  3. nRF5 action!
nRF5 action!
    The chip is now owned by Skyworks: http://www.skyworksinc.com/uploads/rfx/RFX2411N_DataSheet.pdf
    JokgiJ 1 Reply Last reply
      JokgiJ
      JokgiJ
      Jokgi
      @NeverDie As I may have mentioned before. This was a limited run of prototypes (100 total) designed by RF AXIS and built by Xungtong.. My understanding is that this device is being deemphasized by Skyworks in favor of the SKY661xx family..
      • JokgiJ Jokgi
        @Jokgi
        Do you happen to have the datasheet? The closest I've been able to find is: http://www.mouser.com/ds/2/472/rfaxis_RFX2411N Eval Board Summary and Technical N-952564.pdf
        which isn't quite on-point, but I may have to make do with.
        I had thought it would somehow automagically select the better antenna for receiving, but it looks like it wants me to make that selection myself. So, this may work better with longer preambles I suppose, to give enough time to measure the RSSI on each and then decide.
        JokgiJ NeverDieN 2 Replies Last reply
          @Jokgi
          JokgiJ
          JokgiJ
          Jokgi
          @NeverDie The datasheet for the RFX2411N?
          • JokgiJ Jokgi
            JokgiJ
            JokgiJ
            Jokgi
            @Jokgi The only datasheet I have states that it is confidential. Therefore I cannot share it. However if you contact Skyworks they may be able to get you a copy. At the time I received it one needed to fill out a form on RF Axis site and then the file would be sent. Are there any particular parameters you are interested in?
            • JokgiJ Jokgi
              @Jokgi
              Just which pins on the nRF52832 are connected to which control pins on the RF Front End. I just now checked with a continuity meter, and it looks like none of them are. So, it would appear that I'll need to wire the pin connections external to the PCB, which is weird, but maybe that's just how it is.
              • scalzS scalz
                I agree with @d00616 points above.
                And, sure bluetooth would be nice for interacting or debugging.
                In my opinion, maybe I'm wrong, for my network, I would prefer MySensors NRF ESB, in general.
                • "more secure" than bluetooth. "harder" to access Mysensors ESB than bluetooth for example, plus some security issue that can happen with bluetooth, phones..
                • more devices in a network
                Not with bluetooth mesh, you can have thousands of nodes ;)
                scalzS 1 Reply Last reply
                  @Jokgi
                  JokgiJ
                  JokgiJ
                  Jokgi
                  wrote on last edited by Jokgi
                  #1179
                  @NeverDie Hello, If you are referring to that Prototype Board with the Nordic logo on it then it was being controlled by GPIO and by the Bluetooth Low Energy stack (Softdevice) You can read more about it here.. https://devzone.nordicsemi.com/blogs/831/palna-support-in-s132/.
                  As I mentioned before. there is no good way to control the PA in a proprietary mode, only when using BLE. Regardless, I have asked if it is ok to share the schematic that relates to that PA board and I will let you all know. And about the question about antenna switching. This was never implemented in the Softdevice. Any antenna switching would need to be done in the application.
                  See if this chart helps.
                  • Nca78N Nca78
                    #1180
                    not without some latency :)
                    but I agree, I forgot this new mode :+1:
                    I just prefer to keep my nodes "hidden" for security. so no BLE network for me. I will just have some restricted access to it I think..
                    • JokgiJ Jokgi
                      @Jokgi
                      Thanks! Yes, those three tables are exactly what I was looking for.
                        #1182
                        https://www.openhardware.io/view/489/BT830X-Power-Amplified-nRF52832-Remote-Control
                          #1183
                          I just noticed a very clever thing that Fanstel did: their nRF52 modules all have the same land pattern and pinout. That means you can upgrade from a regular nRF52832 to a power amplified version, or even an NRF52840 (when they become available), by just dropping the upgrade module into the same position on the PCB. i.e. you can run all the different modules from the same PCB design. Pretty cool. I like it. :)
                            @NeverDie but how will you spend all the time you save by not having to create new boards all the time? ;-)
                              Yeah, not just that, but also not having to waste all that time waiting for each new board to come back from the fab. :)
                                @Jokgi
                                #1186
                                I suppose an easy solution would be to have a remote node send repeated packets, and I just program the RFAxis to toggle between its two antennas after allowing sufficient dwell time per antenna. That way it's more likely to receive at least one of the packets.
                                All in all, though, I think maybe having two separate radio receivers (since they're cheap anyway) for a gateway is probably better than having one radio receiver, with the burden on the firmware to select which antenna to receive on.
                                Any thoughts on this?
                                  @Jokgi
                                  JokgiJ
                                  JokgiJ
                                  Jokgi
                                  @NeverDie 0_1508367805179_RD-nRF52-RFX2411N-REV2.zip Hello All -- For your viewing enjoyment. The Schematic and layout files for that nRF52840 and RFX2411n board you have. (If it is version 2 which did have the big Nordic logo on it. )
                                  I think you may know this already but this bears repeating. This is not a Nordic board. Nordic Semiconductor's tech support will probably not know anything about this board. Also there is a difference between the RFX2411 and the nRF2411N. (N for Nordic) It is not the same device.
                                    On a different topic, regarding the Ebyte modules, I'm noticing that they are much more likely to miss a packet if being run at 2.1v than if it's being run at, say, 3.3v. I've tried this now on two different modules, and the results are repeatable. It's a preliminary result, because so far I've only tested it with respect to the "listen mode."
                                      JokgiJ
                                      JokgiJ
                                      Jokgi
                                      #1189
                                      @NeverDie Is this the board with a PA on it or stand alone nRF5x part? If with a PA what is the rated voltage of the device?
                                      Depending on the Nordic part the nRF5x can run from 1.7 (or 1.8) to 3.6vdc. Note that the nRF51 cannot run with the DC / DC under 2vdc. The nRF52 does not have that restriction and the DC/DC can be used throughout the full voltage range..
                                      • JokgiJ Jokgi
                                        I observed it on Ebyte's E73-2G4M04S on this board: https://www.openhardware.io/view/471/Ebyte-nRF52832-Small-Breakout-Board
                                        while running in DCDC mode. The E73-2G4M04 has no PA.
                                        For now, I'm just reporting the finding, in case anyone else has noticed it. Also, it's a very early result. If there's no known reason to suspect the nRF52832 as a possible cause (i.e. no erratas or the like), then I'm glad to hear it.
                                          #1191
                                          OK, I fixed the problem by increasing the size of the listen window by another 30 microseconds (which is the smallest granularity that the RTC offers). What this probably means is that some aspect of the wake-up process (for instance, perhaps the amount of time it takes for the high frequency oscillator to come up to speed) is taking a wee bit longer when the module is powered at the lower voltage than when it is powered at 3.3v.
