  3. PIR am312
PIR am312
96 Posts 13 Posters 76.1k Views 10 Watching
  • AWIA AWI
    @NeverDie It looks like its in specification. My "lab" is not that big... I could easily detect around 5 meters through the open door ;-)
    @AWI said in PIR am312:
    FWIW, when I click on your specification link, all I get is "Access Denied". Is it just me, or can anyone else here click through to it?
    AWIA K 2 Replies Last reply
      AWIA
      AWIA
      AWI
      @NeverDie The "specification" is a link back into this forum (https://forum.mysensors.org/topic/6658/pir-sensors/18) so you should be able to access it...
        K
        K
        kontrollable
        @NeverDie Same here, access denied!
          @hek Seems there's a problem: a simple link back to forum is resulting in "Access Denied." Can you fix it?
            You are linking to thread in the moderators private area.
            AWIA 1 Reply Last reply
              AWIA
              AWIA
              AWI
              wrote on last edited by AWI
              @hek @NeverDie @kontrollable My stupid mistake... :blush: I was referring to this from the datasheet Pir-AS312
                but also it depends on the lens right?
                  Unfortunately, the link you posted (https://forum.mysensors.org/assets/uploads/files/1493990586841-pir-as312.pdf) reports file not found.
                  Since links aren't working, can someone upload the pdf of the datasheet to this thread as a file attachment?
                  [Edit: That's funny: After I posted the link, now when I click on it I'm now granted access! So, I'll attach it to this post now that I finally have it.]0_1494013513879_1493990586841-pir-as312.pdf
                  Hopefully others can now access the re-uploaded version.
                    For Halloween, it would be pretty amusing to have the PIR turn on some eyeballs like this:
                    https://cdn-shop.adafruit.com/product-videos/1200x900/3356-05.mp4
                    especially if you had about 6 of them scattered about.
                    • Nca78N
                      Missed this thread last week...
                      Just tested mine today with 3.3V supply and I have similar current consumption, around 15µA on my multimeter but the full board in sleep mode. It's staying active as long as there's movement detected, and seems stable: no interference from NRF24 radio when sending updated state to gateway.
                      But I have poor range, I'm not sure why, maybe the orientation of sensor/lens, or maybe the hot temperature, over 30°C, I will do more tests tomorrow if I can.
                      I tested with a not very well aligned fresnel lens from a SR501 I can detect at over 4m
                      I've got some AM612 too, with extra setting for active duration & sensibility, and an OEN pin to enable output based on analog signal (on datasheet example they use it with a photoresistor). If I believe the very similar detection profiles in the datasheets it's the same sensor but the AS312 has settings hardwired in the "can".
                      Not sure if 2 AA/AAA is the best solution, I would go for lithium cells. CR2032 would probably have too short battery life in a busy room (somewhere around 6 months) but bigger cells like 2477 or CR123 (>1000mAh) would last way over 1 year. Compared to AA they have the big advantage of staying over the 2.7V minimum value in the datasheet for most of their life.
                      gohanG NeverDieN 2 Replies Last reply
                      • Nca78N Nca78
                        @Nca78 do you have any updates on the sensor?
                        Nca78N 1 Reply Last reply
                        • Nca78N Nca78
                          @Nca78 said in PIR am312:
                          In most cases I'm planning to use solar and a supercap. Then, no more batteries to change!
                            it is all a matter of node size and if you like to have solar panels around the house (never forget the WAF :D )
                              @gohan said in PIR am312:
                              Good point. Even a micro panel might be stretching it on the WAF.
                                @gohan I didn't test more but I made a PCB for AM612 it will be much more convenient to make some real life testing :)
                                Sending it tomorrow to PCB production with 11 other PCBs :D
                                  How are you using the AM612?
                                    I don't understand what answer you're expecting for this question :)
                                    I made a PCB, send it to PCB production and when I receive it I will be able to solder the am612 on it and test it.
                                      how about the lens? Did you make a case for it?
                                        I will test using lens from AM312 & from SR501 (made the space and holes for that on the PCB). I have ordered some other ones from AliExpress, too.
                                        No case yet as I just spent a lot of nearly sleepless nights finishing a lot of PCBs. Now time for code preparation before I receive the boards, then 3D design and tests while the 3D printer is printing :)
                                        • Nca78N Nca78
                                          #31
                                          @Nca78
                                          I really like your PCB layouts. Is that Eagle, or some other package that you're using? I'm using Diptrace, which meets my needs and was easy to learn, but your package looks like it's more polished and easier to see both sides of the board at the same time.
