1.1k Posts 105 Posters 836.5k Views 98 Watching
  • YveauxY Yveaux
    @sundberg84 analog and esp8266 also beat me. Tried to play some music from an ESP8266 but result was barely usable. I switched to dac+amp connected via i2s which works fine.
    Maybe you could try with a digital i2s microphone...
    sundberg84S
    sundberg84S
    #332
    @yveaux - thanks!!! A new hope ;) I will.
    @nagelc - I use this: https://www.mouser.se/productdetail/789-p3a-220805s but note, there are 4 different variants. WIth and without opening for USB connector and other stuff. I can send you the footprint for the PCB if you wants.
    nagelcN 1 Reply Last reply
    • sundberg84S sundberg84
      nagelcN
      nagelcN
      nagelc
      @sundberg84 Thanks. Looks like that company has several interesting enclosure shapes. Someday I might get a project complete enough that I will want to put it in an enclosure : )
      • dbemowskD
        dbemowskD
        The nice thing about owning a 3D printer is that I don't have to buy enclosures any more. I just have to buy rolls of plastic. The sky is the limit when you have a 3D printer. I do like that enclosure though.
        Nca78N 1 Reply Last reply
        • dbemowskD dbemowsk
          @dbemowsk said in What did you build today (Pictures) ?:
          Can't agree more, made a quick box for the lights with "crystal" PLA. You need a lot of imagination to believe it's crystal, but it's nice for a light enclosure as it acts as diffuser.
          dbemowskD 1 Reply Last reply
          • Nca78N Nca78
            dbemowskD
            dbemowskD
            @nca78 Nice. That would probably look cool in any translucent colored plastic. I have worked with clear, like this, red and green. Haven't used them for lighted enclosures though.
              Today I'm trying out Thingsboard, which sort of is a controller, but on steroids.
              So far, it seems quite capable, but I have a lot of learning to do. My first step was to integrate it with Sigfox, which seems to work.
              McQueen
              Hey @mfalkvidd were you able to get mysensors nodes to send data to thingsboard? If so, I'm interested to know how you did that. Wondering if thingsboard can be configured as a controller for mysensors. Thanks!
              • M McQueen
                @mcqueen I have not tried, and I have no plans to try. Sorry.
                  McQueen
                  @mfalkvidd no problem, thanks
                  • rozpruwaczR
                    rozpruwaczR
                    rozpruwacz
                    So today I created a simple python script to bridge serial gateway with mqtt bus on my RPI:
                    https://github.com/mczerski/MySensorsSerial2MQTT
                    This is because I already use spi for nrf24 module mounted on a custom pcb so there is no room for another spi device.
                    • sundberg84S
                      sundberg84S
                      #341
                      I'm building a wine rack for my wife in a celler room (currently 14 dgr with 4 dgr outside). I mowed my beer cooler temp node (rfm radio) to measure how much the temp changed over the day. I wrote a script in Lua/Domoticz that each time it changes 1dgr it should notify me. Apparently is a stable temp the most important to store wine.
                      All ideas how I can automate the shit out of this wine-room are appreciated.
                      • LCD display with temp/hum (both on the floor and celling) (Red needs apparently cooler than white wine... Or the opposite).
                      • I'm thinking about to try a passive cooler. A burried hose/pipe in a loop with a 12v fan/pump and temp. My idea is that if I rotate the 14dgr air in a say 20m pipe under ground it should cool the air some . This needs to be automated to keep the temp stable.
                      • light. Some sort of led strips.
                      zboblamontZ tbowmoT bjacobseB 3 Replies Last reply
                        zboblamontZ
                        zboblamontZ
                        zboblamont
                        @sundberg84 Yeah, this brings back memories, particularly of quite a few hangovers.
                        I used 3 and four wide fireclay pipes for bottle storage, they were used for ducts back in the day before plastics took over, cable went optic fibre. I noticed recently here they are back in stock in stores as....yep...wine storage racks.... but wacko pricing relatively...
                        The beauty of the fireclay was it's slow temperature and humidity change, and this formed the bulk of the thermal mass in the cellar I made below the floor.
                        I used a 150mm glazed ceramic drainage pipe dug in under the garden as a loop (rope caulked joints - anybody remember them), from memory down about 1.5m, both avoiding frosts and baking sun, don't think the temperature varied over a degree all year round, the ground acting as a massive heatsink which maintained a constant temperature all year round.
                        Only when the hatch was opened did the temperature jump, a small fan kicked in when the hatch was closed and ran for 30 minutes, a second contact switched on the lights and shut them off, long before LEDs were so prevalent, old reliable (until you were depending on them) incandescent bulbs.
                        That was it really.
                        Biggest problem I found was humidity in the early days, probably the fresh construction...
                          My wine rack is at the store. ;)
                            tbowmoT
                            tbowmoT
                            tbowmo
                            @sundberg84
                            Why not just collect the temperatures over time, in f.ex. influxdb, and then use grafana to analyze data? (Instead of pushing messages to your phone whenever the temperature changes..)
                            sundberg84S gohanG 2 Replies Last reply
                            • tbowmoT tbowmo
                              @sundberg84
                              sundberg84S
                              sundberg84S
                              #345
                              @tbowmo well I have Domoticz to collect data. Maybe your alternative is much better but I can't change from Domoticz without redo everything. The push is just to get a heads-up how often or changes but I can go into Domoticz and follow 15 min updates as well on a daily, weekly and monthly graph .
                              tbowmoT 1 Reply Last reply
                              • tbowmoT tbowmo
                                @sundberg84
                                @tbowmo as the temperature doesn't change that quickly, the 5 minutes Domoticz interval it is OK. As soon as you see a daily variance within your requirements, you are good
                                • dbemowskD
                                  dbemowskD
                                  Was I right to assume that the push of temperature changes to the phone every degree was simply for the initial testing to see quickly how often it would change?
                                  • nagelcN
                                    nagelcN
                                    nagelc
                                    I finally got a BT832 (NRF52832 from Fanstel) to talk to my NRF24 gateway. I got the NFR5s a while ago. Made a quick breakout board (quick to design, but slow delivery). In the mean time, I configured a STM32 "Blue Pill" as a Blackmagic Probe to program it. I had to get the latest Sandeep Mistry NRF5 files from github in order for it to support the blackmagic probe, but . . . it worked : ) So far I have just run the MockMySensors and it shows up on Domoticz.
                                      tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @sundberg84
                                      With a little bit of nodered injected in the stream, you could have domoticz running without ever noticing that influx etc is getting the data as well :)
                                      • sundberg84S
                                        sundberg84S
                                        #350
                                        6.3 days or 152hours just inst good enough - this is what my logger managed to do with 2xAA debugging a temp/hum node sending every 15min. Its below 50% to target (14 days) but this included the leds was on all the time... how much can a 2x leds do :neutral_face: ?? Next experiemtn...
                                        • nagelcN
                                          nagelcN
                                          nagelc
                                          @sundberg84
                                          @tbowmo
                                          Domoticz can also push the data to influx DB. See Settings>More Options>Data Push
                                          12.5k
