  3. Raspberry Gateway + Arduino pro mini (atmega328p) NRF24L01 (without plus +)
atmega328parduino pro miniraspberry serial gatewayhome assistantnrf24l01
21 Posts 4 Posters 7.9k Views 2 Watching
  • A alop
    @mfalkvidd
    Just in general: What is the procedure if I change the MyConfig.h on raspberry?
    @alop edit it with your favorite editor?
    A 1 Reply Last reply
      alop
      @mfalkvidd Ok, so far :)
      But do I need to "compile", "build", "make" something so that changes in MyConfig.h will be taken?
      • A alop
        @alop ok :)
        I think make is sufficient (and make install if you want the new binary installed).
        make is smart enough to recompile everything that has been modified.
          @alop ok :)
          alop
          wrote on last edited by alop
          @mfalkvidd
          Unfortunatelly no change after adding capacitor :(
          Now I have bought NRF24L01 WITH Plus and I'm trying with them.
          I have reinstalled from skratch everything.
          Gateway and sensor are now ca. 3-4 meters appart.
          Sketch on atmega328p (light sensor)
           * Version 1.0 - Henrik EKblad
           * Example sketch showing how to measue light level using a LM393 photo-resistor
           * http://www.mysensors.org/build/light
          #define CHILD_ID_LIGHT 15
          int lastLightLevel;
              sendSketchInfo("Light Sensor", "1.0");
              int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
              Serial.println(lightLevel);
                  send(msg.set(lightLevel));
                  lastLightLevel = lightLevel;
              sleep(SLEEP_TIME);
          On raspberry
          ./configure --my-transport=nrf24 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
          Serial on the sensor
          114445 !TSM:FPAR:NO REPLY
          114447 TSM:FPAR
          114449 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          116457 !TSM:FPAR:FAIL
          116459 TSM:FAIL:CNT=7
          116461 TSM:FAIL:DIS
          116463 TSF:TDI:TSL
          176465 TSM:FAIL:RE-INIT
          176467 TSM:INIT
          176475 TSM:INIT:TSP OK
          176477 TSM:FPAR
          176479 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          178487 !TSM:FPAR:NO REPLY
          178489 TSM:FPAR
          178491 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          180499 !TSM:FPAR:NO REPLY
          180501 TSM:FPAR
          180503 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          182511 !TSM:FPAR:NO REPLY
          182513 TSM:FPAR
          182515 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          on raspberry
          pi@RP3HA:~/MySensors $ sudo ./bin/mysgw -d
          mysgw: Starting gateway...
          mysgw: MCO:BGN:INIT GW,CP=RNNG----,VER=2.2.0-beta
          mysgw: TSF:LRT:OK
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: TSM:INIT:TSP OK
          mysgw: TSM:INIT:GW MODE
          mysgw: MCO:REG:NOT NEEDED
          mysgw: MCO:BGN:STP
          mysgw: MCO:BGN:INIT OK,TSP=1
          And on my home automation (home assistant)
          2017-07-22 13:00:19 ERROR (Thread-13) [mysensors.gateway_serial] Unable to connect to /dev/ttyUSB020
          Update:
          After 15-20 minutes running the gateway I received following lines:
          mysgw: TSF:SAN:OK
          mysgw: TSM:READY:NWD REQ
          mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
          • A
            alop
            It's a workaroud, but not "nice".
            Since I have no problem on creating gateway on another arduino pro mini, I just connected per USB the arduino to RP3 and everything is working fine.
            So sensors can be read by a controller (home assistant).
            Big downside is, that for pro mini I have to use usb to ttl convertor in between.
            Maybe the code for raspberry is with bugs, since to be able to see my rf radio on raspberry I had to install the "development" branch.
              the development branch works well, why don't you use it on the RPI?
                alop
                @gohan As described above, there was no connection between serial gateway on RPi und sensor nodes.
                Above is the whole setup described. Wiring is taken from the mysensors web site.
                  I am referring to create an ethernet gw running on the RPI instead of a serial gw.
                    alop
                    @gohan I do not have ethernet hardware. I just wanted to connect radio directly to RPI
                      Just follow the guide of raspberry gateway and choose to configure it as ethernet, it makes it easier to setup con controller.
                        alop
                        @gohan said in Raspberry Gateway + Arduino pro mini (atmega328p) NRF24L01 (without plus +):
                        choose to configure it as ethernet, .
                        But if I understand right, I need ethernet gateway hardware, or am I missing something?
                          The RPI becomes an ethernet gateway.
