  3. 💬 MDMSNode "Power"
💬 MDMSNode "Power"
arduinoatsha204ahlk-pm01mysensorsdc-dcnrf24l01atmega328prelayrfm69acs711
33 Posts 7 Posters 11.1k Views 5 Watching
  • kalinaK kalina
    Luckily, the device has started up without problems. Yesterday I tested it, even the kettle worked through the device (9A). Now I can share the source files of the project (already are refreshed).
    3_1495287454163_MDMSNode_Power_11.jpg 2_1495287454163_MDMSNode_Power_10.jpg 1_1495287454163_MDMSNode_Power_9.jpg 0_1495287454163_MDMSNode_Power_8.jpg
    sundberg84S
    sundberg84S
    @kalina what is the purpose of the vias on the AC traces? Thermal relief from the components on the other side?
    kalinaK 1 Reply Last reply
    • sundberg84S sundberg84
      kalinaK
      kalinaK
      kalina
      @sundberg84, vias connect the AC traces on the TOP and BOT layers (see picture). This was done for reduce resistance of the conductors and distribute the heat caused by the flow of large currents through them.
      • J
        J
        JWB
        Kalina,
        What CAD program are you using for this project? The board file does not seem to be Eagle or KiCad.
        • J JWB
          Kalina,
          kalinaK
          kalinaK
          kalina
          @JWB said in 💬 MDMSNode "Power":
          I use Altium Designer.
          • L
            L
            lagrosso69
            hello have you a sample program to try MDMSNode power
            thank you
            • L lagrosso69
              thank you
              kalinaK
              kalinaK
              kalina
              #22
              @lagrosso69 said in 💬 MDMSNode "Power":
              Hi @lagrosso69. Do you mean a sketch? Did you order pcb and solder MDMSNode "Power" by yourself?
              L 1 Reply Last reply
              • kalinaK kalina
                L
                L
                lagrosso69
                @kalina no i bought your mdmsnode by ebay and i would love to try it here
                • L lagrosso69
                  kalinaK
                  kalinaK
                  kalina
                  #24
                  @lagrosso69
                  OK, the MDMSNode "Power" is selling with a programmed bootloader and a sketch inside.
                  • kalinaK kalina
                    @lagrosso69
                    L
                    L
                    lagrosso69
                    Hi@kalina ok thank you
                      sindrome73
                      would it be possible to have the ACS711 sketch ???
                      • S sindrome73
                        kalinaK
                        kalinaK
                        kalina
                        @sindrome73 Of course, yes. It's a matter of time. I have a lot of tasks at work and I can't do this right now.
                          sindrome73
                          thanks .... I wait because I do not know how to use it
                            sindrome73
                            Hi, if you have a minute of memories of me ???
                            • S sindrome73
                              kalinaK
                              kalinaK
                              kalina
                              @sindrome73 Hi, time for what?
                                sindrome73
                                for a sketch piece where the ASC711 is used. because I would like to use it for a similar project, but I do not know how to use it to have a reading for AC. so since you used an asc711 in your project, I thought you could help me ....
                                Thanks 10000
                                • S sindrome73
                                  Thanks 10000
                                  kalinaK
                                  kalinaK
                                  kalina
                                  @sindrome73 OK, but it could be in 1-2 weeks, as i wrote earlier, i very busy now...
                                    sindrome73
                                    Ah.... Ok :thumbsup:
