  3. 💬 MyMultisensors
💬 MyMultisensors
328pmotionatsha204amulti sensorhumiditytemperaturepirambiant lightlow powercoincell
176 Posts 33 Posters 95.0k Views 35 Watching
  • CarywinC
    CarywinC
    Carywin
    wrote on last edited by Carywin
    #136
    Okay, so here's some firmware I wrote for these multi-sensors: https://github.com/carywin/MySensors/tree/master/MyS_MultiSensor_revB
    Note that I'm currently using MySensors 2.2-beta from the development branch, to solve the some other problems I was having in my RFM69-based gateway. This sketch should still work fine with the released version of MySensors but I haven't tested it.I'm still testing and refining things here and there, but it should be a working base for people to build from. Of course you will need to change the MySensors #defines to match your network and radio settings.
    You'll probably notice that all of the sensors report under the same Child ID as a "Custom Sensor". This is because I'm using OpenHAB via an MQTT broker, so I don't really care if a certain sensor type matches with its provided variable types. If you're using a different controller, you may have to re-jig the Child ID/Variable types to match the known-working sensors on your controller.
    PIR Sensor:
    The PIR sensor is interrupt driven and will send a message when it receives more than 5 pulses in less than 5 seconds. After triggering, the interrupt is disabled for 60 seconds. If it receives fewer than 5 pulses then approx. 5 seconds after the last pulse it will reset the pulse counter. For the first 30 seconds after power-on, the PIR interrupts are disabled to allow the signal conditioning circuit time to settle. All of these values are configurable in the sketch. Note that I'm using GreyGnome's EnableInterrupt library, which you'll need to get from their Github.
    Lux Sensor:
    The lux level sensor will send a new reading to the controller when the lux reading moves outside a window threshold from the current reading, which is configurable in the sketch. It also takes a new reading after a certain period with no changes in lux, which is also configurable in the sketch.
    Note that you'll need the specific version of the OPT3001 library from the above link copied into your libraries folder. I modified the library to spit out raw values and allow the setting of thresholds, so the lux sensor can do most of the heavy lifting with regards to monitoring light levels and flagging an interrupt when it changes. Note that when the lux readings are very low, such as around sunrise and sunset, the threshold values are fixed to prevent excessive lux sensor messages.
    Door Sensor:
    The D3 pin input is set to trigger an interrupt on state change, which will send its new state to the controller on each change. It's pulled high by an on-board resistor so the input pullup is disabled to save energy.
    Temp & Humidity Sensor:
    Temperature and humidity are read at regular intervals (default 10 min), and new values only sent if the they have changed by 0.1 degC or 1% RH. If a certain number of intervals pass with no change (default 3 hours) they will send new values anyway. This way the controller can expire their readings after 3 hours and ignore stale values, and you can get an indication that maybe your sensor has failed. The interval times are configurable in the sketch. I'm using the Adafruit SI7021 library which you can get from their Github.
    Battery:
    Once a day by default the sensor will report battery voltage as a sensor, and remaining capacity as a percentage using the in-built reporting function. The full and empty thresholds as well as reporting interval are configurable in the sketch. Note that the method used to measure battery voltage has a large margin for error, but that this can mostly be calibrated out. For this reason you'll see a VCC calibration value that you should set by measuring each sensor's battery voltage with a multimeter, and comparing with its reported battery volts.
    WDT:
    I'm using the WDT during the time when the code isn't asleep, with a timeout of 2 seconds. This should be more than enough to send all of the sensor messages needed each cycle, but I haven't extensively tested that. I included it because in revision A I was suffering some kind of unknown lock up that would keep the MC awake and drain the coin cell battery in just a few hours. Of course the WDT is used by the library for timing the sleep intervals, so it gets re-enabled each wake up.
    Because timing how long an Arduino has been asleep is difficult without a RTC, the sleep time may vary somewhat depending on how many interrupts the sensor receives. Each time the MC is woken from sleep by an interrupt, it reduces the amount of time it will sleep next time by 25%. In addition to this, if more than 25 interrupts occur before a new round of sensor readings are taken, then the interval will be declared over and the sensors read again. These are crude methods for timing but so far it seem to be reliable in that the sensor neither sleeps forever nor spams excessively when receiving realistic rates of interrupt.
    I welcome any input people have on this project and ways that this might be improved.
      @Carywin
      Good work :+1:
      I will take a look when i'll have more time.
      • Adi VacaruA
        Adi VacaruA
        Adi Vacaru
        I was wondering why didn't you use a open drain comparator and you could have or-ed your outputs using only one MCU pin ?
          because there was already enough parts on board, for power consumption and wanted to save as much as i could with this design.
          The prototype had it though, but i removed it because that was useless as there are more than enough pins for this on mcu.
          • Adi VacaruA
            Adi VacaruA
            Adi Vacaru
            good answer ! it's not a good one for those of us that are less 'code gifted'. but anyway good work for the design.i would have to study how i can get it to work in code.
            • CarywinC
              CarywinC
              Carywin
              Does anybody know of a neat way to get this board to operate below 2.7V?
              From some reading it seems like the Atmega328 chip doesn't like running a crystal oscillator below 2.7V, but should be happy running from internal clock source. It seems like this might cause problems with libraries or serial comms though. Does anyone have experience with this or can point me towards a bootloader that might work?
              So far I've had a couple of these sensors fail after 2 months or so with battery volts around 2.65V. I was hoping for at least 12 months from a CR2450, but some of these sensors are sending >150 messages a day so I'd understand if it was shorter than that. Still, 2 months is not enough I think, and I hope I can tweak something to get it to work down to at least 2.0V, which might squeeze some more time out of it.
              Nca78N 1 Reply Last reply
              • CarywinC Carywin
                @Carywin hello.
                By default the BOD is set at 2.7V so the atmega will enter a boot loop when reaching this voltage.
                You need to update the fuses to set BOD at 1.8V or remove it (but it's better to keep one, o
                In some rare case it could write data in the wrong place and mess with the bootloader code).
                It's also necessary to update fuses if you want to use internal oscillator, it is less precise but you just need to use a lower baud rate when transferring sketches or debugging and you will be fine.
                I also suggest you run at 1MHz as long as you have no heavy computing to do. From it humble experience with CR batteries I always have better battery life at 1MHz compared to 8MHz.
                Look for tutorials about updating bootloader, there's a topic somewhere here called "various optiboot bootloader's" with précompilés bootloaders at different frequencies.
                You just need to put the file in the right directory after updating you boards.txt file and you can write bootloader from arduino interface. Fuses will be updated at the same time.
                To write bootloader don't worry about a programmer, just go the easy way with Arduino ISP sketch (in examples menu) on a nano, connect as explained in the many tutorials on the web (but use 3.3V for VCC to protect your radio), select "Arduino as ISP" as programmer and you're good to go :)
                  I usually use the MySensors Sensebender bootloader. It's 1.8V BOD and internal 8Mhz.
                  else like nca78 said there is this topic:
                  https://www.openhardware.io/view/33/Various-bootloader-files-based-on-Optiboot-62
                  • CarywinC
                    CarywinC
                    Carywin
                    I should have mentioned that I already set the BOD to 1.8V, but that doesn't help when the XTAL oscillator stops working at 2.6.
                    I'll try one of those other bootloaders and see what flies.
                    • CarywinC
                      CarywinC
                      Carywin
                      Okay I played around with this tonight and had some struggles. I couldn't get serial uploading working on any of the Gert Sanders bootloaders, so I had to use Arduino as ISP and Upload via Programmer.
                      However since I have encryption enabled, I need the AES key in EEPROM before my nodes will work.
                      So I had to enable the fuse that prevents EEPROM being erased when programming.
                      I experimented with using the 1 MHz oscillator option, but the sketch didn't run properly. It was sending 5-8 copies of every message at a very slow rate.
                      So now I'm trying the 8 MHz internal oscillator with BOD at 1.8 V to see if that works at a lower voltage than the crystal.
                      If anyone knows if MySensors works at 1 MHz, or what might cause it to send multiple copies of the same message, speak up please!
                      • CarywinC Carywin
                        @Carywin I don't have any problem at 1MHz, all my battery nodes run perfectly at that frequency.
                        But at 1MHz with internal oscillator the only speed you can safely use is 9600bauds.
                        • alexsh1A
                          alexsh1A
                          alexsh1
                          @scalz Can you please enlighten me re PIR? There are two inputs D6 and D7. I cannot understand why and how to manage them in a sketch? Previously, I only used one digital input.
                          scalzS 1 Reply Last reply
                          • alexsh1A alexsh1
                            #148
                            @alexsh1
                            You need to use pinchange interrupts. I won't reinvent a howto, there are multiple on google, like the one from Gammon here
                            https://gammon.com.au/forum/?id=11488&reply=6#reply6
                            pinchange can only detect toggle. it's up to you to detect the pin state in the interrupt routine.
                            Mysensors sleep() doesn't handle pinchange. so in this case, just use sleep(ms). and test for the irq flag when it wakes up
                            In a previous post, I extracted and showed you the few functions needed for this. I thought it was enough documented!
                            ISR (PCINT1_vect)
                              if (digitalRead(AMBIANT_LIGHT_PIN))
                                irqLight = false;
                                irqLight = true;
                            ISR (PCINT2_vect)
                              if((PIND & (1 << PIND6)) == 0x40 ) {
                            	  myPirSensor.pirhCount++;
                            		myPirSensor.irqPir = true;
                              if((PIND & (1 << PIND7)) == 0x80 ) {
                            	  myPirSensor.pirlCount++;
                            Function: pirIntEnable
                            Purpose : Enable pin change for PIR interrupt
                            Input   : -
                            Output  : -
                            Comments:
                            void pirIntEnable()
                              // Enable pin change for D6, D7
                              PCMSK2 |= bit (PCINT22);
                              PCMSK2 |= bit (PCINT23);
                              PCIFR  |= bit (PCIF2);   // clear any outstanding interrupts
                              PCICR  |= bit (PCIE2);   // enable pin change interrupts for D0 to D7
                            Function: pirIntDisable
                            Purpose : Disable pin change for PIR interrupt
                            Input   : -
                            Output  : -
                            Comments:
                            void pirIntDisable()
                              // Disable pin change for D6, D7
                              PCICR  ^= bit (PCIE2);   // disable pin change interrupts for D0 to D7
                            Function: lightIntEnable
                            Purpose : Enable pin change for OPT3001 interrupt
                            Input   : -
                            Output  : -
                            Comments:
                            void lightIntDisable()
                              PCMSK1 |= bit (PCINT9);
                              PCIFR  |= bit (PCIF1);   // clear any outstanding interrupts
                              PCICR  |= bit (PCIE1);   // enable pin change interrupts for A0 to A5
                            Function: Light_IntDisable
                            Purpose : Disable pin change for OPT3001 interrupt
                            Input   : -
                            Output  : -
                            Comments:
                              PCICR  ^= bit (PCIE1);   // disable pin change interrupts
                            So if we add this, in the MySensors Motion example, as a very basic example, this should look like this:
                            (untested, no time, but it should be close or maybe working)
                            // Enable debug prints
                            // #define MY_DEBUG
                            //#define MY_RADIO_NRF5_ESB
                            //#define MY_RADIO_RFM95
                            uint32_t SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
                            #define PIR_SETTLE_TIME 300000
                            #define PIR_INT_PINH 6   // The digital input you attached your motion sensor.
                            #define PIR_INT_PINL 7   // The digital input you attached your motion sensor.
                            // Initialize motion message
                            volatile bool irqPirHigh = false;
                            Pin change Interrupt Service Routine for D0 to D7
                            ISR (PCINT2_vect)
                              // Pin change interrupt!
                              // if one of the PIR pins is HIGH, we have a pulse
                              if((PIND & (1 << PIND6)) == 0x40 || (PIND & (1 << PIND7)) == 0x80 ) {
                                 irqPirHigh = true;
                            Comments:
                            void pirIntEnable()
                            Comments:
                              Function: before
                              Purpose : set pin states
                              Comments: before setup Mysensors init
                            void before()
                              hwDigitalWrite(PIR_INT_PINH, LOW);
                              hwPinMode(PIR_INT_PINH, INPUT);      // sets the motion sensor digital pinH as input
                              hwPinMode(PIR_INT_PINL, INPUT);      // sets the motion sensor digital pinL as input
                              // do setup stuff like waiting for pir to settle, send states at init etc.
                              sleep(PIR_SETTLE_TIME);
                              // enable pin change interrupt to enable PIR/motion detection
                              pirIntEnable();
                            	present(CHILD_ID, S_MOTION);
                              // irq ?
                              if (irqPirHigh) {
                                // We got a HIGH pulse on PIR pins!!
                                // increment a pulse counter, etc.
                                // test pulse counter then send or not
                                send(msg.set("1"));
                                irqPirHigh = false;
                              else {
                                // increment timer counters, to reset motion state etc
                                // do stuff
                              // Sleep until timer or a pin change interrupt
                              sleep(SLEEP_TIME);
                              Serial.println("Wake up!");
                            Remember it detect pin change, so it will wake up at each pin change state.
                            I can't make this example more noob and simple. then add all your variables for states, timers, improve power consumption etc, as you wish.
                            Or, it's perhaps easier to use the example from carywinn above. he posted his sketch which use a lib to handle pinchange. (on my side I don't need a lib for this, and it also saves memory).
                            I hope it's clear about pinchange, so I'm done at explaining it ;)
                            alexsh1A 1 Reply Last reply
                            • scalzS scalz
                              @alexsh1
                              ISR (PCINT1_vect)
                                  irqLight = false;
                                  irqLight = true;
                              ISR (PCINT2_vect)
                              Input   : -
                              Output  : -
                              Comments:
                              void pirIntEnable()
                              Input   : -
                              Output  : -
                              Comments:
                              Input   : -
                              Output  : -
                              Comments:
                              Input   : -
                              Output  : -
                              Comments:
                              // #define MY_DEBUG
                              ISR (PCINT2_vect)
                                   irqPirHigh = true;
                              Comments:
                              void pirIntEnable()
                              Comments:
                                Function: before
                              void before()
                                pirIntEnable();
                                // irq ?
                                if (irqPirHigh) {
                                  send(msg.set("1"));
                                  irqPirHigh = false;
                                else {
                                  // do stuff
                                sleep(SLEEP_TIME);
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @scalz said in 💬 MyMultisensors:
                              You are a star - I must admit that setting it up is a bit more fiddly. This is the first time I come across pinchange interrupts and excellent link you provided. Thank you
                              • alexsh1A
                                alexsh1A
                                alexsh1
                                Did anyone manage to find a good case for this sensor? Maybe 3D printed one?
                                • dbemowskD
                                  dbemowskD
                                  I will gladly design a nice 3D printable case if someone can donate a board. I see that there are multiple battery options, so I would design a case that would fit all battery options.
                                  • dbemowskD dbemowsk
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    #152
                                    @dbemowsk Thanks for volunteering!
                                    I can probably order new boards (they come in batches of 3) from oshpark and send you one or two. They are 1.93 x 1.00 inch (49.0 x 25.4 mm).
                                    Unfortunately, the boards I have with CR2450 battery holders and these are extremely fragile to be posted (they are soldered to little pads may come off easily).
                                    • alexsh1A alexsh1
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @scalz I did just notice that I have about 30-32uA sleep consumption, which is too high. This is very consistent through 3 sensors. Any ideas why I have such high consumption? Obviously, there is a chance my multimeter is not giving me correct reading, but so far my Brymen BM869S has been very much spot on!
                                        #154
                                        @alexsh1 looks weird, because there is nothing special on the board which could consumes like that, all parts are ultra low power..I tested mine with uCurrent gold device.
                                        so I would say if it's consistent on 3sensors boards, it could be:
                                        • software
                                        • bad caps, out of specs parts..(I usually order my parts at Mouser, arrow etc..)
                                        what do you get when using sketch J from gammon for example + shutdown sensors in case, no serial connected.
                                        alexsh1A 2 Replies Last reply
                                        • scalzS scalz
                                          • software
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @scalz Sketch J is giving 1.5mA consumption.
