  3. 💬 In Wall AC/DC Pcb (with Relay) for MySensors (SMD)
switchin-wallrelayacdchlk-pm01
89 Posts 27 Posters 35.4k Views 29 Watching
  • J
    J
    Justas
    Hi, @sundberg84
    I'm really interested in this module. Maybe stupid question, but I'm very new with openhardware and would like to understand: if I will go and buy through the link provided (10xPCB for 15$), will I receive already assembled unit with all the parts, or I have to go and buy parts and assemble it myself?
    Thanks & Regards
    tonnerre33T gohanG 2 Replies Last reply
    • J Justas
      Hi, @sundberg84
      Thanks & Regards
      tonnerre33T
      tonnerre33T
      tonnerre33
      #34
      @Justas Hello,
      yes you have to buy parts and assemble them yourself. 1.5$ by PCB is cheap, you can't have the components for this price ;)
      • J Justas
        Hi, @sundberg84
        Thanks & Regards
        @Justas
        you get the PCB only, then you have to buy all the components and solder them on the pcb :)
        If you aren't a lot familiar with soldering you could also evaluate Sonoff wifi relays ;)
        • J
          J
          Justas
          Thanks, I also checked the parts list and found that total price is more than $14, so now I see how stupid my questions was ;)
          • proddyP
            proddyP
            proddy
            and building it is 99% of the fun !
            • H
              H
              hugch
              wrote on last edited by hugch
              #38
              Very nice project. And it is so nice that you thought about the fuses for the power supply and the relais. :-)
              I have two additional ideas:
              • adding the ATSHA204 fo secure signing
              • I could be to big to integrate but something like this (https://www.aliexpress.com/item/1Bit-AC-220V-Optocoupler-Isolation-Module-Testing-Board-Adaptive-for-PLC/32754734564.html) would be great to detect the in wall switch state.
              • E
                E
                exilit
                Great project, thank you for sharing. Searching for a power supply i found your project which seems to fit my needs pretty well. What do you think are the main differences to the AC/DC/Double SSD Relay by Aproxx (https://www.mysensors.org/hardware/ac-dc-ssd-relay). I am mainly interested in the AC/DC conversion part.Would like to hear your opinion on that.
                • E exilit
                  sundberg84S
                  sundberg84S
                  @exilit - sorry my friend, I have not studied the AC/DC/Double SSD Relay by Aproxx very closely.
                  Mine is a bit smaller instead of 50x50 but he got 2 relays.
                  • E
                    E
                    exilit
                    wrote on last edited by exilit
                    #41
                    @sundberg84 Thank you for your reply. Do you see big differences regarding the safety?
                    As far as I see both projects use a slow blow fuse and a thermal fuse to protect the AC-side.
                    Sorry for digging deeper, but both projects look great. Yours seems to be better tested,
                    but the other one has two relays. Hard to decide, which one to use :-).
                    • E exilit
                      sundberg84S
                      sundberg84S
                      @exilit - I think we both origin from the original discussion about the HLK-PM01: https://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers.
                      If you read this you can pretty much see everything in the PCB (fuses, varistor and temp fuse to protect the HLK module).
                        Martin Nicolaisen
                        Hi @sundberg84 does it fit the fuga (scandinavian) wall socket? :=
                        • M Martin Nicolaisen
                          sundberg84S
                          sundberg84S
                          @martin-nicolaisen - Im not familiar with the fuga wall socket.
                          I use standard round wall sockets (60cm). Can you point me to an image with dimensions ?
                          gohanG 1 Reply Last reply
                          • sundberg84S sundberg84
                            @sundberg84 said in 💬 In Wall AC/DC Pcb (with Relay) for MySensors (SMD):
                            (60cm)
                            Wow that's quite a wall plug
                              (60cm)
                              sundberg84S
                              sundberg84S
                              @gohan - lol :)
                              60mm!!!!
                              • meanmrgreenM
                                meanmrgreenM
                                meanmrgreen
                                https://photos.app.goo.gl/JBIVogCZMp0mOCVh2
                                I must have been drunk when I ordered this. Any idea what I have ordered? I ordered thru dirtypcbs somehow.
                                Does look a little bit like this PCB but not really. Have I found a early version and drunk ordered 10 of em?
                                  That looks like version 4.1
                                  • N
                                    N
                                    Nightbodom
                                    Hi folks, I manage to solder all the tiny pieces together and now I need some advice on uploading some code/sketch. To start with... is there any instruction for dummies on internet how to upload sketch through ICSP ? I have one arduino which can be programmer, but I don't know how to do it. Then there is question about powering circuit during uploading code.... is it OK if it's connect to AC power during uploading code? And finally, can anyone post some simple sketch for this board to check if everythiing is working? Thanks for help.
                                    H 1 Reply Last reply
                                    • N Nightbodom
                                      H
                                      H
                                      hugch
                                      @nightbodom Arduino have a tutorial for this https://www.arduino.cc/en/Tutorial/ArduinoISP
                                      • N
                                        N
                                        Nightbodom
                                        @hugch thanks for info. I also find this: https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard for burning bootloader. And after that... how should I upload sketch?
                                        • N Nightbodom
                                          sundberg84S
                                          sundberg84S
                                          @nightbodom you connect it to a ISP programmer to the port. This will take care of 5v and Gnd as well so don't connect to AC during upload
