  3. Raspberry Gateway + Arduino pro mini (atmega328p) NRF24L01 (without plus +)
atmega328parduino pro miniraspberry serial gatewayhome assistantnrf24l01
21 Posts 4 Posters 7.9k Views 2 Watching
  • A alop
    Unfortunatelly not.
    Same result
    3 TSM:INIT
    4 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSF:SID:OK,ID=1
    14 TSM:FPAR
    1613 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    3621 !TSM:FPAR:NO REPLY
    3623 TSM:FPAR
    5223 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    7230 !TSM:FPAR:NO REPLY
    7232 TSM:FPAR
    8832 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    10839 !TSM:FPAR:NO REPLY
    And here is the code:
     * Version 1.0 - Henrik Ekblad
    // Enable debug prints
    #define MY_RF24_CE_PIN 6
    #define MY_RF24_CS_PIN 10
    #define MY_RF24_DATARATE RF24_2MBPS
    #define CHILD_ID 11   // Id of the sensor child
    #include <MyConfig.h>
    // Initialize motion message
      Serial.println(F("Setup"));
      present(CHILD_ID, S_MOTION);
      Serial.println(F("Presentation"));
      Serial.println(F("loop"));
      // Read digital motion value
      bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
      Serial.println(tripped);
    sundberg84S
    sundberg84S
    @alop said in Raspberry Gateway + Arduino pro mini (atmega328p) NRF24L01 (without plus +):
    !TSM:FPAR:NO REPLY
    This means "no potential parents replied to find parent request" so pretty much the node and the gw doesnt talk to each other. Why? Well, it looks like the radios is initialized if im right but either its a range issue (to long between, or sometimes even to close so they over-shout eachother) and it could be a power issue. The most important thing is that you have capacitors on the radio.
    How do you power the radios?
    A 1 Reply Last reply
    • sundberg84S sundberg84
      !TSM:FPAR:NO REPLY
      alop
      @sundberg84
      I dont have capacitors on radios.
      The distance between radios is 20-30 cm.
      Raspberry radio is powered from raspberry.
      On Arduino i have additional power supply 5v for the motion sensor.
      Arduino is powered through USB.
      Am I assuming right, that on raspberry when there is no configure parameter for something, I just change it in MyConfig.h and "make" again?
      I had the same hardware setup tested with gettingstarted and the communication was established.
      • A alop
        @sundberg84
        @alop you'll have a hard time getting help from anyone until you have capacitors on the radios. Power issues are the top 1, 2, 3, 4 and 5 issues if you look at the problems people are having. Yes, sometimes it works with a very simple example. No that does not mean that your power is stable enough.
        https://www.mysensors.org/build/raspberry#advanced shows how to set defines if you don't want to modify MyConfig.h, but modifying MyConfig.h also works. I prefer the -D variant because then I can easily switch MySensors versions in git without having to re-apply the changes.
          alop
          wrote on last edited by alop
          @mfalkvidd OK. I just bought some 4.7 capacitors :)
          I'll make the setup with them.
          @mfalkvidd said in Raspberry Gateway + Arduino pro mini (atmega328p) NRF24L01 (without plus +):
          Just to clerify, if I change MyConfig.h on raspberry it is not enough just to save the file and "build" the gateway with other parameters?
          Maybe this is why I dont receive any signal.
          • A alop
            @alop geat.
            Until you have the capacitors in place, see if sundberg's advice on moving the nodes apart helps, about 2-3 meters. The signal can become too strong.
              @alop geat.
              alop
              @mfalkvidd
              Just in general: What is the procedure if I change the MyConfig.h on raspberry?
              • A alop
                @mfalkvidd
                @alop edit it with your favorite editor?
                  alop
                  @mfalkvidd Ok, so far :)
                  But do I need to "compile", "build", "make" something so that changes in MyConfig.h will be taken?
                  • A alop
                    @alop ok :)
                    I think make is sufficient (and make install if you want the new binary installed).
                    make is smart enough to recompile everything that has been modified.
                      @alop ok :)
                      alop
                      @mfalkvidd
                      Unfortunatelly no change after adding capacitor :(
                      Now I have bought NRF24L01 WITH Plus and I'm trying with them.
                      I have reinstalled from skratch everything.
                      Gateway and sensor are now ca. 3-4 meters appart.
                      Sketch on atmega328p (light sensor)
                       * Version 1.0 - Henrik EKblad
                       * Example sketch showing how to measue light level using a LM393 photo-resistor
                       * http://www.mysensors.org/build/light
                      #define CHILD_ID_LIGHT 15
                      int lastLightLevel;
                          sendSketchInfo("Light Sensor", "1.0");
                          int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
                          Serial.println(lightLevel);
                              send(msg.set(lightLevel));
                              lastLightLevel = lightLevel;
                          sleep(SLEEP_TIME);
                      On raspberry
                      ./configure --my-transport=nrf24 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
                      Serial on the sensor
                      114445 !TSM:FPAR:NO REPLY
                      114447 TSM:FPAR
                      114449 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      116457 !TSM:FPAR:FAIL
                      116459 TSM:FAIL:CNT=7
                      116461 TSM:FAIL:DIS
                      116463 TSF:TDI:TSL
                      176465 TSM:FAIL:RE-INIT
                      176467 TSM:INIT
                      176475 TSM:INIT:TSP OK
                      176477 TSM:FPAR
                      176479 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      178487 !TSM:FPAR:NO REPLY
                      178489 TSM:FPAR
                      178491 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      180499 !TSM:FPAR:NO REPLY
                      180501 TSM:FPAR
                      180503 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      182511 !TSM:FPAR:NO REPLY
                      182513 TSM:FPAR
                      182515 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      on raspberry
                      pi@RP3HA:~/MySensors $ sudo ./bin/mysgw -d
                      mysgw: Starting gateway...
                      mysgw: MCO:BGN:INIT GW,CP=RNNG----,VER=2.2.0-beta
                      mysgw: TSF:LRT:OK
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: TSM:INIT:TSP OK
                      mysgw: TSM:INIT:GW MODE
                      mysgw: MCO:REG:NOT NEEDED
                      mysgw: MCO:BGN:STP
                      mysgw: MCO:BGN:INIT OK,TSP=1
                      And on my home automation (home assistant)
                      2017-07-22 13:00:19 ERROR (Thread-13) [mysensors.gateway_serial] Unable to connect to /dev/ttyUSB020
                      Update:
                      After 15-20 minutes running the gateway I received following lines:
                      mysgw: TSF:SAN:OK
                      mysgw: TSM:READY:NWD REQ
                      mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                      • A
                        alop
                        It's a workaroud, but not "nice".
                        Since I have no problem on creating gateway on another arduino pro mini, I just connected per USB the arduino to RP3 and everything is working fine.
                        So sensors can be read by a controller (home assistant).
                        Big downside is, that for pro mini I have to use usb to ttl convertor in between.
                        Maybe the code for raspberry is with bugs, since to be able to see my rf radio on raspberry I had to install the "development" branch.
                          the development branch works well, why don't you use it on the RPI?
                            alop
                            @gohan As described above, there was no connection between serial gateway on RPi und sensor nodes.
                            Above is the whole setup described. Wiring is taken from the mysensors web site.
                              I am referring to create an ethernet gw running on the RPI instead of a serial gw.
                                alop
                                @gohan I do not have ethernet hardware. I just wanted to connect radio directly to RPI
                                  Just follow the guide of raspberry gateway and choose to configure it as ethernet, it makes it easier to setup con controller.
                                    alop
                                    @gohan said in Raspberry Gateway + Arduino pro mini (atmega328p) NRF24L01 (without plus +):
                                    choose to configure it as ethernet, .
                                    But if I understand right, I need ethernet gateway hardware, or am I missing something?
                                      The RPI becomes an ethernet gateway.
