  3. $8 Lamp (Outlet) "Smart Plug" Module
109 Posts 34 Posters 121.6k Views 13 Watching
  • Z
    Z
    znikos
    Very nice job!
    But don't forget the earth wire on the plug! it's very important for security reason if your lamp (or anythings else) is metallic!!!!
    • petewillP petewill
      Hi All,
      I created a second "Smart Plug" and thought I'd make a how to video this time. I have found them very useful for controlling various devices around the house. It's long but hopefully will be good for everyone including those not too familiar with MySensors. I know when I was first starting out I had little to no experience with any of this stuff and it was hard to piece it all together.
      http://youtu.be/oNpMDN4QqD8
      Here is the parts list (most of this stuff can be obtained from the my sensors store so don't forget to support them!)
      • 1 Gang Outlet Box
      • Outlet
      • Computer power cord or extension cord
      • Old cell phone charger or some other 5v power supply
      • Items from MySensors Store http://www.mysensors.org/store/
      • 22-24 gauge wire or similar (network cord)
      • Female Pin Header Connector Strip
      • Prototype Universal Printed Circuit Board
      • NRF24L01 Radio
      • Arduino Pro Mini
      • Capacitors (10uf and .1uf)
      • 3.3v voltage regulator
      • Female Dupont cables
      Here is a wiring diagram for the 3.3v regulator:
      Here is the code I used. I made a few customizations but the example "Relay Actuator" code can be used as well.
      https://codebender.cc/sketch:72358
      *edited to add wiring diagram
      RJ_MakeR
      RJ_MakeR
      RJ_Make
      @petewill Well Done!! Another Great Help Video!
      RJ_Make
      • petewillP
        petewillP
        petewill
        @znikos Yeah, I did connect it to the outlet but maybe I forgot to mention it? Oops...
        Thanks @ServiceXp!
        • blaceyB
          blaceyB
          blacey
          Sweet! :)
          • N
            N
            NotYetRated
            Very nice video! Thanks!
            • gigiG
              gigiG
              gigi
              Nice project!!!
              Vera lite - mysensors Ethernet gateway - AirWik sensor - Relay Module
              • D
                Dean
                Thanks for sharing your video! I just finished watching it and I feel like I just learned more in that time than I have in months! If you can't tell, I am a bit of a visual learner :-) It was really helpful to be able to watch the whole project come together from beginning to end.
                petewillP 1 Reply Last reply
                • D Dean
                  petewillP
                  petewillP
                  petewill
                  @Dean glad it could help! That is exactly why I made it like that. I know it will be too long for some people but I remember it was difficult for me to piece together all the steps when I was first starting.
                  • FrancoisF
                    FrancoisF
                    Francois
                    @petewill Great video when are you planning in doing the power monitoring for this project?
                      Excellent @petewill.
                      Your video has been added to relay build page and in the news section.
                      Great work!
                      • petewillP
                        petewillP
                        petewill
                        @Francois great question! To be honest, it's on the list but not very high. I have a few other projects I wanted to do and hopefully create videos for.
                        @hek Thanks! You have created something awesome and I am excited to give back just a little when I can. Thanks for all you've done (and continue to do)!!
                        • J
                          J
                          johnr
                          Nice project.
                          I will build some plugs myself, but I would like to exclude the charger, we should be able to power the arduino directly from the ac plug.
                          I am thinking to use something like this
                          https://www.elfa.se/elfa3~tr_en/elfa/init.do?item=69-065-19&toc=19413
                          What do you think about it?
                          tbowmoT 1 Reply Last reply
                          • J johnr
                            Nice project.
                            tbowmoT
                            tbowmoT
                            tbowmo
                            @johnr said:
                            Nice project.
                            That looks like an "charger" just in another package :) in my opinion it's a bit over the top, with a 10W power supply, to a device that uses arround 0,5W (0.1mA @ 5V) in peaks.
                            / Thomas
                            • J
                              J
                              johnr
                              wrote on last edited by johnr
                              Sorry I Think I expressed myself to short and incorrect on my way to work.
                              I really like this Project. My personal problem is that when you have many sensors, sooner or later you run out of old chargers ;)
                              Therefore for the relay (wallplug) it would be nice to find a small ac/dc power supply, which is easy to integrate into the breadboard/pcb.
                              The Meanwell that I linked to i also availible in 5w, but personally I had some problems in the past, with the current consumption of the relays, using sub wall-warts. This is why I am thinking 10w.
                              Mean well have nice quality but pricing is quite high. Would be nice to find an alternative with enough quality that you can trust that it wont burst into flames.
                              Edit: Mybe this tread is the correct one to discuss ac/dc converters. http://forum.mysensors.org/topic/687/230v-power-supply-to-arduino
                              RJ_MakeR 1 Reply Last reply
                              • J johnr
                                RJ_MakeR
                                RJ_MakeR
                                RJ_Make
                                @johnr It doesn't look like that series has any temperature protection??
                                RJ_Make
                                • J
                                  J
                                  johnr
                                  servicexp, no I guess it have only over current protection.
                                  I am going to test a smaller 5w converter. MW irm-05-5 which I was able to get for a ok price through work. It has also smaller physical dimensions.
                                  • J johnr
                                    petewillP
                                    petewillP
                                    petewill
                                    Nice, let us know how it works! I also find I run out of chargers. Thankfully I can get them from work occasionally when people recycle their old phone chargers.
                                      BulldogLowellB
                                      BulldogLowellB
                                      BulldogLowell
                                      @petewill
                                      Or hotel lost and found...
                                      • petewillP
                                        petewillP
                                        petewill
                                        @BulldogLowell yeah, good idea! I wonder if electronics stores may have them too. I know Best Buy has a electronics recycling program. Maybe they get them there too? I just got a fresh supply from work so I should be good for a little while :)
                                        • Mohsin HassanM
                                          Mohsin HassanM
                                          Mohsin Hassan
                                          Hey Hi. Awesome project.
                                          Just a quick though, could i just a Pro mini 5V and skip the whole voltage regulator part? or would that need some additional changes to the project?
                                          Thank :+1:
