  3. ๐Ÿ’ฌ BlackCircle Sensor - High "WAF" Temp/Hum. sensor
contest2017temperaturehumiditymysensorswaf
13 Posts 8 Posters 5.7k Views 7 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/411/BlackCircle-Sensor-High-WAF-TempHum-sensor
      sundberg84S
      sundberg84S
      @nca - you are on fire :) Well done! High WAF - will talk to wife ;)
      • AnticimexA
        AnticimexA
        Anticimex
        Nice stuff! Please don't forget to add the documentation as required by your chosen license.
        Details are here: https://forum.mysensors.org/topic/3096/open-hardware-licensing
        Nca78N 1 Reply Last reply
          We need to create a sticker like "WAF Compliant" or similar to put on projects :D
          Nca78N CrankyCoderC 2 Replies Last reply
          • AnticimexA Anticimex
            @Anticimex said in ๐Ÿ’ฌ BlackCircle Sensor - High "WAF" Temp/Hum. sensor:
            Oups yes sorry, adding it right now on my last published boards...
              @gohan said in ๐Ÿ’ฌ BlackCircle Sensor - High "WAF" Temp/Hum. sensor:
              I put a WAF tag on openhardware.io, try it :D
              • Nca78N
                I quickly soldered one and it's running perfectly on a chinese CR2032.
                220ยตF reserve capacitor fits perfectly behind the battery so no need for using 2x100uF, and the radio capacitor has more space so no need to put it over the radio.
                It might benefit from a few adjustments in the PCB shape but it fits easily like that and the double sided tape that kept in place the original circuit is perfect for this PCB also.
                No more "work in progress" :D
                  CrankyCoderC
                  CrankyCoderC
                  CrankyCoder
                  @gohan LOVE THIS IDEA!!! We should have a line of them.
                  WAF Rating: 1-5
                  1 = super fun for us
                  5 = wife doesn't kick us out
                  Home Automation Tinkerer
                  www.CrankyCoder.net
                  Gateway: MQTTClientGateway
                  MySensors: 2.3
                    Come on guys, we need someone that can build a WAF-o-meter to put on openhardware :D
                    • henninneH
                      henninneH
                      henninne
                      @Nca78 Do you have aby figures in how long the battery will last?
                      • henninneH henninne
                        @henninne said in ๐Ÿ’ฌ BlackCircle Sensor - High "WAF" Temp/Hum. sensor:
                        Hello, no unfortunately because I've not been doing sensors for long enough :D
                        But at least one year and probably more depending on the quality of the battery you use (chinese or brand name) and the quality of the radio communication.
                        First nodes with similar hardware have been running for a few months now, and are still at "100%" (= above 2.9V, still not eating in the bulk of the capacity) even those running on cheap chinese batteries.
                        • bisschopsrB
                          bisschopsrB
                          bisschopsr
                          Hi All,
                          Like the design thinking of this, although an older topic I did manage to get me one of these dishes. After taking it apart, I have one question that came to mind. Is the ventilation in the dish enough for the humity sensor? Is there any experience with that after running this sensor for a while?
                          Thx
                          Ralph
                          Domoticz, P1 meter interface, MySensors and more to come!
                          • bisschopsrB bisschopsr
                            Hi All,
                            Thx
                            Ralph
                            @bisschopsr said in ๐Ÿ’ฌ BlackCircle Sensor - High "WAF" Temp/Hum. sensor:
                            Hi All,
                            Thx
                            Ralph
                            Hello, yes I think it's enough, in fact there's much more ventilation than in many commercial sensors which only have a small hole. But it's a good test to make, I'll try to compare to a sensor out of it's enclosure to see if there's significant difference or delay.
                            With your input, this post could be even better ๐Ÿ’—
