  3. 💬 In Wall AC/DC Pcb (with Relay) for MySensors (SMD)
switchin-wallrelayacdchlk-pm01
89 Posts 27 Posters 35.2k Views 29 Watching
  • proddyP proddy
    @sundberg84 Thanks for sharing this. I'm gathering the components and plan to build it soon when the PCB v7.1 is available.
    I do have a few questions if I may
    • with the Relay, is it important to have one that has zero crossover? E.g the difference between getting the G3MC-202PL over a G3MC-202P
    • what were you planning to use the 16Mhz oscillator for eventually?
    • do you see any issues if I build the first prototype using an ESP-12 (ESP8266 with onboard Serial WiFi running at 3.3v)?
    sundberg84S
    sundberg84S
    @Paul-Derbyshire
    1. It must depend on what you are planning to connect to the relay
    2. The oscillator is for the MCU - you can program a bootloader without it and use the internal.
    3. No issue - please do! Im glad i can make stuff that gets the community forward. Best of luck!
    proddyP 1 Reply Last reply
    • sundberg84S sundberg84
      @Paul-Derbyshire
      proddyP
      proddyP
      proddy
      It would use it to switch on and off an external mounted lamp - so with a fixed Watt & Voltage. Probably an LED 220V Lamp. Should I avoid zero-crossover as I've read somewhere that zero-crossover can cause a surge current of perhaps 10 to 40 times the steady state current when switched on.
      • proddyP proddy
        sundberg84S
        sundberg84S
        @Paul-Derbyshire - sorry, to be hones i missunderstood you.
        Most SSR sold for arduino are P and not PL it seems.
        "The light from the diode is beamed into a light-sensitive semiconductor that, in the case of zero-voltage crossover relays, conditions the control circuit to turn on the output solid-state switch at the next zero-voltage crossover. In the case of nonzero-voltage crossover relays, the output solid-state switch is turned on at the precise voltage occurring at the time."
        • Jose SimoesJ
          Jose SimoesJ
          Jose Simoes
          hi, just an idea, do you think it is possible to add a current sensor to the PCB in order to add a power meter function to the node to monitor power consumption? say up to 20A
          • Jose SimoesJ Jose Simoes
            sundberg84S
            sundberg84S
            @Jose-Simoes - no clue about current sensors... sorry I just cant answer that at the moment.
            Jose SimoesJ 1 Reply Last reply
            • Jose SimoesJ
              Jose SimoesJ
              Jose Simoes
                Jose SimoesJ
                Jose SimoesJ
                Jose Simoes
                @sundberg84 -hey, i was meaning something like the ACS712 Module, but add the ic to the PCB for better integration.
                  sundberg84S
                  sundberg84S
                  @Jose-Simoes said in 💬 In Wall AC/DC Pcb (with Relay) for MySensors (SMD):
                  ACS712
                  Well, to safe space and meet my goal to be able to have it so small so it fits inside a wallsocket i have excluded all sensors and included the MysX connector. This way every user can add their own sensor.
                  • J
                    J
                    Justas
                    Hi, @sundberg84
                    I'm really interested in this module. Maybe stupid question, but I'm very new with openhardware and would like to understand: if I will go and buy through the link provided (10xPCB for 15$), will I receive already assembled unit with all the parts, or I have to go and buy parts and assemble it myself?
                    Thanks & Regards
                    tonnerre33T gohanG 2 Replies Last reply
                    • J Justas
                      Hi, @sundberg84
                      Thanks & Regards
                      tonnerre33T
                      tonnerre33T
                      tonnerre33
                      #34
                      @Justas Hello,
                      yes you have to buy parts and assemble them yourself. 1.5$ by PCB is cheap, you can't have the components for this price ;)
                      • J Justas
                        Hi, @sundberg84
                        Thanks & Regards
                        @Justas
                        you get the PCB only, then you have to buy all the components and solder them on the pcb :)
                        If you aren't a lot familiar with soldering you could also evaluate Sonoff wifi relays ;)
                        • J
                          J
                          Justas
                          Thanks, I also checked the parts list and found that total price is more than $14, so now I see how stupid my questions was ;)
                          • proddyP
                            proddyP
                            proddy
                            and building it is 99% of the fun !
                            • H
                              H
                              hugch
                              wrote on last edited by hugch
                              #38
                              Very nice project. And it is so nice that you thought about the fuses for the power supply and the relais. :-)
                              I have two additional ideas:
                              • adding the ATSHA204 fo secure signing
                              • I could be to big to integrate but something like this (https://www.aliexpress.com/item/1Bit-AC-220V-Optocoupler-Isolation-Module-Testing-Board-Adaptive-for-PLC/32754734564.html) would be great to detect the in wall switch state.
                              • E
                                E
                                exilit
                                Great project, thank you for sharing. Searching for a power supply i found your project which seems to fit my needs pretty well. What do you think are the main differences to the AC/DC/Double SSD Relay by Aproxx (https://www.mysensors.org/hardware/ac-dc-ssd-relay). I am mainly interested in the AC/DC conversion part.Would like to hear your opinion on that.
                                • E exilit
                                  sundberg84S
                                  sundberg84S
                                  @exilit - sorry my friend, I have not studied the AC/DC/Double SSD Relay by Aproxx very closely.
                                  Mine is a bit smaller instead of 50x50 but he got 2 relays.
                                  • E
                                    E
                                    exilit
                                    wrote on last edited by exilit
                                    #41
                                    @sundberg84 Thank you for your reply. Do you see big differences regarding the safety?
                                    As far as I see both projects use a slow blow fuse and a thermal fuse to protect the AC-side.
                                    Sorry for digging deeper, but both projects look great. Yours seems to be better tested,
                                    but the other one has two relays. Hard to decide, which one to use :-).
                                    • E exilit
                                      sundberg84S
                                      sundberg84S
                                      @exilit - I think we both origin from the original discussion about the HLK-PM01: https://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers.
                                      If you read this you can pretty much see everything in the PCB (fuses, varistor and temp fuse to protect the HLK module).
                                        Martin Nicolaisen
                                        Hi @sundberg84 does it fit the fuga (scandinavian) wall socket? :=
                                        • M Martin Nicolaisen
                                          sundberg84S
                                          sundberg84S
                                          @martin-nicolaisen - Im not familiar with the fuga wall socket.
                                          I use standard round wall sockets (60cm). Can you point me to an image with dimensions ?
                                          gohanG 1 Reply Last reply
