1.1k Posts 105 Posters 792.8k Views 98 Watching
  • sundberg84S sundberg84
    I think we need a thread (and it would be fun) where old and new users can post a picture with a small text with "look what I did today". Its a steal from another forum i watch but its a really fun thread to follow like-minded people in their daily work.
    The rules are simple - keep it simple with one picture (or a few) with a small text including a small explanation. If you want to comment on a particular post please create a new thread ("Reply as topic") or keep it really short. The idea is to get a flow with pictures. It does absolutely not needs to be a finished project - it can be a sketch of an idea or a process of something. Anything you can take a picture off from the MySensors / Home automation world.
    I hope this is not violating any forum rules and if it does, please remove - but I think this can be a fun addition to the forum.
    Let me start!
    Today i created a second motion detector based on Slim Node from @m26872. Its a 1mhz bootloader and modified hc-sr501(3.3v "hack"). Its currently "deployed" in my kitchen (replaced the old one) in the spice-rack above the stove... low WAF but high camouflage! Might work :)
    Great idea @sundberg84
    This prompted me to finally get started on something that I've put off for far too long, especially considering how little work it was.
    I'm still using dupont wires to connect my radios, despite better solutions such as the easypcb being available. But this quick little trick makes it easier to switch the radio modules.
    https://youtu.be/Jeg0kS9AcgY
    You'll need:
    • Dupont female-female wires (I use 10cm), https://www.aliexpress.com/item/Free-Shipping-1lot-40pcs-lot-10cm-2-54mm-1pin-femal-to-femal-jumper-wire-Dupont-cable/32329983091.html
    • 4x2 jumper wire connector/header from a 620 pcs kit, https://www.aliexpress.com/item/620-Pcs-1-Set-Jumper-Wire-Cable-Pin-Header-Connector-Kit-Male-Crimp-Female-Pin-Terminal/32816829548.html
    • NRF24L01+ radio module, https://www.aliexpress.com/item/Free-shiping-best-prices-10pcs-lot-NRF24L01-NRF24L01-Wireless-Module-2-4G-Wireless-Communication-Module/674686536.html
    • Small screwdriver
    In the future, I plan to build the other end of the connector for Pro Mini and Rasbperry Pi.
    LaranL F 2 Replies Last reply
    • sundberg84S
      sundberg84S
      Today I had to make a quick debug to my dorrbell node. It stopped working for some reason some weeks ago but the node was fine. It was due to Domoticz update didn't recognise the node anymore. Since it's down I'm going to change from a mechanic trigger to a octocoupler... Any day now.
      I also have a new outdoor node testing for some weeks npw... Maybe tomorrow will be a Mysensors day and I can do the enclosure and deploy.
      I 1 Reply Last reply
      • mfalkviddM
        Today I learned how to cut and merge video clips on the command line using ffmpeg (and strip the audio which only contains my breathing), producing this video:
        https://youtu.be/5CIWxZEt9NE
        I also learned that maybe I shouldn't recond at 50fps using the highest quality codec, because uploading videos take a lot of time.
        • mfalkviddM
          Today's build is a new raspberry pi gateway to assist troubleshooting in this thread. I use the connectors that I created earlier. Great to be able to switch radio module in the connector.
          The binder clips to the left are great for keeping network and power cables in place.
            @mfalkvidd
            Is your use of cables for temporary testing, or is it permanent as far as you're concerned? If the later, I'm surprised you haven't yet found a PCB solution openhardware.io that you prefer.
              @mfalkvidd
              @NeverDie I guess it could be considered permanent by now. I have been using MySensors for more than 2 years and I've never gotten round to using any of the pcbs.
              gohanG 1 Reply Last reply
                @mfalkvidd in fact if nobody is going to touch the area around the raspberry, jumper wires just work fine. I'm waiting for the result on the double radio pcb hat for raspberry.
                • tbowmoT
                  tbowmoT
                  tbowmo
                  I'm in the mid of building a more complex sensor setup for the chicken coop, where I use dupont cables all over (actually, it's more or less the first sensor that I use them in..) I do not expect to poke around in the wires, after I have mounted it in the chicken coop at some point in time. So I recon it's going to be ok.. (And it will be hot glued into a large weatherproof junction box)
                    Rule #1 from what I've read is to keep connections as short as possible, especially when radio is involved. However, if you're not suffering from using long wires, then, well, I guess why not? If this is a prevailing belief, then maybe it does at least partially explain the remarkably low uptake of openhardware.io projects.
                      I personally use only short dupont wires as they give you some flexibility but without too much "spaghetti" wiring 😁
                        Guys, you are deviating from the OPs thread "rules" ;)
                        • sundberg84S
                          sundberg84S
                          I guess the thread can evolve the way it does - but in the same time, if there are a interesting ongoing discussion all mods are more than welcome to lift that discussion out for a own thread and if so we can keep this thread as intended?
                          • micahM
                            micahM
                            micah
                            Here is a project I finished this weekend.... 5m LED strip controller (the cover is off for the photo)
                            I think you can say I've come quite far since my first ever arduino build... lol
                            • sundberg84S
                              sundberg84S
                              Last night i continued improving my Logger (mostly protecting the serial input and make sure it can handle incoming serial logic from everything from 2.5v to 5v into my 3.3v system). I finally bought myself a oscilloscope so now I have the longest list possible of things I want to improve... (EasyPCB series, Booster performance?, some relays... the list goes on).
                              0_1508830436618_upload-c1713104-7660-4530-b88e-7a8a7cadc109
                              • sundberg84S
                                sundberg84S
                                Tonight I changed the mechanic trigger to a optocoupler on my doorbell node. I went with some sort of half good solution.
                                8v AC (Doorbell activated) -> Diode (Not a full bridge, just a support capacitor) -> Voltage divider -> optocoupler > D3. Worked out great, but might be one of the ugliest nodes I have :)
                                Testing/Soldering/Deployment:
                                0_1508867567585_upload-f1e406e5-6af9-4433-8108-07badff5200d
                                  I changed the form of my integrated nRF52832-protoboard:
                                  Previously, I was using: https://www.openhardware.io/view/472/Ebyte-nRF52832-Prototyping-Board
                                  • sundberg84S
                                    sundberg84S
                                    Today I made some small changes to a battery node. Once again I had copy/pasted all battery code but forgot the internalReference in setup() (since I copy from another node sketch). So I now created a dedicated file for battery code I can use to copy from... and once again I remembered I'm not a coder... But it works.
                                    https://github.com/sundberg84/MySensors2.0.0/blob/master/BatteryMeasurer/BatteryMeasurer.ino
                                    dbemowskD 1 Reply Last reply
                                      dbemowskD
                                      dbemowskD
                                      @sundberg84 Not to be critical or get off topic, but it's percent, not procent
                                      • R
                                        R
                                        robosensor
                                        Simple RS485 gateway and node for two BME280 sensors:
                                          Made a small tool to simplify the extraction of serial debug data from a 10-pin IDC connector and reading it from a typical 6-pin FTDI module.
                                          The 10-pin IDC connector is what's most commonly used for programming nRF5x modules.
