  3. 💬 Arduino Pro Mini Shield for RFM69(H)W
atmega328patmega328pressureinterstitialhumiditywirelesspcbrfm69hwsensorbme280rfm69temperaturearduinosi7021
53 Posts 13 Posters 18.8k Views 11 Watching
  • pepsonP
    pepsonP
    pepson
    ok but for arduino pro mini 3v i can not connect relay 5v. I use it to control relay...
    Can i use it : https://pl.aliexpress.com/item/8CH-IIC-I2C-Logic-Level-Converter-Bi-Directional-Module-DC-DC-5V-to-3-3V-Setp/32238089139.html?spm=a2g17.search0104.3.299.voV8Dr&ws_ab_test=searchweb0_0,searchweb201602_4_10152_5000015_10151_10065_10344_10068_10342_10343_51102_10340_10341_5130015_10084_10083_10304_10307_10301_10312_10059_10313_10314_10534_5790011_100031_10604_10103_10594_5060015_10142,searchweb201603_32,ppcSwitch_4&algo_expid=1efe59eb-1872-47dd-8d87-8a30137c624f-24&algo_pvid=1efe59eb-1872-47dd-8d87-8a30137c624f&rmStoreLevelAB=5
    • pepsonP pepson
      Ok but why nothing is describe on MySensors on page where show how connect radio ?
      But i have connected and works ok 5V without logic level converter...
      If i not use this logic level converter what will be happen ?
      I can use this https://pl.aliexpress.com/item/8CH-IIC-I2C-Logic-Level-Converter-Bi-Directional-Module-DC-DC-5V-to-3-3V-Setp/32238089139.html?spm=a2g17.search0104.3.299.voV8Dr&ws_ab_test=searchweb0_0,searchweb201602_4_10152_5000015_10151_10065_10344_10068_10342_10343_51102_10340_10341_5130015_10084_10083_10304_10307_10301_10312_10059_10313_10314_10534_5790011_100031_10604_10103_10594_5060015_10142,searchweb201603_32,ppcSwitch_4&algo_expid=1efe59eb-1872-47dd-8d87-8a30137c624f-24&algo_pvid=1efe59eb-1872-47dd-8d87-8a30137c624f&rmStoreLevelAB=5 ?
      zboblamontZ
      zboblamontZ
      zboblamont
      @pepson I suggest you read it again.... The table refers to VCC 3.3v, thereby what is shown NOT a 5v device, the NOTE on that page and which I quoted above spells it out clearly, a converter would be required for 5v.
      If you are supplying it with 5v as well as connecting 5v logic, it is working outside it's specifications, that it is working at all is luck, but magic smoke will appear at some point.
      • pepsonP
        pepsonP
        pepson
        To VCC i put 3.3V (by AMS1117)
        All other pins from Arduino i use directly.
          #33
          @pepson
          let's recap, I'm not sure you got it..
          Says you have a VIN of 5 or 9V, and you connect it to your arduino. On the arduino board you have a ldo. So:
          • 5V Arduino variants will convert the VIN to a 5V VCC supply to you microcontroller (let's call it atmel, or 328p it's shorter). At this moment the atmel is running fully on 5v. If you set an IO to HIGH or =1, it will output 5V! And it's the same for SPI that you connect to your radio module. You thought you could apply a lower voltage to the radio module by applying an external 3V ?? Can't work, because SPI has datain and dataout. Dataout from atmel to radio will be 5v!!
          • 3V arduino variants will convert your VIN (5, 9V etc..) to 3v. The atmel will run on 3v, its pins and peripherals too, so no problem for the dataout above.
          I can't explain better, or maybe you should use a 3v arduino, and add a fet to drive your relay from 5v.
          I would prefer this way (level shifting a basic io, than level shifting the spi bus)
          pepsonP 1 Reply Last reply
          • pepsonP pepson
            zboblamontZ
            zboblamontZ
            zboblamont
            @pepson This reminds of that famous quotation "Any ship can be a Minesweeper..."
            "Once...."
            • pepsonP pepson
              @pepson if you need to run a relay, just get an optoisolated relay board and you can use a 3.3v arduino or raspberry without problems.
              • scalzS scalz
                @pepson
                pepsonP
                pepsonP
                pepson
                @scalz
                What is "fet" ?
                When i use Arduino Pro Mini 3V i can put power 5V to Arduino and he step down to 3V ? Arduino will not destroy ?
                  pepsonP
                  pepsonP
                  pepson
                  wrote on last edited by pepson
                  #37
                  @gohan said in 💬 Arduino Pro Mini Shield for RFM69(H)W:
                  I dont uderstand ?
                  Relay is power by 5V. But if i use Arduino Pro Mini 3V he give to relay 3V and relay probably not working on power 3V...
                  Sorry i am beginner...
                  And i can use this logic level converter
                    wrote on last edited by gohan
                    #38
                    Get one of these and you can use whatever arduino you want
                    https://www.aliexpress.com/item/With-Optocoupler-4-Channel-4-channel-Relay-Modules-Relay-Control-Panel-PLC-Relay-5V-Four-Way/32458001101.html
                    And maybe a new rfm69 module since you probably already killed the one you used.
                      pepsonP
                      pepsonP
                      pepson
                      @gohan
                      Radio works ok.
                      But from where i get 5V for Relay ?
                      gohanG 1 Reply Last reply
                      • pepsonP pepson
                        @gohan
                        Radio works ok.
                        @pepson if you have the 5V power supply, you get it from there
                        • zboblamontZ
                          zboblamontZ
                          zboblamont
                          @pepson If you go to 3v Arduino, the answer seems likely to be a 3v relay, either a package as @gohan suggested or roll your own, no ?
                          FYI, I have a 3v3 node with a RFM69 which has to run a 5v sensor but the number of spare pins is limited, so after many trials and tribulations, am using a 5v Arduino to run and task the sensor with the results being passed back via I2C to the 3.3 device via level converter, all initiated via a single DPDT relay which switches the booster and 5v unit on and off after each cycle..
                          "Radio works ok." is today, tomorrow is another day...
                            muguran
                            According to this connection guide https://www.mysensors.org/build/connect_radio the pro mini D2 will connect to RFN69's DI00.
                            But the shield seems to connect D4 to DI00.
                            Is it OK? Or we need to adapt our sketches?
                            • M muguran
                              #43
                              @muguran said in 💬 Arduino Pro Mini Shield for RFM69(H)W:
                              Actually, no. DIO0 does connect to D2 on this shield, so there should be no issues. :)
                                muguran
                                It seems that I've got another board: it have 4 holes above GND, D2, D3 and D4, and DI00 is connected to the one for D4.
                                Is this an old version?
                                I've ordered at the beginning of this year.
                                • M muguran
                                  @muguran post a picture if you can
                                    muguran
                                    NeverDieN pepsonP 2 Replies Last reply
                                    • M muguran
                                      @muguran
                                      Yes, that's an older version. A fix is discussed in the comments above.
                                      • M muguran
                                        pepsonP
                                        pepsonP
                                        pepson
                                        @muguran
                                        Hi
                                        Where i can buy this pcb to connect RFM69HW with Arduino Mini Pro ?
                                        • pepsonP pepson
                                          @muguran
                                          Hi
                                          @pepson said in 💬 Arduino Pro Mini Shield for RFM69(H)W:
                                          @muguran
                                          Hi
                                          Click "buy" at this link: https://www.openhardware.io/view/268/Arduino-Pro-Mini-Shield-for-RFM69HW
