  3. 💬 In Wall AC/DC Pcb (with Relay) for MySensors (SMD)
switchin-wallrelayacdchlk-pm01
89 Posts 27 Posters 35.2k Views 29 Watching
  • Jose SimoesJ Jose Simoes
    @sundberg84 -hey, i was meaning something like the ACS712 Module, but add the ic to the PCB for better integration.
    sundberg84S
    sundberg84S
    @Jose-Simoes said in 💬 In Wall AC/DC Pcb (with Relay) for MySensors (SMD):
    ACS712
    Well, to safe space and meet my goal to be able to have it so small so it fits inside a wallsocket i have excluded all sensors and included the MysX connector. This way every user can add their own sensor.
    • J
      J
      Justas
      Hi, @sundberg84
      I'm really interested in this module. Maybe stupid question, but I'm very new with openhardware and would like to understand: if I will go and buy through the link provided (10xPCB for 15$), will I receive already assembled unit with all the parts, or I have to go and buy parts and assemble it myself?
      Thanks & Regards
      tonnerre33T gohanG 2 Replies Last reply
      • J Justas
        Hi, @sundberg84
        Thanks & Regards
        tonnerre33T
        tonnerre33T
        tonnerre33
        #34
        @Justas Hello,
        yes you have to buy parts and assemble them yourself. 1.5$ by PCB is cheap, you can't have the components for this price ;)
        • J Justas
          Hi, @sundberg84
          Thanks & Regards
          @Justas
          you get the PCB only, then you have to buy all the components and solder them on the pcb :)
          If you aren't a lot familiar with soldering you could also evaluate Sonoff wifi relays ;)
          • J
            J
            Justas
            Thanks, I also checked the parts list and found that total price is more than $14, so now I see how stupid my questions was ;)
            • proddyP
              proddyP
              proddy
              and building it is 99% of the fun !
              • H
                H
                hugch
                wrote on last edited by hugch
                #38
                Very nice project. And it is so nice that you thought about the fuses for the power supply and the relais. :-)
                I have two additional ideas:
                • adding the ATSHA204 fo secure signing
                • I could be to big to integrate but something like this (https://www.aliexpress.com/item/1Bit-AC-220V-Optocoupler-Isolation-Module-Testing-Board-Adaptive-for-PLC/32754734564.html) would be great to detect the in wall switch state.
                • E
                  E
                  exilit
                  Great project, thank you for sharing. Searching for a power supply i found your project which seems to fit my needs pretty well. What do you think are the main differences to the AC/DC/Double SSD Relay by Aproxx (https://www.mysensors.org/hardware/ac-dc-ssd-relay). I am mainly interested in the AC/DC conversion part.Would like to hear your opinion on that.
                  • E exilit
                    sundberg84S
                    sundberg84S
                    @exilit - sorry my friend, I have not studied the AC/DC/Double SSD Relay by Aproxx very closely.
                    Mine is a bit smaller instead of 50x50 but he got 2 relays.
                    • E
                      E
                      exilit
                      wrote on last edited by exilit
                      #41
                      @sundberg84 Thank you for your reply. Do you see big differences regarding the safety?
                      As far as I see both projects use a slow blow fuse and a thermal fuse to protect the AC-side.
                      Sorry for digging deeper, but both projects look great. Yours seems to be better tested,
                      but the other one has two relays. Hard to decide, which one to use :-).
                      • E exilit
                        sundberg84S
                        sundberg84S
                        @exilit - I think we both origin from the original discussion about the HLK-PM01: https://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers.
                        If you read this you can pretty much see everything in the PCB (fuses, varistor and temp fuse to protect the HLK module).
                          Martin Nicolaisen
                          Hi @sundberg84 does it fit the fuga (scandinavian) wall socket? :=
                          • M Martin Nicolaisen
                            sundberg84S
                            sundberg84S
                            @martin-nicolaisen - Im not familiar with the fuga wall socket.
                            I use standard round wall sockets (60cm). Can you point me to an image with dimensions ?
                            gohanG 1 Reply Last reply
                            • sundberg84S sundberg84
                              @sundberg84 said in 💬 In Wall AC/DC Pcb (with Relay) for MySensors (SMD):
                              (60cm)
                              Wow that's quite a wall plug
                                (60cm)
                                sundberg84S
                                sundberg84S
                                @gohan - lol :)
                                60mm!!!!
                                • meanmrgreenM
                                  meanmrgreenM
                                  meanmrgreen
                                  https://photos.app.goo.gl/JBIVogCZMp0mOCVh2
                                  I must have been drunk when I ordered this. Any idea what I have ordered? I ordered thru dirtypcbs somehow.
                                  Does look a little bit like this PCB but not really. Have I found a early version and drunk ordered 10 of em?
                                    That looks like version 4.1
                                    • N
                                      N
                                      Nightbodom
                                      Hi folks, I manage to solder all the tiny pieces together and now I need some advice on uploading some code/sketch. To start with... is there any instruction for dummies on internet how to upload sketch through ICSP ? I have one arduino which can be programmer, but I don't know how to do it. Then there is question about powering circuit during uploading code.... is it OK if it's connect to AC power during uploading code? And finally, can anyone post some simple sketch for this board to check if everythiing is working? Thanks for help.
                                      H 1 Reply Last reply
                                      • N Nightbodom
                                        H
                                        H
                                        hugch
                                        @nightbodom Arduino have a tutorial for this https://www.arduino.cc/en/Tutorial/ArduinoISP
                                        • N
                                          N
                                          Nightbodom
                                          @hugch thanks for info. I also find this: https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard for burning bootloader. And after that... how should I upload sketch?
