  3. PIR am312
PIR am312
96 Posts 13 Posters 73.1k Views 10 Watching
  • D Offline
    Dwalt
    Does anyone have any experience with this sensor?
    I exhausted my stock of panasonic PIRs and was looking for a replacement which was low powered and self contained (all components within the can) similar to the panasonics and ran across the am/hm PIR series from Senba Optics. The am312 is the only one I have seen in the wild - $13 on aliexpress but ~$2 from Banggood. I cannot find a non-chinese datasheet anywhere but some wholesalers have listed specs which look promising, specifically detection range and current.
    Any thoughts?
    T N 2 Replies Last reply
    • D Dwalt
      Any thoughts?
      T Offline
      T Offline
      TheoL
      @Dwalt if I understand it correctly, it monitors motion actively? So that it keeps the pin high as long as it keeps detecting motion?
      Keep me informed, please. That way I can remove that part from my nodes.
      • D Dwalt
        Any thoughts?
        N Offline
        N Offline
        @Dwalt
        Did you ever find anything out regarding its true current consumption?
        • A Offline
          A Offline
          acp
          Sorry to bump this old Thread.
          But i thought i give some Info in case anyone stumbles on it via searching am312+mysensors like i did some Weeks ago.
          I used the banggood Module for a Battery Powerd Node.
          At first it was running from 3xAAA Alkaline Batteries.
          But after a Week Batteries where emtpy.
          So i had a detailed look at the Node.
          The PIR Module has a 3V regulator on Board, which seems to be designed for 5V input.
          The Batteries only provided ~3,9V wich resulted in ~1,4V behind the regulator, but the Module was working properly.
          So i decided to remove the regulator from the PIR Module and power it from 2 AAA Batteries (providing ~2,4V input).
          Additionally i removed another 3,3V regulator i was using for the nrf24l01 Radio.
          Now the Power consumption is down to ~0,2 mA while sleeping (ATMega328+NRF24l01+Pir Module) and ~15mA when awake.
          Running without Problems since 2 Days.
          A 1 Reply Last reply
          • A acp
            A Offline
            A Offline
            AWI
            wrote on last edited by AWI
            I just received my samples of the AM312 and ( @gohan as promised) my observations/ measurements. (which are not in line with @acp observations above)
            1. Rock stable. Even if I use the on-board regulator to also power a MySensors node it does not get into trouble (fires only when supposed to)
            2. The hold-time is as specified in the datasheet 2.3 seconds
            3. Power consumption: 14.2 µA! when idle 15.4 µA when active.
            4. These boards can handle anywhere between 3.3 and 12 V power (ldo on-board).
            5. I won't be using any of the small or modified HC-SR501 or similar BISS0001 based sensors anymore. These typically have 4 times higher power consumption/ very sensitive to all kinds of power and environment noise/ large/ but adjustable (can live with that and handle in software).
            0_1493902794635_upload-93dc9758-648f-4ba2-a14c-5c2f95666b5d
            S 1 Reply Last reply
            • N Offline
              N Offline
              @AWI
              Thanks for your post! What type of detection range are you getting out of it? i.e. within what range can you reliably detect motion?
              • A AWI
                @AWI - Could you see what happened below 3.3v? Ie, using 2xAA ?
                  I can't wait to get my pir sensors 😀
                  • N Offline
                    N Offline
                    Me too. Based on AWI's report above, I just went ahead and ordered them.
                    N 1 Reply Last reply
                    • N NeverDie
                      @AWI
                      A Offline
                      A Offline
                      AWI
                      @NeverDie It looks like its in specification. My "lab" is not that big... I could easily detect around 5 meters through the open door ;-)
                      • S sundberg84
                        A Offline
                        A Offline
                        AWI
                        @sundberg84 I turned the voltage down to 2.6V and it was still fully functional. Did not test noise sensitivity (disassembled the test set-up) The sensor is specified to 2.7V, the LDO (HT-7530) has a typical voltage drop of 100mV in normal operation.
                        Seems to be very small (< 5mV) when Vin is below 3V.
                        Conclusion: looks good for 2AA alkaline.:ribbon:
                        • A AWI
                          N Offline
                          N Offline
                          @AWI said in PIR am312:
                          FWIW, when I click on your specification link, all I get is "Access Denied". Is it just me, or can anyone else here click through to it?
                          A K 2 Replies Last reply
                          • N NeverDie
                            A Offline
                            A Offline
                            AWI
                            @NeverDie The "specification" is a link back into this forum (https://forum.mysensors.org/topic/6658/pir-sensors/18) so you should be able to access it...
                            • N NeverDie
                              K Offline
                              K Offline
                              kontrollable
                              @NeverDie Same here, access denied!
                              • N Offline
                                N Offline
                                @hek Seems there's a problem: a simple link back to forum is resulting in "Access Denied." Can you fix it?
                                • hekH Offline
                                  hekH Offline
                                  You are linking to thread in the moderators private area.
                                    A Offline
                                    A Offline
                                    AWI
                                    @hek @NeverDie @kontrollable My stupid mistake... :blush: I was referring to this from the datasheet Pir-AS312
                                      but also it depends on the lens right?
                                      • N Offline
                                        N Offline
                                        Unfortunately, the link you posted (https://forum.mysensors.org/assets/uploads/files/1493990586841-pir-as312.pdf) reports file not found.
                                        Since links aren't working, can someone upload the pdf of the datasheet to this thread as a file attachment?
                                        [Edit: That's funny: After I posted the link, now when I click on it I'm now granted access! So, I'll attach it to this post now that I finally have it.]0_1494013513879_1493990586841-pir-as312.pdf
                                        Hopefully others can now access the re-uploaded version.
                                        • N Offline
                                          N Offline
                                          For Halloween, it would be pretty amusing to have the PIR turn on some eyeballs like this:
                                          https://cdn-shop.adafruit.com/product-videos/1200x900/3356-05.mp4
                                          especially if you had about 6 of them scattered about.
