  3. 💬 In Wall AC/DC Pcb (with Relay) for MySensors (SMD)
switchin-wallrelayacdchlk-pm01
89 Posts 27 Posters 35.4k Views 29 Watching
  • Jose SimoesJ Jose Simoes
    hi, just an idea, do you think it is possible to add a current sensor to the PCB in order to add a power meter function to the node to monitor power consumption? say up to 20A
    sundberg84S
    sundberg84S
    @Jose-Simoes - no clue about current sensors... sorry I just cant answer that at the moment.
    Jose SimoesJ 1 Reply Last reply
    • Jose SimoesJ
      Jose SimoesJ
      Jose Simoes
      • sundberg84S sundberg84
        Jose SimoesJ
        Jose SimoesJ
        Jose Simoes
        @sundberg84 -hey, i was meaning something like the ACS712 Module, but add the ic to the PCB for better integration.
          sundberg84S
          sundberg84S
          @Jose-Simoes said in 💬 In Wall AC/DC Pcb (with Relay) for MySensors (SMD):
          ACS712
          Well, to safe space and meet my goal to be able to have it so small so it fits inside a wallsocket i have excluded all sensors and included the MysX connector. This way every user can add their own sensor.
          • J
            J
            Justas
            Hi, @sundberg84
            I'm really interested in this module. Maybe stupid question, but I'm very new with openhardware and would like to understand: if I will go and buy through the link provided (10xPCB for 15$), will I receive already assembled unit with all the parts, or I have to go and buy parts and assemble it myself?
            Thanks & Regards
            tonnerre33T gohanG 2 Replies Last reply
            • J Justas
              Hi, @sundberg84
              Thanks & Regards
              tonnerre33T
              tonnerre33T
              tonnerre33
              #34
              @Justas Hello,
              yes you have to buy parts and assemble them yourself. 1.5$ by PCB is cheap, you can't have the components for this price ;)
              • J Justas
                Hi, @sundberg84
                Thanks & Regards
                @Justas
                you get the PCB only, then you have to buy all the components and solder them on the pcb :)
                If you aren't a lot familiar with soldering you could also evaluate Sonoff wifi relays ;)
                • J
                  J
                  Justas
                  Thanks, I also checked the parts list and found that total price is more than $14, so now I see how stupid my questions was ;)
                  • proddyP
                    proddyP
                    proddy
                    and building it is 99% of the fun !
                    • H
                      H
                      hugch
                      wrote on last edited by hugch
                      #38
                      Very nice project. And it is so nice that you thought about the fuses for the power supply and the relais. :-)
                      I have two additional ideas:
                      • adding the ATSHA204 fo secure signing
                      • I could be to big to integrate but something like this (https://www.aliexpress.com/item/1Bit-AC-220V-Optocoupler-Isolation-Module-Testing-Board-Adaptive-for-PLC/32754734564.html) would be great to detect the in wall switch state.
                      • E
                        E
                        exilit
                        Great project, thank you for sharing. Searching for a power supply i found your project which seems to fit my needs pretty well. What do you think are the main differences to the AC/DC/Double SSD Relay by Aproxx (https://www.mysensors.org/hardware/ac-dc-ssd-relay). I am mainly interested in the AC/DC conversion part.Would like to hear your opinion on that.
                        • E exilit
                          sundberg84S
                          sundberg84S
                          @exilit - sorry my friend, I have not studied the AC/DC/Double SSD Relay by Aproxx very closely.
                          Mine is a bit smaller instead of 50x50 but he got 2 relays.
                          • E
                            E
                            exilit
                            wrote on last edited by exilit
                            #41
                            @sundberg84 Thank you for your reply. Do you see big differences regarding the safety?
                            As far as I see both projects use a slow blow fuse and a thermal fuse to protect the AC-side.
                            Sorry for digging deeper, but both projects look great. Yours seems to be better tested,
                            but the other one has two relays. Hard to decide, which one to use :-).
                            • E exilit
                              sundberg84S
                              sundberg84S
                              @exilit - I think we both origin from the original discussion about the HLK-PM01: https://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers.
                              If you read this you can pretty much see everything in the PCB (fuses, varistor and temp fuse to protect the HLK module).
                                Martin Nicolaisen
                                Hi @sundberg84 does it fit the fuga (scandinavian) wall socket? :=
                                • M Martin Nicolaisen
                                  sundberg84S
                                  sundberg84S
                                  @martin-nicolaisen - Im not familiar with the fuga wall socket.
                                  I use standard round wall sockets (60cm). Can you point me to an image with dimensions ?
                                  gohanG 1 Reply Last reply
                                    @sundberg84 said in 💬 In Wall AC/DC Pcb (with Relay) for MySensors (SMD):
                                    (60cm)
                                    Wow that's quite a wall plug
                                      (60cm)
                                      sundberg84S
                                      sundberg84S
                                      @gohan - lol :)
                                      60mm!!!!
                                      • meanmrgreenM
                                        meanmrgreenM
                                        meanmrgreen
                                        https://photos.app.goo.gl/JBIVogCZMp0mOCVh2
                                        I must have been drunk when I ordered this. Any idea what I have ordered? I ordered thru dirtypcbs somehow.
                                        Does look a little bit like this PCB but not really. Have I found a early version and drunk ordered 10 of em?
                                          That looks like version 4.1
