  3. RPI Gateway - !TSM:INIT:TSP FAIL
19 Posts 6 Posters 7.8k Views 5 Watching
  • M Offline
    M Offline
    maxdor
    Hello everybody,
    I try to make a Rapberry Pi Ethernet Gateway with an NRF24 card. The NRF has a 220uf capacitor, soldering direct on the board.
    The problem is, the RPI does not detect the NRF24. On an arduino, the NRF24 is working fine as a serial Gateway. I have tested it with two different NRF and on a RPi 1 and a RPI 2 and different cable.
    All is made like in this Tutorial.
    Exactly what I have done:
    sudo su
    cd MySensors
    ./configure --my-transport=nrf24
    ./configure --my-gateway=ethernet --my-port=5003
    raspi-config
    SPI activated and reboot......
    make
    sudo ./bin/mysgw -d
    Now I get everytime:
    root@raspberrypi:/home/pi/MySensors# sudo ./bin/mysgw -d
    mysgw: Starting gateway...
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: !TSM:INIT:TSP FAIL
    mysgw: TSM:FAIL:CNT=1
    mysgw: TSM:FAIL:PDT
    mysgw: TSM:FAIL:RE-INIT
    mysgw: TSM:INIT
    mysgw: TSM:FAIL:CNT=2
    mysgw: TSM:FAIL:PDT
    mysgw: TSM:INIT
    mysgw: TSM:FAIL:CNT=3
    mysgw: TSM:FAIL:PDT
    Does someone know, what else could wrong? :(
    Kind regards
      Try development branch
      • M Offline
        M Offline
        maxdor
        Thanks for the answer.
        Sorry, I'm new to Mysensors and I don't understand what is meaning with "development branch".
        gohanG 1 Reply Last reply
        • M Offline
          M Offline
          mickecarlsson
          You have run ./configure twice, run it like this:
          ./configure --my-transport=nrf24 --my-gateway=ethernet --my-port=5003
          • M maxdor
            @maxdor when you do the git clone replace master with development: it's also written in the guide.
            • M Offline
              M Offline
              mickecarlsson
              git clone https://github.com/mysensors/MySensors.git --branch development
              ./configure
              make
              sudo make install
              sudo /usr/local/bin/mysgw -d
              This is how I did it on a Raspberry Pi 3.
              • M Offline
                M Offline
                maxdor
                Thanks for the help.
                I have made a new install with developement branch, but after the "make", I get this error:
                gcc -MT build/drivers/BCM/bcm2835.o -MMD -MP -march=armv6zk -mtune=arm1176jzf-s                        -mfpu=vfp -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINU                       X_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003  -Ofast -g -Wall -Wextra  -I.                        -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/bcm2835.c -o build/dri                       vers/BCM/bcm2835.o
                drivers/BCM/bcm2835.c: In function ‘bcm2835_delayMicroseconds’:
                drivers/BCM/bcm2835.c:441:40: error: expected ‘)’ before ‘PRIu64’
                   printf("bcm2835_delayMicroseconds %" PRIu64 "\n", micros);
                drivers/BCM/bcm2835.c:441:37: warning: spurious trailing ‘%’ in format [-Wformat                       =]
                Makefile:102: recipe for target 'build/drivers/BCM/bcm2835.o' failed
                make: *** [build/drivers/BCM/bcm2835.o] Error 1
                sudo: ./bin/mysgw: command not found
                SPI is activated.
                  @hek do you think it is a compiler issue or a bug?
                  • M maxdor
                    SPI is activated.
                    @maxdor looks like the same problem as reported in https://github.com/mysensors/MySensors/issues/955
                    Add --extra-cxxflags="-D__STDC_FORMAT_MACROS" to the configure command
                      T Offline
                      T Offline
                      tchoblond59
                      @mfalkvidd I have the same issue. Even with --extra-cxxflags="-D__STDC_FORMAT_MACROS".
                      • T tchoblond59
                        @tchoblond59 could you post the full configure command you used and info on what system you are trying to build on?
                        gcc -v |& grep 'gcc version'
                        grep PRETTY_NAME /etc/os-release
                        • T Offline
                          T Offline
                          tchoblond59
                          wrote on last edited by tchoblond59
                          @mfalkvidd
                          ./configure --my-transport=nrf24 --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --extra-cxxflags="-D__STDC_FORMAT_MACROS"
                          gcc version 6.3.0 20170516 (Raspbian 6.3.0-18+rpi1)
                          PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
                            Do you get same error even if you compile as ethernet gateway?
                            • T Offline
                              T Offline
                              tchoblond59
                              make clean
                              make
                              Same error after this.
                              • T tchoblond59
                                @mfalkvidd
                                @tchoblond59 thanks. So far, it seems your system that is unable to compile is the same as the system I was able to compile cleanly on. I wonder were the difference is.
                                • T Offline
                                  T Offline
                                  tchoblond59
                                  I open an issue on github
                                  https://github.com/mysensors/MySensors/issues/980
                                  Hope i will be able to fix it. I will try to reinstall a raspbian when i have some times
                                  Thanks for the help
                                  • T Offline
                                    T Offline
                                    tchoblond59
                                    For the moment i am able to compile by going to previous commit
                                    git checkout 9e5a1e32
                                    make
                                    (I haven't test with a nrf24 but i can launch mysgw )
                                    • I Offline
                                      I Offline
                                      Inso
                                      I chave the exact same issue. Made the installation of Raspi and MySensors quite often last days because of problems with the NRF24. Now, as it finally worked, the installation of my clean final version crashes -.-.
                                      • M Offline
                                        M Offline
                                        mickecarlsson
                                        wrote on last edited by mickecarlsson
                                        Same error here.
                                        gcc version 4.9.2 (Raspbian 4.9.2-10)
                                        PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
                                        Replacing
                                        with
                                        printf("bcm2835_delayMicroseconds %lld\n", micros);
                                        in file drivers/BCM/bcm2835.c fixed the issue.
                                        EDIT:
                                        It did compile, but it segfaults when I try to start mysgw
                                        Time to get a fresh copy from git
                                        EDIT2:
                                        Fix from commit in bug report fixed it.
                                        12.1k
