  3. 💬 MDMSNode "Power"
💬 MDMSNode "Power"
arduinoatsha204ahlk-pm01mysensorsdc-dcnrf24l01atmega328prelayrfm69acs711
33 Posts 7 Posters 11.1k Views 5 Watching
  • kalinaK kalina
    Luckily, the device has started up without problems. Yesterday I tested it, even the kettle worked through the device (9A). Now I can share the source files of the project (already are refreshed).
    3_1495287454163_MDMSNode_Power_11.jpg 2_1495287454163_MDMSNode_Power_10.jpg 1_1495287454163_MDMSNode_Power_9.jpg 0_1495287454163_MDMSNode_Power_8.jpg
    Samuel235
    @kalina - I knew you could do it o.O
    MySensors 2.1.1
    • kalinaK kalina
      sundberg84S
      sundberg84S
      @kalina what is the purpose of the vias on the AC traces? Thermal relief from the components on the other side?
      kalinaK 1 Reply Last reply
      • sundberg84S sundberg84
        kalinaK
        kalinaK
        kalina
        @sundberg84, vias connect the AC traces on the TOP and BOT layers (see picture). This was done for reduce resistance of the conductors and distribute the heat caused by the flow of large currents through them.
        • J
          J
          JWB
          Kalina,
          What CAD program are you using for this project? The board file does not seem to be Eagle or KiCad.
          • J JWB
            Kalina,
            kalinaK
            kalinaK
            kalina
            @JWB said in 💬 MDMSNode "Power":
            I use Altium Designer.
            • L
              L
              lagrosso69
              hello have you a sample program to try MDMSNode power
              thank you
              • L lagrosso69
                thank you
                kalinaK
                kalinaK
                kalina
                #22
                @lagrosso69 said in 💬 MDMSNode "Power":
                Hi @lagrosso69. Do you mean a sketch? Did you order pcb and solder MDMSNode "Power" by yourself?
                L 1 Reply Last reply
                • kalinaK kalina
                  L
                  L
                  lagrosso69
                  @kalina no i bought your mdmsnode by ebay and i would love to try it here
                  • L lagrosso69
                    kalinaK
                    kalinaK
                    kalina
                    #24
                    @lagrosso69
                    OK, the MDMSNode "Power" is selling with a programmed bootloader and a sketch inside.
                    • kalinaK kalina
                      @lagrosso69
                      L
                      L
                      lagrosso69
                      Hi@kalina ok thank you
                        sindrome73
                        would it be possible to have the ACS711 sketch ???
                        • S sindrome73
                          kalinaK
                          kalinaK
                          kalina
                          @sindrome73 Of course, yes. It's a matter of time. I have a lot of tasks at work and I can't do this right now.
                            sindrome73
                            thanks .... I wait because I do not know how to use it
                              sindrome73
                              Hi, if you have a minute of memories of me ???
                              • S sindrome73
                                kalinaK
                                kalinaK
                                kalina
                                @sindrome73 Hi, time for what?
                                  sindrome73
                                  for a sketch piece where the ASC711 is used. because I would like to use it for a similar project, but I do not know how to use it to have a reading for AC. so since you used an asc711 in your project, I thought you could help me ....
                                  Thanks 10000
                                  • S sindrome73
                                    Thanks 10000
                                    kalinaK
                                    kalinaK
                                    kalina
                                    @sindrome73 OK, but it could be in 1-2 weeks, as i wrote earlier, i very busy now...
                                      sindrome73
                                      Ah.... Ok :thumbsup:
