  3. NRF24L01+ genuine vs. counterfeit - checked some modules
36 Posts 10 Posters 17.3k Views 13 Watching
  • Nca78N Nca78
    @VaZso said in NRF24L01+ genuine vs. counterfeit - checked some modules:
    These are the modules I am speaking about: https://www.aliexpress.com/item/10-pcs-Free-Shipping-2-4GHz-NRF24l01-Wireless-Module-Mini-Version/32297159921.html
    Their pinout is the same as the pinout of RF24L01F20 - that module is only a little bit larger, but with PA and certs, so it has much better range and quality.
    I am using those, from another AliExpress supplier but looking exactly the same including markings on the "NRF24" counterfeit chip. And when in sleep mode (without watchdog times) my nodes (atmega + radio) seem to consume around 2µA so less than the 4uA you measured for radio only, I'm a bit surprised ? But maybe I'm tricked by my multimeter...
    V
    V
    VaZso
    @Nca78 I have measured less than 1μA for real modules and about 660μA for counterfeit ones.
    However, multimeter may also give invalid result...
    Nca78N 1 Reply Last reply
    • V VaZso
      @gohan They seem to be connected to GND.
      Range depends on the specific ennvironment (walls, used materials like metals, etc), the channel used (if there are other noises like WLAN and so), reflections and such things.
      You may also try better antennas or to reduce TX power to see if it runs better.
      @VaZso those modules comes with a 20cm long antenna, I don't have anything bigger than that.
      Anyway I'm looking for normal nrf24 modules to fit into smaller projects.
      V 1 Reply Last reply
        V
        V
        VaZso
        @gohan External size is one thing, internals are more important - there are better (properly tuned) antennas in small size.
        The RF24L01F20 module seems to be really good. Albeit it has PA, you may lowering the outside power a bit if necessary.
        NeverDieN gohanG 2 Replies Last reply
        • V VaZso
          @VaZso
          Have you considered using LoRa instead of the extra amplified NRF's?
            @VaZso
            V
            V
            VaZso
            @NeverDie No. I don't want to depend on other equipments and for better range, I may use other transmitters in the 866 / 433 MHz bands. However, in our projects, range was not really a limit, but sometimes delay had to be minimized.
            • V VaZso
              wrote on last edited by gohan
              #23
              @VaZso the problem is how to determine which antenna is better
              PS I checked the addition pins and they are indeed ground. I just wonder what is the need to have them there.
                @gohan said in NRF24L01+ genuine vs. counterfeit - checked some modules:
                Mechanical stability?
                  could be if you don't put the SMA connector through a hole in box it would be heavy on a pcb/pins with that big antenna.
                  • TmasterT
                    TmasterT
                    Tmaster
                    wrote on last edited by Tmaster
                    #26
                    i only saw this post today. So i dont have any nrf24 that have this square on top righ of the chip. all have a solid circle. that means they are fake right?
                    obvius i already expect that because they cost 80cents on ebay righ now.... ::blush:
                    i'm a arduino fan .Even sometimes don't undestanding how to use it :P
                    • V VaZso
                      That's huge, I'm running a few nodes with those modules on CR2025 and CR2032 they would die in 2 weeks with such a draw and obviously that's not the case. And I don't think a multimeter can be that far from reality ...
                        0_1496957462613_upload-f4a8ab02-3060-4c9c-a409-4c88eb4443c7
                        This a module I just got from Amazon produced by Sunfounder but it seems it has the same chip as the fake ones I got also from Amazon
                        0_1496957630016_upload-354ce8ee-9ba3-4769-a03b-2d6730656a43
                        The red one has actually a better range of about 3 meters more indoor but they cost 4.5€ each while the others cost 1.2€. I think I am going to return them and get some from Itead
                        • TmasterT Tmaster
                          V
                          V
                          VaZso
                          @Tmaster Not necessarily. Marking is one thing, Nordic may used both square and solid circle (as far as I know they used both).
                          However, for 80 cent, I assume they are fake for sure. :)
                          • Nca78N Nca78
                            V
                            V
                            VaZso
                            @Nca78 Yes, it is true - if 240 mAh is the battery capacity, it would last for ~15 days.
                            However, I have measured my modules uninitialized, so it may be better if one sends it to sleep mode by software... I have not measured them in other modes.
                            • V VaZso
                              Ah yes that's probably the reason, I will test before I connect them.
                              @gohan I thing your better range is due to the antenna design, same "style" than the one on "F" ESP8266 modules which also have a slightly better range.
                                @gohan
                                For better range, a lot of people seem to like this modification: http://www.instructables.com/id/Enhanced-NRF24L01/
                                gohanG 1 Reply Last reply
                                  manutremo
                                  I'm going to try these - they contain the signal amplifier but without the bulk of the sma connector and the external antenna.
                                  link text
                                    @gohan
                                    @NeverDie I tried that already and also the other mod with a single wire but nothing changed. The real improvement was when I used the PA lna on the gateway but still I only gained a few meters
                                    • M manutremo
                                      link text
                                      #35
                                      @manutremo
                                      At that price it seems you'd be better off with RFM69 or Ra-01 modules instead. It's a real puzzle to me as to why some people get great range from their NRF24L01's, and others do not. I never had much luck with it myself, whereas the RFM69's seem to just work. In the past the RFM's cost a lot more than they do now. On the other hand, the RFM's can be a lot more complex to program, and their wire antenna makes them less compact than the NRF24L01's.
                                      I do like that the Ra-01's appear to have passed FCC (assuming the stamp on their enclosure can be believed).
                                        manutremo
                                        Many thanks for your advice. For good or bad, reality is never black or white, but shades of grey. I already thought on switching to RFM69 or try the new LoRa but that would mean switching around 15 already functioning nodes, together with the associated cost. Out of those 15, the few showing problems to communicate with the gw are the furthest ones; those are where where I'm planning to give an oportunity to the new modules linked above. By the way, my gateway already has one PA+LNA module inside, but with an external whip antenna.
                                        I actually just installed the first one. I removed the "normal" nrf24 and switched by one of these in the most problematic node. Soldering the wiring into the 1.27mm holes was a challenge; some adapters that should make connection easier should be about to arrive but I was eager to run some tests. For the moment this module seems to have less problems to connect to the gateway - of course I won't be able to draw more final conclusions until it's been in use for some days, but for the moment it looks promising.
                                        Of course, should they finally not show a significant improvemen over the former modules, I'll consider testing some of the other options.
