716 Posts 111 Posters 703.1k Views 93 Watching
    @sundberg84 wow, that's a quite expensive booster :cold_sweat:
    sundberg84S
    sundberg84S
    @gohan - yes almost 5 times more expensive but I'm building it myself and it's probably five times better...
    @dakipro https://www.openhardware.io/view/4/EasyNewbie-PCB-for-MySensors check "Battery without step up booster (advanced users)"
      @gohan said in 💬 Easy/Newbie PCB for MySensors:
      The chip itself is less than 0.7$ on Arrow.com (so, legit one) so with additional components it should be 2$.
      But I see in the datasheet that typical operating current for 3.3V version is 45uA, added to the 15% of losses (max 85% efficiency) I'm a bit skeptical about the battery life you can get using it ?
      @sundberg84 if you find someone funding oscilloscopes, please send me the contact :D Else you have the captures in the datasheet for the most critical cases :P
      • Nca78N Nca78
        sundberg84S
        sundberg84S
        #396
        @Nca78 45 uA will last me a long time. On my dht nodes I aim for <100uA so if you sleep between readings that's ok. If this circuit would be much better than these cheap eBay boosters I'm happy even if they run at a couple of more uA
        Will let you know if I find oscilloscope funder 😉
        Nca78N 1 Reply Last reply
        • sundberg84S sundberg84
          @sundberg84 said in 💬 Easy/Newbie PCB for MySensors:
          But I still fail to see the interest of all the pain with the boosters and keeping the DHT22 which need "high" voltage of 3.3V when a sht21/si7021 is 3$ or less on aliexpress and can run way over 1 year with a simple cr2032 ? And if you use 2 AA it will run for 5 years. No problem with noise/stability, no booster to buy, just a 0.x$ big capacitor to add in parallel with the battery if you're using a CR2032 (and nothing if you're using 2 AA/AAA).
          dbemowskD sundberg84S D 3 Replies Last reply
          • Nca78N Nca78
            dbemowskD
            dbemowskD
            @Nca78 Another option that I went with is an HDC1080. The only problem with this one is that according to the datasheet, the recommended operating minimum voltage is 2.7v, where the si7021's minimum is 1.9v. When I was looking on ebay, these said that they were a replacement for the si7021, and it was my mistake not checking the datasheet before buying. They do seem to be working good though and I have had one of them running for about 5 months with no trouble so far.
            • Nca78N Nca78
              sundberg84S
              sundberg84S
              #399
              @Nca78 that's why I added the option without boosters. The only downside is that it's not that easy changing bod. When you get the booster function to work you can also run a motion dec in 3.3v for example. 3.3v will give you more sensor options.
              dbemowskD Nca78N 2 Replies Last reply
              • D
                dakipro
                wrote on last edited by dakipro
                #400
                I could just (do it very very ugly) and cut the vcc line near the board and solder it directly to the battery input?
                That way both arduino and radio will get battery power, and dht22 would still receive 3.3v? (then I can lower the BOD)
                Or would that not work due to some other connection?
                Also, would flashing pro mini to 1Mhz benefit battery consumption at all? (while still using 3.3 booster)
                (p.s. I stole your signature :) )
                  dbemowskD
                  dbemowskD
                  @sundberg84 That is one of the nice things about your board is it's flexibility.
                    Well, it is pretty easy IMHO, you just have to follow on of the many tutorials, and you learn a lot on the way :)
                    For motion detection isn't a booster a bad idea ? You can use AM312 anyway, very small and very stable, no soldering necessary to run it down to 2.7V meaning you can use most of the capacity of a lithum cell like CR123.
                    @dbemowsk thanks for the information I didn't even know about this sensor, looks like a very precise one with a very low power consumption. Can you link to where you bought it from I see nothing below 4$ on aliexpress ?
                    dbemowskD 1 Reply Last reply
                    • Nca78N Nca78
                      dakipro
                      @Nca78 said in 💬 Easy/Newbie PCB for MySensors:
                      The thing is that when people start with mysensors and arduinos, none of these are listed on Store page, so using them would be experimenting basically. And experimenting before you have even begun anything is a bit masochistic. At least in my case that is how I was thinking, so I ordered several of dht22, not really knowing that there are better/efficient alternatives. Maybe we can get those sensors in the store page, perhaps mention them on the examples page, noting that they are more efficient?
                        mickecarlsson
                        I went for the BME280, a little expensive, but it uses I2C and can be run from 1.71 volt to 3.3 volt.
                        • Nca78N Nca78
                          dbemowskD
                          dbemowskD
                          @Nca78 I believe this is the same one that I bought, at least the carrier board looks to be labeled the same. Mine was just listed as an HDC1080, where this one is listed as a GY-213V-HDC1080. I am assuming it is the same chip. When I bought the 2 that I have I paid $5/module shipped which after looking at this one was a bit high. Live and learn though.
                          http://www.ebay.com/itm/Low-Power-GY-213V-HDC1080-I2C-High-Accuracy-Digital-Humidity-Temperature-Sensor-/172666252980?hash=item2833b5eeb4:g:1C8AAOSwi7RZELpK
                          • D dakipro
                            sundberg84S
                            sundberg84S
                            @dakipro the dht22 is a hot potato not only due to 3.3 req but also quality... I know this has been requested for removal on homepage before and I think it's just a matter of someone makes a good example for another sensor to replace it with.
                            Yes you can cut the trace for vcc and hardwire it from bat if you want to lower bod.
                            And yes it's not that hard to lower bod... but harder than booster and therefore I choose the easiest option since that's my board goal.
                            I'm running 1mhz with booster and motion without problems... but same there, with a bad booster it will false trigger.
                            Nca78N D 2 Replies Last reply
                            • mfalkviddM
                              This might be the better example you are looking for https://github.com/mysensors/MySensorsArduinoExamples/pull/25
                                sundberg84S
                                sundberg84S
                                @mfalkvidd so all we need is some graphics and some text 👍?
                                  The only thing for the DHT sensors is they have their own pins, so you don't have to solder pins like on the breakout board of the I2C sensors. That's a good reason to keep them in example section otherwise a soldering iron is necessary, but it should at least talk about the existence of I2C sensors.
                                  • mfalkviddM
                                    Mod: Fuse/bootloader discussion moved to https://forum.mysensors.org/topic/7296/burning-fuses on request by @sundberg84
                                      dakipro
                                      @sundberg84 just to update success of the story, I cut the vcc trace and connected mini directly to battery, burned the fuses based on your advice here https://forum.mysensors.org/topic/7296/burning-fuses/8, and now the sensor goes down to 2.0v :)
                                      Booster is still used but only for dht22, radio and pro mini run directly from the battery.
                                      Thank you very much guys for help, now I have a foundation (and the knowledge) for more awesome sensors! :)
                                      • T
                                        Tommas
                                        Dear All!
                                        I would like to use this PCB. I would like power it with 5V, but I would like to use a 3.3V version mini Pro. How should I do it? I would like to use it from 5V (USB adapter) or battery 2xAA . Could I do it?
                                        Best regards,
                                          just power it from the usb adapter, the pro mini can work at 5V. If you have other HW not 5V tolerant you need to use the RAW pin and let the pro mini regulator to its job. It all depends on what you want to do with the node
