @hek Seems there's a problem: a simple link back to forum is resulting in "Access Denied." Can you fix it?
              You are linking to thread in the moderators private area.
              AWIA 1 Reply Last reply
                AWIA
                AWIA
                AWI
                wrote on last edited by AWI
                @hek @NeverDie @kontrollable My stupid mistake... :blush: I was referring to this from the datasheet Pir-AS312
                  but also it depends on the lens right?
                    Unfortunately, the link you posted (https://forum.mysensors.org/assets/uploads/files/1493990586841-pir-as312.pdf) reports file not found.
                    Since links aren't working, can someone upload the pdf of the datasheet to this thread as a file attachment?
                    [Edit: That's funny: After I posted the link, now when I click on it I'm now granted access! So, I'll attach it to this post now that I finally have it.]0_1494013513879_1493990586841-pir-as312.pdf
                    Hopefully others can now access the re-uploaded version.
                      For Halloween, it would be pretty amusing to have the PIR turn on some eyeballs like this:
                      https://cdn-shop.adafruit.com/product-videos/1200x900/3356-05.mp4
                      especially if you had about 6 of them scattered about.
                      • Nca78N
                        Missed this thread last week...
                        Just tested mine today with 3.3V supply and I have similar current consumption, around 15µA on my multimeter but the full board in sleep mode. It's staying active as long as there's movement detected, and seems stable: no interference from NRF24 radio when sending updated state to gateway.
                        But I have poor range, I'm not sure why, maybe the orientation of sensor/lens, or maybe the hot temperature, over 30°C, I will do more tests tomorrow if I can.
                        I tested with a not very well aligned fresnel lens from a SR501 I can detect at over 4m
                        I've got some AM612 too, with extra setting for active duration & sensibility, and an OEN pin to enable output based on analog signal (on datasheet example they use it with a photoresistor). If I believe the very similar detection profiles in the datasheets it's the same sensor but the AS312 has settings hardwired in the "can".
                        Not sure if 2 AA/AAA is the best solution, I would go for lithium cells. CR2032 would probably have too short battery life in a busy room (somewhere around 6 months) but bigger cells like 2477 or CR123 (>1000mAh) would last way over 1 year. Compared to AA they have the big advantage of staying over the 2.7V minimum value in the datasheet for most of their life.
                        gohanG NeverDieN 2 Replies Last reply
                        • Nca78N Nca78
                          @Nca78 do you have any updates on the sensor?
                          Nca78N 1 Reply Last reply
                          • Nca78N Nca78
                            @Nca78 said in PIR am312:
                            In most cases I'm planning to use solar and a supercap. Then, no more batteries to change!
                              it is all a matter of node size and if you like to have solar panels around the house (never forget the WAF :D )
                                @gohan said in PIR am312:
                                Good point. Even a micro panel might be stretching it on the WAF.
                                  @gohan I didn't test more but I made a PCB for AM612 it will be much more convenient to make some real life testing :)
                                  Sending it tomorrow to PCB production with 11 other PCBs :D
                                    How are you using the AM612?
                                      I don't understand what answer you're expecting for this question :)
                                      I made a PCB, send it to PCB production and when I receive it I will be able to solder the am612 on it and test it.
                                        how about the lens? Did you make a case for it?
                                          I will test using lens from AM312 & from SR501 (made the space and holes for that on the PCB). I have ordered some other ones from AliExpress, too.
                                          No case yet as I just spent a lot of nearly sleepless nights finishing a lot of PCBs. Now time for code preparation before I receive the boards, then 3D design and tests while the 3D printer is printing :)
