  3. Raspberry Gateway + Arduino pro mini (atmega328p) NRF24L01 (without plus +)
atmega328parduino pro miniraspberry serial gatewayhome assistantnrf24l01
21 Posts 4 Posters 7.9k Views 2 Watching
  • A alop
    @mfalkvidd OK. I just bought some 4.7 capacitors :)
    I'll make the setup with them.
    @mfalkvidd said in Raspberry Gateway + Arduino pro mini (atmega328p) NRF24L01 (without plus +):
    https://www.mysensors.org/build/raspberry#advanced shows how to set defines if you don't want to modify MyConfig.h, but modifying MyConfig.h also works. I prefer the -D variant because then I can easily switch MySensors versions in git without having to re-apply the changes.
    Just to clerify, if I change MyConfig.h on raspberry it is not enough just to save the file and "build" the gateway with other parameters?
    Maybe this is why I dont receive any signal.
    @alop geat.
    Until you have the capacitors in place, see if sundberg's advice on moving the nodes apart helps, about 2-3 meters. The signal can become too strong.
    A 1 Reply Last reply
      @alop geat.
      alop
      @mfalkvidd
      Just in general: What is the procedure if I change the MyConfig.h on raspberry?
      • A alop
        @mfalkvidd
        @alop edit it with your favorite editor?
          alop
          @mfalkvidd Ok, so far :)
          But do I need to "compile", "build", "make" something so that changes in MyConfig.h will be taken?
          • A alop
            @alop ok :)
            I think make is sufficient (and make install if you want the new binary installed).
            make is smart enough to recompile everything that has been modified.
              @alop ok :)
              alop
              wrote on last edited by alop
              @mfalkvidd
              Unfortunatelly no change after adding capacitor :(
              Now I have bought NRF24L01 WITH Plus and I'm trying with them.
              I have reinstalled from skratch everything.
              Gateway and sensor are now ca. 3-4 meters appart.
              Sketch on atmega328p (light sensor)
               * Version 1.0 - Henrik EKblad
               * Example sketch showing how to measue light level using a LM393 photo-resistor
               * http://www.mysensors.org/build/light
              #define CHILD_ID_LIGHT 15
              int lastLightLevel;
                  sendSketchInfo("Light Sensor", "1.0");
                  int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
                  Serial.println(lightLevel);
                      send(msg.set(lightLevel));
                      lastLightLevel = lightLevel;
                  sleep(SLEEP_TIME);
              On raspberry
              ./configure --my-transport=nrf24 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
              Serial on the sensor
              114445 !TSM:FPAR:NO REPLY
              114447 TSM:FPAR
              114449 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              116457 !TSM:FPAR:FAIL
              116459 TSM:FAIL:CNT=7
              116461 TSM:FAIL:DIS
              116463 TSF:TDI:TSL
              176465 TSM:FAIL:RE-INIT
              176467 TSM:INIT
              176475 TSM:INIT:TSP OK
              176477 TSM:FPAR
              176479 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              178487 !TSM:FPAR:NO REPLY
              178489 TSM:FPAR
              178491 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              180499 !TSM:FPAR:NO REPLY
              180501 TSM:FPAR
              180503 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              182511 !TSM:FPAR:NO REPLY
              182513 TSM:FPAR
              182515 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              on raspberry
              pi@RP3HA:~/MySensors $ sudo ./bin/mysgw -d
              mysgw: Starting gateway...
              mysgw: MCO:BGN:INIT GW,CP=RNNG----,VER=2.2.0-beta
              mysgw: TSF:LRT:OK
              mysgw: TSM:INIT
              mysgw: TSF:WUR:MS=0
              mysgw: TSM:INIT:TSP OK
              mysgw: TSM:INIT:GW MODE
              mysgw: MCO:REG:NOT NEEDED
              mysgw: MCO:BGN:STP
              mysgw: MCO:BGN:INIT OK,TSP=1
              And on my home automation (home assistant)
              2017-07-22 13:00:19 ERROR (Thread-13) [mysensors.gateway_serial] Unable to connect to /dev/ttyUSB020
              Update:
              After 15-20 minutes running the gateway I received following lines:
              mysgw: TSF:SAN:OK
              mysgw: TSM:READY:NWD REQ
              mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
              • A
                alop
                It's a workaroud, but not "nice".
                Since I have no problem on creating gateway on another arduino pro mini, I just connected per USB the arduino to RP3 and everything is working fine.
                So sensors can be read by a controller (home assistant).
                Big downside is, that for pro mini I have to use usb to ttl convertor in between.
                Maybe the code for raspberry is with bugs, since to be able to see my rf radio on raspberry I had to install the "development" branch.
                  the development branch works well, why don't you use it on the RPI?
                    alop
                    @gohan As described above, there was no connection between serial gateway on RPi und sensor nodes.
                    Above is the whole setup described. Wiring is taken from the mysensors web site.
                      I am referring to create an ethernet gw running on the RPI instead of a serial gw.
                        alop
                        @gohan I do not have ethernet hardware. I just wanted to connect radio directly to RPI
                          Just follow the guide of raspberry gateway and choose to configure it as ethernet, it makes it easier to setup con controller.
                            alop
                            @gohan said in Raspberry Gateway + Arduino pro mini (atmega328p) NRF24L01 (without plus +):
                            choose to configure it as ethernet, .
                            But if I understand right, I need ethernet gateway hardware, or am I missing something?
                              The RPI becomes an ethernet gateway.
