  3. My first working Switch with Battery and Temperature ..
temperatureswitchbatterybinary
5 Posts 3 Posters 4.9k Views 1 Watching
  • D Offline
    dzairo
    Hi all.
    I make my first project (thanks to all for help) Switch , with battery and temperature monitoring..
    here is my node PCB :
    and here is schematic :
    and project :
    BinSwitchBatSleep_ACK.zip
    This project use two button INT0 and INT1 . if change state then send packet with ACK request .
    if no ACK received then generate sound .. from piezoelectric generator .
    Battery is in volate *10 - if received value is for example 28 it s 2.8V .
    now working good .. power consumption is 7uA .
    PS> I need help with pin change interupt .. I now use two button only .. but want support 4x button.. then need litle help how to use it ..
    regards..
    B 1 Reply Last reply
    • D Offline
      daulagari
      @dzairo: Nice piece of work and looking at the schematics with enough attention to decoupling and powering the device!
      I assume that is sleep current. Do you know anything about the average consumption over say one hour?
      I think I can not directly help you with this but it would be good to know to which pins the buttons are connected, that is not readable from the schematics above.
      • D dzairo
        Hi all.
        and project :
        regards..
        B Offline
        B Offline
        BulldogLowell
        @dzairo
        Nick Gammon did an example of four pins 'sharing' one interrupt pin. Perhaps this will be workable for you.
        It may be tough to squeeze the 4 diodes onto your board, though!
        • D Offline
          dzairo
          I know how to do it by diode.. but I want by interrupt only.. I do it my self..
          • D dzairo
            B Offline
            B Offline
            BulldogLowell
            @dzairo
            there is a nice PinChangeInterrupt library that you may want to look at.
            12.1k
