  3. 💬 Button size radionode with sensors swarm extension
atsha204aflashhumidityrf69lightuv lightbatterymysensortemperatureota
189 Posts 28 Posters 76.6k Views 25 Watching
  • Y yury
    combined capacitance of booth should be 100 --200 microfarads . It is input capacitors.
    please try replacing them
    re:
    I was suspecting EEPROM (CS pin with pull-up resistor?) to be a culprit
    not pullups...
    alexsh1A
    alexsh1A
    alexsh1
    @yury what's your estimate of battery life based on a new consumption of about 25uA and the default sketch?
    Y 1 Reply Last reply
    • alexsh1A alexsh1
      Y
      Y
      yury
      @alexsh1 220 mAh(Duracell) / 0.025 (mA) = 8800 hrs = 366 days.
      alexsh1A 1 Reply Last reply
      • alexsh1A alexsh1
        @Koresh thanks. It does not matter which caps, right?
        I have a few 1206 100uF ceramic caps. They are not polarised and may be a good fit size wise
        KoreshK
        KoreshK
        Koresh
        @alexsh1 There is no problem to use your capacitors. 1206imp = 3216metric (type A) so they are fit perfect :+1:
        About consumption... This is quite universal board. If you plan to use CR2032 battery it can be worth to omit LDO. You can do it using existing 0603 jumper footprint near right storage capacitor.
        • Y yury
          alexsh1A
          alexsh1A
          alexsh1
          @yury said in 💬 Button size radionode with sensors swarm extension:
          Not exactly - 25uA is a sleeping current.
          There will be sending periods every 10 mins.
          So I suppose the lifetime is less than a year
          • KoreshK Koresh
            alexsh1A
            alexsh1A
            alexsh1
            @Koresh yes, I'm using it with the 2032 battery.
            Which pads to your refer to please?
            KoreshK 1 Reply Last reply
            • alexsh1A alexsh1
              Y
              Y
              yury
              @alexsh1
              @alexsh1 said in 💬 Button size radionode with sensors swarm extension:
              Yes, it is sleeping time estimate. When it wakes up it compares first, like : if ( abs(d) > 50 ) send(msg_vis.set(VIS_LIGHT), true); so it might send or not.
              But this is just example sketch and you are very welcome to create pull-request or make suggestion how to improve.
              alexsh1A 2 Replies Last reply
              • alexsh1A alexsh1
                KoreshK
                KoreshK
                Koresh
                wrote on last edited by Koresh
                #73
                @alexsh1 You can fit juper (or any small wire, R10 on the schematic) or remove LDO at all and short top two pads.
                • Y yury
                  @alexsh1
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @yury ok, you took the best case scenario (no messages as all) and if we take worst case scenario - sending every 10 mins in any case (suppose no if statement).
                  Then we take life time somewhere in between.
                  I think it make sense to take 18uA as a sleeping current removing the LDO from equation
                  • KoreshK Koresh
                    alexsh1A
                    alexsh1A
                    alexsh1
                    #75
                    @Koresh said in 💬 Button size radionode with sensors swarm extension:
                    More neat solution is to remove LDO and solder 0 ohm resistor (R10). Looks nice
                    Ok, 18uA - this is more like it.
                    Thank you very much for helping to get it sorted. Now I need to understand why the consumption has gone when using Si1132
                    @yury Did you test power consumption of modules with Si1132 please? I hope it was a bad soldering on my side
                    • Y yury
                      @alexsh1
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @yury I suggest we use this:
                      http://oregonembedded.com/batterycalc.htm
                      Based on non-LDO board consumption of 18uA the battery life assuming constant updates 10 mins and 140ms wake-up time (120ms is needed by bh1750) is 1.03 years. Excellent
                      • Y
                        Y
                        yury
                        Could not find good code to send it to sleep. without it Si1132 was eating a lot...
                        • Y yury
                          alexsh1A
                          alexsh1A
                          alexsh1
                          #78
                          @yury Hmmmm. Datasheet is stating that the standby current < 500 nA
                          However, actively measuring current - 4.5mA
                          This would kill 2032 very quickly
                          Nca78N 1 Reply Last reply
                          • KoreshK Koresh
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @Koresh another alternative would be using Si1145 it is pin-for-pin compatible with Si1132 and
                            This low-power sensing family enables long battery life with standby less than 500 nA and an average power of as little as 1.2 uA with once per second real-time UV Index measurements.
                            However, I still think that Si1132 can be working with the battery nicely. 0x18 register is a key:
                            The COMMAND Register is the primary mailbox register into the internal sequencer. Writing to the COMMAND register is the only I2C operation that wakes the device from standby mode.
                            The only question is how to put the sensor into the standby mode after all measurements are taken
                            • alexsh1A alexsh1
                              Matter of hours I guess, it's half more than the max continuous discharge current of a CR2032.
                              • Nca78N Nca78
                                alexsh1A
                                alexsh1A
                                alexsh1
                                #81
                                @Nca78 said in 💬 Button size radionode with sensors swarm extension:
                                It is 4.mA for 120ms for less just for measurements
                                However, I agree that this is not very battery friendly
                                • alexsh1A alexsh1
                                  Ah ok I completely misunderstood :D But yes seems high for a CR2032 sensor...
                                  • TerrenceT
                                    TerrenceT
                                    Terrence
                                    • A
                                      Abdu Sahin
                                      @Koresh,
                                      I tried to buy some of these on the link you provided, but couldn't do it. Do you still have this component in your stock ? I like to buy 865mhz HW/W versions.
                                      • Y
                                        Y
                                        yury
                                        @Abdu-Sahin said in 💬 Button size radionode with sensors swarm extension:
                                        865mhz HW/
                                        Hi
                                        They will be ready end of this week. do you need both HCW and CW versions?
                                        • Y yury
                                          865mhz HW/
                                          Hi
                                          Abdu Sahin
                                          @yury
                                          I like to try both 865 HW/W versions. I need sensors with long battery life and good RF distance coverage for my project. I've noticed some people suggested using only 'W' version for battery powered nodes, but from my initial experience I didn't have good distance with 'W' version.
                                          12.5k
