1.1k Posts 105 Posters 795.9k Views 98 Watching
    @SquareKinematics
    Very useful to have. Not sure if you're aware, but you can buy PoE power adapters off the shelf. Even Amazon sells them. You select the output voltage you want with a slide switch.
    sinczeS
    sinczeS
    sincze
    MySensors Evangelist
    And so it it almost Christmas...
    Jolly jolly.. wel actually no....
    We have had wet feet from the central heating system serveral times now around Christmas or New Year.
    Causing a wet floor and other possible disasters. Yes I know.. A Central Heating Mechanism should not leak, you could try putting a bucket underneath... But that is not 'that home automation' smart that I was looking for.
    So to detect a leakage.... I came up with this some time ago.
    Pretty standard, a few wires... a Mysensors Node... and Pushover to send me urgens notifications about the leakge.
    0_1512750844649_Leakage.jpg link url))
    And ladies and gentlemen it actually works as you can see in the pushover sreenshot, it kicked off today.
    • sinczeS sincze
      @sincze You could also put some salt into your tray for added conductivity when things get wet.
      sinczeS rmtuckerR 2 Replies Last reply
        sinczeS
        sinczeS
        sincze
        @neverdie Great tip, this will resolve in even a quicker response during a flood right?. I already added toilet paper as cover for a smooth moist/water distribution. Lets add some salt to that and hopefully never see an error message again. But I wont bet a bitcoin on that ;-).. Happy with this cheap solution.
          well, since you are not using distilled water, normal tap water should have enough conductivity
          • sinczeS sincze
            manutremo
            @sincze How did you design the detection circuitry? Are you using an analog or a digital input?
            Tap water should work without adding more conductivity - in my case I just designed something similar but I wanted to detect an overfill of osmosis water, which is similar to distilled. I had issues with getting it to work through a digital input, so I just built a voltage divider capable of detecting the small change in conductivity. I also added a capacitor to be sure that no false alarms would be received because of noise in the lines. It's been working perfect for days now.
            sinczeS 1 Reply Last reply
              rmtuckerR
              rmtuckerR
              rmtucker
              @neverdie said in What did you build today (Pictures) ?:
              Be very careful using salt,i killed an SI7021 doing something similar.
              I got up one morning and found the sensor covered in white fur and it was dead:white_frowning_face:
              • andrewA
                andrewA
                andrew
                2 gang EU type livolo customisation, from theory to product... still in progress.
                2_1512829925723_small_20171112_011444.jpg 1_1512829925723_small_20171101_175752.jpg 0_1512829925722_small_20170114_124152.jpg 2_1512829936757_small_20171119_155004.jpg 1_1512829936757_small_20171118_202738.jpg 0_1512829936757_small_20171112_011725.jpg !
                • andrewA
                  andrewA
                  andrew
                  0_1512830079874_small_20171119_155404.jpg 0_1512830092134_small_20171119_163354.jpg 0_1512830107562_small_20171119_163849.jpg 0_1512830119867_small_20171119_164745.jpg 0_1512830130032_small_20171119_165717.jpg 0_1512830150237_small_20171203_092353.jpg 0_1512830159490_small_20171203_163658.jpg 0_1512830169403_small_20171207_194213.jpg
                  NeverDieN sundberg84S sinczeS andrewA 4 Replies Last reply
                  • andrewA andrew
                    @andrew Wow!
                    • M manutremo
                      sinczeS
                      sinczeS
                      sincze
                      @manutremo As the water indeed is 'rock' solid here in the area I was pretty succesfull using the digital pins. A short... when there is a water connection or open... when there is no connection. No false alarms. Only legit... Each leakage costs me money to get some guy to fix it for me. But at least the floor is not ruined anymore as I had that the first 2 times.
                      • rmtuckerR rmtucker
                        sinczeS
                        sinczeS
                        sincze
                        @rmtucker ai ai . what happened with the salt???
                        • andrewA andrew
                          sinczeS
                          sinczeS
                          sincze
                          @andrew Wow indeed.
                          • sinczeS
                            sinczeS
                            sincze
                            Almost Christmas, that means... Lights. In this case programmable 5v LED's that are driven by an Arduino and controlled via Mysensors & Domoticz.
                            While the arduino sketch has a lot of tricks (showing animations).. I still have to figure out HOW I can stop an animation from playing when I want to see the next one.. It now completes the first animation.. and then starts the one I selected. It needs to break from the function if a new message comes in. I'll have to look for some examples in the forum.
                            • rozpruwaczR
                              rozpruwaczR
                              rozpruwacz
                              @andrew I see that You put the nrf module between two pcbs. Do You have issues with reception ? Because the boards may act as a shielding.
                              andrewA 1 Reply Last reply
                              • rozpruwaczR rozpruwacz
                                andrewA
                                andrewA
                                andrew
                                @rozpruwacz I try to avoid filled copper areas, which could act as RF blockers. as I mentioned, everything is still in progress, in-wall tests will just come. hopefully I'll have time for that in the next 2 weeks.
                                mtiutiuM 1 Reply Last reply
                                • mfalkviddM
                                  #170
                                  (CNC milling forked to separate thread. It got too interesting :-) )
                                  • andrewA andrew
                                    mtiutiuM
                                    mtiutiuM
                                    mtiutiu
                                    @andrew
                                    I know that this is not the right place to ask but I'm very curious how do you overcome the fact that in EU there's only the live with in the walls for light switches. I saw that you used a HLK-PM0xx module for testing which needs both live and null. Or maybe your "in-wall" wiring is different... Anyways congratulations for your work so far.
                                    • mtiutiuM mtiutiu
                                      @andrew
                                      andrewA
                                      andrewA
                                      andrew
                                      wrote on last edited by andrew
                                      #172
                                      @mtiutiu well, that's the dirty hacking part :) electricians will probably not like it.
                                      so, for first, I've a different approach to control my lamps compared to other in-wall switches and dimmers, due to the fact, that I won't switch the mains directly, with the switch. I have LED ceiling lamps which operate at 12V, but the power supplies (230V to 12V) are in the lamps' body. it could be possible to switch their mains on/off thus to turn the lamps on/off (this is what I do now with standard switches), but it is not possible to dim the lights this way.
                                      to be able to dim the LEDs as well I'll have a lamp controller node right after the switching PSUs in each lamp. this will be controlled with the in-wall switches (and could be controlled with other nodes/gateways as well), over the air only.
                                      as all of my wall lamp switch have dual wiring (one line in, two switched line out) I planned the following setup:
                                      one switched line will be "re-assigned" and wired to N at the lamp. this way, at the wall switch I'll have both L and N. the other switched in-wall line will still forward the L to the lamp, but it will do it directly, to continuously operate the lamp's PSU, which also powers the lamp's controller module.
                                      the controller will be always on and it will control both the dimming (PWM on the 12V) and the switching wich basically allowing or disabling the 12V from the PSU to the LEDs.
                                      the in-wall switch will be basically just a radio remote controller this way, but operating from the mains, without any need of batteries.
                                      I hope that my explanation wasn't too complicated :)
                                      • fernando alvarez buyllaF
                                        well today finally i decide to change to c.h.i.p. as a controller with domoticz an amazing device but too bad for the product that got really bad customer support, ( if you planning to buy a c.h.i.p. read the forum first to get all the problems)
                                        this is my controller using a chip, arduino nano
                                        planing to chage the nano to a nodemcu
                                        • fernando alvarez buyllaF fernando alvarez buylla
                                          #174
                                          @fernando-alvarez-buylla Is the C.H.I.P. better than a Raspberry Pi Zero? At least with a Pi, you know there's going to be support.
                                          https://www.adafruit.com/product/2885?gclid=EAIaIQobChMIrMm-lcv-1wIVxSSBCh1PJQB3EAQYASABEgItsvD_BwE
                                          https://www.adafruit.com/product/3400
                                          fernando alvarez buyllaF 1 Reply Last reply
