  3. PIR am312
PIR am312
96 Posts 13 Posters 76.1k Views 10 Watching
    I can't wait to get my pir sensors 😀
      Me too. Based on AWI's report above, I just went ahead and ordered them.
        @AWI
        Thanks for your post! What type of detection range are you getting out of it? i.e. within what range can you reliably detect motion?
        AWIA
        AWIA
        AWI
        @NeverDie It looks like its in specification. My "lab" is not that big... I could easily detect around 5 meters through the open door ;-)
        • sundberg84S sundberg84
          @AWI - Could you see what happened below 3.3v? Ie, using 2xAA ?
          AWIA
          AWIA
          AWI
          @sundberg84 I turned the voltage down to 2.6V and it was still fully functional. Did not test noise sensitivity (disassembled the test set-up) The sensor is specified to 2.7V, the LDO (HT-7530) has a typical voltage drop of 100mV in normal operation.
          Seems to be very small (< 5mV) when Vin is below 3V.
          Conclusion: looks good for 2AA alkaline.:ribbon:
          • AWIA AWI
            @AWI said in PIR am312:
            FWIW, when I click on your specification link, all I get is "Access Denied". Is it just me, or can anyone else here click through to it?
            AWIA K 2 Replies Last reply
              AWIA
              AWIA
              AWI
              @NeverDie The "specification" is a link back into this forum (https://forum.mysensors.org/topic/6658/pir-sensors/18) so you should be able to access it...
                K
                K
                kontrollable
                @NeverDie Same here, access denied!
                  @hek Seems there's a problem: a simple link back to forum is resulting in "Access Denied." Can you fix it?
                    You are linking to thread in the moderators private area.
                    AWIA 1 Reply Last reply
                      AWIA
                      AWIA
                      AWI
                      wrote on last edited by AWI
                      @hek @NeverDie @kontrollable My stupid mistake... :blush: I was referring to this from the datasheet Pir-AS312
                        but also it depends on the lens right?
                          Unfortunately, the link you posted (https://forum.mysensors.org/assets/uploads/files/1493990586841-pir-as312.pdf) reports file not found.
                          Since links aren't working, can someone upload the pdf of the datasheet to this thread as a file attachment?
                          [Edit: That's funny: After I posted the link, now when I click on it I'm now granted access! So, I'll attach it to this post now that I finally have it.]0_1494013513879_1493990586841-pir-as312.pdf
                          Hopefully others can now access the re-uploaded version.
                            For Halloween, it would be pretty amusing to have the PIR turn on some eyeballs like this:
                            https://cdn-shop.adafruit.com/product-videos/1200x900/3356-05.mp4
                            especially if you had about 6 of them scattered about.
                            • Nca78N
                              Missed this thread last week...
                              Just tested mine today with 3.3V supply and I have similar current consumption, around 15µA on my multimeter but the full board in sleep mode. It's staying active as long as there's movement detected, and seems stable: no interference from NRF24 radio when sending updated state to gateway.
                              But I have poor range, I'm not sure why, maybe the orientation of sensor/lens, or maybe the hot temperature, over 30°C, I will do more tests tomorrow if I can.
                              I tested with a not very well aligned fresnel lens from a SR501 I can detect at over 4m
                              I've got some AM612 too, with extra setting for active duration & sensibility, and an OEN pin to enable output based on analog signal (on datasheet example they use it with a photoresistor). If I believe the very similar detection profiles in the datasheets it's the same sensor but the AS312 has settings hardwired in the "can".
                              Not sure if 2 AA/AAA is the best solution, I would go for lithium cells. CR2032 would probably have too short battery life in a busy room (somewhere around 6 months) but bigger cells like 2477 or CR123 (>1000mAh) would last way over 1 year. Compared to AA they have the big advantage of staying over the 2.7V minimum value in the datasheet for most of their life.
                              gohanG NeverDieN 2 Replies Last reply
                              • Nca78N Nca78
                                @Nca78 do you have any updates on the sensor?
                                Nca78N 1 Reply Last reply
                                • Nca78N Nca78
                                  @Nca78 said in PIR am312:
                                  In most cases I'm planning to use solar and a supercap. Then, no more batteries to change!
                                    it is all a matter of node size and if you like to have solar panels around the house (never forget the WAF :D )
                                      @gohan said in PIR am312:
                                      Good point. Even a micro panel might be stretching it on the WAF.
                                        @gohan I didn't test more but I made a PCB for AM612 it will be much more convenient to make some real life testing :)
                                        Sending it tomorrow to PCB production with 11 other PCBs :D
                                          How are you using the AM612?
