  3. Adaptive sleep time
Adaptive sleep time
7 Posts 4 Posters 2.2k Views 4 Watching
    I am looking into a way to proportionally increase the sleep time as the voltage of the battery/supercap decreases. I have tried with map function but I think I messed up and getting weird results. I am looking for suggestions to make something flexible that can be set to a minimum sleep time and a max. At the moment a made something that works in fixed steps but it is not very elegant nor very flexible
      manutremo
      @gohan At first approach, I would say the map function should be the way to go.. what is it that it's working weird?
      gohanG 1 Reply Last reply
      • raptorjrR
        raptorjrR
        raptorjr
        Would it be possible to divide the sleeptime with the voltage? As the voltage is getting lower the sleeptime will be higher?
        Start with a number that after dividing sems good. Then it will automatically increase when voltage decrease.
        • M manutremo
          @manutremo I don't have the code with me, but if you are kind enough could you post a map function that you think could work.
            manutremo
            wrote on last edited by manutremo
            @gohan If I understood correctly what you are trying to achieve, do you think this could work?
            #define VOLT_MAX 3.7
            #define VOLT_MIN 3.0
            #define SLEEP_MAX 100000
            #define SLEEP_MIN 10000
              // put your main code here, to run repeatedly:
            float v,p,s;
            v=3.5;          // Result from volt reading routine
            p=(v-VOLT_MIN)/(VOLT_MAX-VOLT_MIN);
            p=constrain(p, 0, 100);
            s=map(p, 0, 100, SLEEP_MAX, SLEEP_MIN);
            sleep (s, true);             // true for smartsleep, false if otherwise
              Thanks a lot, I'll look at it in the next days. Today I woke up at 5 am and returned home at 8pm... My neurons are not very cooperative at the moment 😅
                @gohan so it's actually you who needs a set sleep time based on energy levels? ;-)
                12.5k
