  2. Announcements
    @anticimex I guess you were right... the gw and node aren't using the AES key. So where am I supposed to add it in the gateway?
    AnticimexA
    AnticimexA
    Anticimex
    @gohan you set that with the configure arguments I suspect, but I can't see it in the documentation. @marceloaqno perhaps knows how the rPi port handles this. I'm on a phone so I can't check the code easily. But you should be able to find it in the transport driver for rPi. On the rPi it can probably be defined in the code as it does not have a personalizer.
    gohanG 1 Reply Last reply
    • AnticimexA Anticimex
      @anticimex It doesn't read it from the mysonfig.h for sure as it is where I always put it
      AnticimexA 1 Reply Last reply
        AnticimexA
        AnticimexA
        Anticimex
        @gohan MyConfig.h does to my knowledge not have a define value for that. You cannot add new definitions to it and expect them to have an effect. If there is one already defined in there, as a comment or not, and it does not have an effect, please report a bug on it.
        • M macvictor
          @marceloaqno Thank's for you help. I have other question.. general I try configure my gateway to work with security & signing, but they doesn't work. Where is problem? On the bottom i send point what it do it:
          Gateway:
          2. make
          3. sudo make install
          10. sudo mysgw --gen-aes-key
          Node:
          #define USE_SOFT_SIGNING
          #define STORE_SOFT_KEY
          #define USER_SOFT_KEY
          #define STORE_SOFT_SERIAL
          #define STORE_AES_KEY
          #define USER_AES_KEY
          EEPROM configuration:
          // Enable NRF24L01 radio type
          // Select soft signing
          #define MY_SIGNING_SOFT
          // Enable node whitelisting
          #define MY_REPEATER_FEATURE
          #define BUTTON_PIN  3   // Arduino Digital I/O pin number for button
          #define CHILD_ID 1      // Id of the sensor child
          #define RELAY_ON 1
          #define RELAY_OFF 0
          Bounce debouncer = Bounce();
          int oldValue = 0;
          bool state;
            // Setup the button
            pinMode(BUTTON_PIN, INPUT);
            // Activate internal pull-up
            debouncer.attach(BUTTON_PIN);
            debouncer.interval(5);
            pinMode(RELAY_PIN, OUTPUT);
            state = loadState(CHILD_ID);
            digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);
          void presentation()  {
            debouncer.update();
            // Get the update value
            int value = debouncer.read();
          //  oldValue = value;
            delay(5000);
            if (message.isAck()) {
              // Change relay state
              state = message.getBool();
              // Store state in eeprom
          4 TSM:INIT
          5 TSF:WUR:MS=0
          11 TSM:INIT:TSP OK
          13 TSF:SID:OK,ID=105
          15 TSM:FPAR
          2065 !TSM:FPAR:NO REPLY
          2067 TSM:FPAR
          4117 !TSM:FPAR:NO REPLY
          4119 TSM:FPAR
          6169 !TSM:FPAR:NO REPLY
          6171 TSM:FPAR
          8221 !TSM:FPAR:FAIL
          8222 TSM:FAIL:CNT=1
          8224 TSM:FAIL:PDT
          and in gateway i see:
          sudo mysgw -d
          mysgw: Starting gateway...
          mysgw: TSF:LRT:OK
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: TSM:INIT:TSP OK
          mysgw: TSM:INIT:GW MODE
          mysgw: MCO:REG:NOT NEEDED
          mysgw: MCO:BGN:STP
          mysgw: MCO:BGN:INIT OK,TSP=1
          mysgw: connected to 127.0.0.1
          mysgw: MQTT connected
          mysgw: !TSF:MSG:PVER,3=2
          mysgw: !TSF:MSG:PVER,1=2
          mysgw: TSF:MSG:REL MSG
          mysgw: !TSF:RTE:240 UNKNOWN
          mysgw: !TSF:MSG:PVER,0=2
          mysgw: !TSF:RTE:233 UNKNOWN
          mysgw: !TSF:RTE:51 UNKNOWN
          Where is problem?
          rajeev2301R
          rajeev2301R
          rajeev2301
          @macvictor
          I followed all the step that you mentioned in your post to establish the serial gateway. However I am still not able to receive the message from arduino. Could you please what to do?
          import RPi.GPIO as GPIO
          from lib_nrf24 import NRF24
          import time
          import spidev
          GPIO.setmode(GPIO.BCM)
          pipes = [[0xE8, 0xE8, 0xF0, 0xF0, 0xE1], [0xF0, 0xF0, 0xF0, 0xF0, 0xE1]]
          radio = NRF24(GPIO, spidev.SpiDev())
          radio.begin(0,8)
          radio.setPayloadSize(32)
          radio.setChannel(0x76)
          radio.setDataRate(NRF24.BR_1MBPS)
          radio.setPALevel (NRF24.PA_MAX)
          radio.setAutoAck(True)
          radio.enableDynamicPayloads()
          radio.enableAckPayload()
          radio.openReadingPipe(1 ,pipes[1])
          radio.printDetails()
          radio.startListening()
          radio.GPIO.cleanup()
          Please find below my raspberry code..can you please suggest , if there is any issue with code or am I missing anything ?
          • rajeev2301R rajeev2301
            @macvictor
            import time
            import spidev
            radio.begin(0,8)
            @rajeev2301 please don't split our effort to help you into multiple threads. It wastes people's time when some information is in one thread and some in another thread.
            • wesW
              wesW
              wes
              To upgrade to the latest release, can I use git pull, or is it better to delete the directory and start again?
              Blog: https://www.wes.id.au/
              Nodes: Arduino Pro Mini ATMega328P 3.3V 8MHz, RFM69 433MHz, Canton Power CE024 0.8-3.3V regulator & single AA battery
              Gateway & Controller: Raspberry Pi 3 + Home Assistant
              • wesW wes
                AnticimexA
                AnticimexA
                Anticimex
                @wes you can pull. Just as long as you verify that your working directory is clean or only contains changes you intend to have. And you have the appropriate branch or tag checked out.
                S 1 Reply Last reply
                • M macvictor
                  Gateway:
                  2. make
                  Node:
                  #define RELAY_ON 1
                  #define RELAY_OFF 0
                  int oldValue = 0;
                  bool state;
                    // Setup the button
                    debouncer.update();
                    delay(5000);
                  4 TSM:INIT
                  5 TSF:WUR:MS=0
                  11 TSM:INIT:TSP OK
                  15 TSM:FPAR
                  2067 TSM:FPAR
                  4119 TSM:FPAR
                  6171 TSM:FPAR
                  8221 !TSM:FPAR:FAIL
                  8222 TSM:FAIL:CNT=1
                  8224 TSM:FAIL:PDT
                  sudo mysgw -d
                  mysgw: TSF:LRT:OK
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: MCO:BGN:STP
                  Where is problem?
                  pepsonP
                  pepsonP
                  pepson
                  @macvictor
                  Hi
                  Is any chance to add security & signing for radio RFM69HW ? Please help me how ?
                  • pepsonP pepson
                    @macvictor
                    Hi
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @pepson signing is radio agnostic. It has nothing to do with the radio.
                      sineverba
                      @anticimex @wes Can I please ask how to update? I mean, the right command to type.
                      I have the folder "MySensors" on documents of my user in Pi:
                      /home/sineverba/MySensors
                      Of course I have all installed and perfectly working now (I'm on the 2.2.0 rc2).
                      I need also to relaunch the ./config command?
                      Thank you to both and all!
                      • S sineverba
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @sineverba https://www.mysensors.org/download
                          Syna
                          Hello, I configure the raspberry gateway to use MQTT. I set mosquitto as the broker. The problem that I encounter is that when I subscribe to test if the gateway publish on the broker, I have empty message. So my first guess is that there is an issue somewhere which cause that only empty message are sent.
                          • Sergio RiusS
                            Sergio RiusS
                            Sergio Rius
                            Regarding the communication issues described in the instructions page with the 2.2 stable version, is that still valid and still recommended to use the development branch?
                                Sergio RiusS
                                Sergio RiusS
                                Sergio Rius
                                @gohan Thank you verys muchos. :+1:
                                • S Syna
                                  marceloaqno
                                  Code Contributor
                                  wrote on last edited by marceloaqno
                                  #797
                                  #define MY_NODE_ID X
                                    sineverba
                                    Hi to all,
                                    1 - Disable the daemon with
                                    sudo rm -r MySensors
                                    4 - Git the "new" MySensors folder && configure it as usual. Remember to activate the daemon and see on Domoticz (for example) the gateway with new version :)
                                    • O
                                      O
                                      otto001
                                      # -*- coding: utf-8 -*-
                                      LOOKFOR = u"mysgw"
                                          if proc.name() == "mysgw":
                                              #print(proc)
                                              #print(cpu)
                                              #print(proc.cpu_times())
                                              if cpu > 50:
                                              else:
                                      Cheers,
                                      Pula
                                      Nick WillisN 1 Reply Last reply
                                      • O otto001
                                        LOOKFOR = u"mysgw"
                                                #print(proc)
                                                #print(cpu)
                                                if cpu > 50:
                                                else:
                                        Cheers,
                                        Pula
                                        Nick WillisN
                                        Nick WillisN
                                        Nick Willis
                                        @otto001 Thanks for that! I'm also getting this annoying service failure on 2.2 on a RPi 2. It seems to happen at random at night when nothing much is going on in the house. It probably happens once every 1 to 2 weeks.
                                        • alowhumA
                                          alowhumA
                                          alowhum
