  3. 💬 Button size radionode with sensors swarm extension
atsha204aflashhumidityrf69lightuv lightbatterymysensortemperatureota
189 Posts 28 Posters 76.6k Views 25 Watching
  • alexsh1A alexsh1
    @yury I was suspecting EEPROM (CS pin with pull-up resistor?) to be a culprit
    KoreshK
    KoreshK
    Koresh
    @alexsh1 you can solder one or two capacitors ~50-200uf. But you should remove both because we do not know which of them is bad. Do not forget about polarity ;) Dot-key on the board means positive, so tantalum has positive key, but electrolitic capacitors has negative key.
    alexsh1A 1 Reply Last reply
    • KoreshK Koresh
      alexsh1A
      alexsh1A
      alexsh1
      #66
      @Koresh thanks. It does not matter which caps, right?
      I have a few 1206 100uF ceramic caps. They are not polarised and may be a good fit size wise
      KoreshK 1 Reply Last reply
      • Y yury
        combined capacitance of booth should be 100 --200 microfarads . It is input capacitors.
        please try replacing them
        re:
        not pullups...
        alexsh1A
        alexsh1A
        alexsh1
        @yury what's your estimate of battery life based on a new consumption of about 25uA and the default sketch?
        Y 1 Reply Last reply
        • alexsh1A alexsh1
          Y
          Y
          yury
          @alexsh1 220 mAh(Duracell) / 0.025 (mA) = 8800 hrs = 366 days.
          • alexsh1A alexsh1
            KoreshK
            KoreshK
            Koresh
            @alexsh1 There is no problem to use your capacitors. 1206imp = 3216metric (type A) so they are fit perfect :+1:
            About consumption... This is quite universal board. If you plan to use CR2032 battery it can be worth to omit LDO. You can do it using existing 0603 jumper footprint near right storage capacitor.
            • Y yury
              alexsh1A
              alexsh1A
              alexsh1
              @yury said in 💬 Button size radionode with sensors swarm extension:
              Not exactly - 25uA is a sleeping current.
              There will be sending periods every 10 mins.
              So I suppose the lifetime is less than a year
              • KoreshK Koresh
                alexsh1A
                alexsh1A
                alexsh1
                @Koresh yes, I'm using it with the 2032 battery.
                Which pads to your refer to please?
                • alexsh1A alexsh1
                  Y
                  Y
                  yury
                  @alexsh1
                  @alexsh1 said in 💬 Button size radionode with sensors swarm extension:
                  Yes, it is sleeping time estimate. When it wakes up it compares first, like : if ( abs(d) > 50 ) send(msg_vis.set(VIS_LIGHT), true); so it might send or not.
                  But this is just example sketch and you are very welcome to create pull-request or make suggestion how to improve.
                  alexsh1A 2 Replies Last reply
                  • alexsh1A alexsh1
                    KoreshK
                    KoreshK
                    Koresh
                    wrote on last edited by Koresh
                    #73
                    @alexsh1 You can fit juper (or any small wire, R10 on the schematic) or remove LDO at all and short top two pads.
                    • Y yury
                      @alexsh1
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @yury ok, you took the best case scenario (no messages as all) and if we take worst case scenario - sending every 10 mins in any case (suppose no if statement).
                      Then we take life time somewhere in between.
                      I think it make sense to take 18uA as a sleeping current removing the LDO from equation
                      • KoreshK Koresh
                        alexsh1A
                        alexsh1A
                        alexsh1
                        #75
                        @Koresh said in 💬 Button size radionode with sensors swarm extension:
                        More neat solution is to remove LDO and solder 0 ohm resistor (R10). Looks nice
                        Ok, 18uA - this is more like it.
                        Thank you very much for helping to get it sorted. Now I need to understand why the consumption has gone when using Si1132
                        @yury Did you test power consumption of modules with Si1132 please? I hope it was a bad soldering on my side
                        • Y yury
                          @alexsh1
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @yury I suggest we use this:
                          http://oregonembedded.com/batterycalc.htm
                          Based on non-LDO board consumption of 18uA the battery life assuming constant updates 10 mins and 140ms wake-up time (120ms is needed by bh1750) is 1.03 years. Excellent
                          • Y
                            Y
                            yury
                            Could not find good code to send it to sleep. without it Si1132 was eating a lot...
                            • Y yury
                              alexsh1A
                              alexsh1A
                              alexsh1
                              #78
                              @yury Hmmmm. Datasheet is stating that the standby current < 500 nA
                              However, actively measuring current - 4.5mA
                              This would kill 2032 very quickly
                              Nca78N 1 Reply Last reply
                              • KoreshK Koresh
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @Koresh another alternative would be using Si1145 it is pin-for-pin compatible with Si1132 and
                                This low-power sensing family enables long battery life with standby less than 500 nA and an average power of as little as 1.2 uA with once per second real-time UV Index measurements.
                                However, I still think that Si1132 can be working with the battery nicely. 0x18 register is a key:
                                The COMMAND Register is the primary mailbox register into the internal sequencer. Writing to the COMMAND register is the only I2C operation that wakes the device from standby mode.
                                The only question is how to put the sensor into the standby mode after all measurements are taken
                                • alexsh1A alexsh1
                                  Matter of hours I guess, it's half more than the max continuous discharge current of a CR2032.
                                  • Nca78N Nca78
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    #81
                                    @Nca78 said in 💬 Button size radionode with sensors swarm extension:
                                    It is 4.mA for 120ms for less just for measurements
                                    However, I agree that this is not very battery friendly
                                    • alexsh1A alexsh1
                                      Ah ok I completely misunderstood :D But yes seems high for a CR2032 sensor...
                                      • TerrenceT
                                        TerrenceT
                                        Terrence
                                        • A
                                          Abdu Sahin
                                          @Koresh,
                                          I tried to buy some of these on the link you provided, but couldn't do it. Do you still have this component in your stock ? I like to buy 865mhz HW/W versions.
                                          12.5k
