1.1k Posts 105 Posters 795.9k Views 98 Watching
  • scalzS scalz
    @Nca78
    It was just a private joke :) If I inspire some people, then I'm glad! Because like you said, aeos is different (better mcu, more ios&sensors, and latest unpublished revision is..more generous).
    But, if you're trying to make a "aeos" (same sensors for instance) in future, then i don't get the point..why reinventing the wheel? Your board has qfn/dfn footprints too, so I don't see how it's easier to handsolder.
    If this is related to Ic's price, there are lot of different ways to get them cheaper.
    You should maybe use stencils (maybe you already do it) that will save your day ;)
    Keep the good work
    @NeverDie yep, agree with you
    @scalz said in What did you build today (Pictures) ?:
    @Nca78
    Bigger board won't have those QFN and LGA footprints of course ;)
    As you say I don't want to reinvent the wheel, especially one that'll look square compared to yours :D
    But I think it's important we still have a DIY option available for those who don't like soldering LGA or 0402, an equivalent of using the pro mini for the nrf5 world.
    • sinczeS
      sinczeS
      sincze
      MySensors Evangelist
      This sunday a friend of mine and I did not know what to build. So we decided to use a project designed by @Yveaux
      Source
      I received 2 new CDEByte antennas that needed a range test. As I live in a mansion.... Next to a park we figured out that walking 1 degrees outside would be an excellent time to do a range test. It was not raining so.....
      Our conclusion would be:
      • Cheap ass NRF... good enough for indoor usage.. if it can mesh.
      • Cheap ass Amplified NRF.. good enough in the house, needs a bit more space and power, but works quite well.
      • CDEByte... not cheap.. but man my hands were freezing outside due to the long range.. And according to @Yveaux we could achieve a higher range if we would have set the power to MAX... During testing this was MIN.
      bjacobseB 1 Reply Last reply
      • sinczeS sincze
        Source
        bjacobseB
        bjacobseB
        bjacobse
        @sincze said in What did you build today (Pictures) ?:
        CDEByte
        Thank you for the test :-) Which pointed to me that I urgently need a new serialgateway and use CDEBYTE
        • brendanlB
          brendanlB
          brendanl
          wrote on last edited by brendanl
          #151
          Over the weekend I hacked the previously battery powered Minecraft lights in the Minecraft bedroom (doesn't everyone have one?). Now there's no more replacing batteries and OpenHAB controls include On, Off, Brightness and Flame Flicker.
          This is the reason I was asking about establishing power distribution in the attic. I've decided to distribute 12v and drop to 5 or 3.3 only as needed.
          More info and video: https://techconz.com/smart-home/minecraft-lights/
            #152
            Received the PCB today, so I put together this leak detector for testing:
            Looks as though some of the physical clearance tolerances are a bit tight, so I'll have to do another spin after changing the PCB layout. Some Kapton tape will compensate for now and allow for some initial testing.
              SquareKinematics
              Not MySensors, but related. Power over Ethernet (802.3af compliant) addon for the raspberry pi zero. I plan to use this for high power & high reliability devices where wireless will not work.
              Top one is a higher power version, bottom one just uses an off the shelf regulator.
              Currently these just have some IR LED's to control IR devices.
              • S SquareKinematics
                #154
                @SquareKinematics
                Very useful to have. Not sure if you're aware, but you can buy PoE power adapters off the shelf. Even Amazon sells them. You select the output voltage you want with a slide switch.
                sinczeS 1 Reply Last reply
                  @SquareKinematics
                  sinczeS
                  sinczeS
                  sincze
                  And so it it almost Christmas...
                  Jolly jolly.. wel actually no....
                  We have had wet feet from the central heating system serveral times now around Christmas or New Year.
                  Causing a wet floor and other possible disasters. Yes I know.. A Central Heating Mechanism should not leak, you could try putting a bucket underneath... But that is not 'that home automation' smart that I was looking for.
                  So to detect a leakage.... I came up with this some time ago.
                  Pretty standard, a few wires... a Mysensors Node... and Pushover to send me urgens notifications about the leakge.
                  0_1512750844649_Leakage.jpg link url))
                  And ladies and gentlemen it actually works as you can see in the pushover sreenshot, it kicked off today.
                  • sinczeS sincze
                    @sincze You could also put some salt into your tray for added conductivity when things get wet.
                    sinczeS rmtuckerR 2 Replies Last reply
                      sinczeS
                      sinczeS
                      sincze
                      @neverdie Great tip, this will resolve in even a quicker response during a flood right?. I already added toilet paper as cover for a smooth moist/water distribution. Lets add some salt to that and hopefully never see an error message again. But I wont bet a bitcoin on that ;-).. Happy with this cheap solution.
                        well, since you are not using distilled water, normal tap water should have enough conductivity
                        • sinczeS sincze
                          manutremo
                          @sincze How did you design the detection circuitry? Are you using an analog or a digital input?
                          Tap water should work without adding more conductivity - in my case I just designed something similar but I wanted to detect an overfill of osmosis water, which is similar to distilled. I had issues with getting it to work through a digital input, so I just built a voltage divider capable of detecting the small change in conductivity. I also added a capacitor to be sure that no false alarms would be received because of noise in the lines. It's been working perfect for days now.
                            rmtuckerR
                            rmtuckerR
                            rmtucker
                            @neverdie said in What did you build today (Pictures) ?:
                            Be very careful using salt,i killed an SI7021 doing something similar.
                            I got up one morning and found the sensor covered in white fur and it was dead:white_frowning_face:
                            • andrewA
                              andrewA
                              andrew
                              2 gang EU type livolo customisation, from theory to product... still in progress.
                              2_1512829925723_small_20171112_011444.jpg 1_1512829925723_small_20171101_175752.jpg 0_1512829925722_small_20170114_124152.jpg 2_1512829936757_small_20171119_155004.jpg 1_1512829936757_small_20171118_202738.jpg 0_1512829936757_small_20171112_011725.jpg !
                              • andrewA
                                andrewA
                                andrew
                                0_1512830079874_small_20171119_155404.jpg 0_1512830092134_small_20171119_163354.jpg 0_1512830107562_small_20171119_163849.jpg 0_1512830119867_small_20171119_164745.jpg 0_1512830130032_small_20171119_165717.jpg 0_1512830150237_small_20171203_092353.jpg 0_1512830159490_small_20171203_163658.jpg 0_1512830169403_small_20171207_194213.jpg
                                NeverDieN sundberg84S sinczeS andrewA 4 Replies Last reply
                                • andrewA andrew
                                  @andrew Wow!
                                  • M manutremo
                                    sinczeS
                                    sinczeS
                                    sincze
                                    @manutremo As the water indeed is 'rock' solid here in the area I was pretty succesfull using the digital pins. A short... when there is a water connection or open... when there is no connection. No false alarms. Only legit... Each leakage costs me money to get some guy to fix it for me. But at least the floor is not ruined anymore as I had that the first 2 times.
                                    • rmtuckerR rmtucker
                                      sinczeS
                                      sinczeS
                                      sincze
                                      @rmtucker ai ai . what happened with the salt???
                                      • andrewA andrew
                                        sinczeS
                                        sinczeS
                                        sincze
                                        @andrew Wow indeed.
                                        • sinczeS
                                          sinczeS
                                          sincze
                                          Almost Christmas, that means... Lights. In this case programmable 5v LED's that are driven by an Arduino and controlled via Mysensors & Domoticz.
                                          While the arduino sketch has a lot of tricks (showing animations).. I still have to figure out HOW I can stop an animation from playing when I want to see the next one.. It now completes the first animation.. and then starts the one I selected. It needs to break from the function if a new message comes in. I'll have to look for some examples in the forum.
