  2. Announcements
  • AnticimexA Anticimex
    @gohan you set that with the configure arguments I suspect, but I can't see it in the documentation. @marceloaqno perhaps knows how the rPi port handles this. I'm on a phone so I can't check the code easily. But you should be able to find it in the transport driver for rPi. On the rPi it can probably be defined in the code as it does not have a personalizer.
    @anticimex It doesn't read it from the mysonfig.h for sure as it is where I always put it
    AnticimexA 1 Reply Last reply
      AnticimexA
      AnticimexA
      Anticimex
      @gohan MyConfig.h does to my knowledge not have a define value for that. You cannot add new definitions to it and expect them to have an effect. If there is one already defined in there, as a comment or not, and it does not have an effect, please report a bug on it.
      • M macvictor
        @marceloaqno Thank's for you help. I have other question.. general I try configure my gateway to work with security & signing, but they doesn't work. Where is problem? On the bottom i send point what it do it:
        Gateway:
        2. make
        3. sudo make install
        10. sudo mysgw --gen-aes-key
        Node:
        #define USE_SOFT_SIGNING
        #define STORE_SOFT_KEY
        #define USER_SOFT_KEY
        #define STORE_SOFT_SERIAL
        #define STORE_AES_KEY
        #define USER_AES_KEY
        EEPROM configuration:
        // Enable NRF24L01 radio type
        // Select soft signing
        #define MY_SIGNING_SOFT
        // Enable node whitelisting
        #define MY_REPEATER_FEATURE
        #define BUTTON_PIN  3   // Arduino Digital I/O pin number for button
        #define CHILD_ID 1      // Id of the sensor child
        #define RELAY_ON 1
        #define RELAY_OFF 0
        Bounce debouncer = Bounce();
        int oldValue = 0;
        bool state;
          // Setup the button
          pinMode(BUTTON_PIN, INPUT);
          // Activate internal pull-up
          debouncer.attach(BUTTON_PIN);
          debouncer.interval(5);
          pinMode(RELAY_PIN, OUTPUT);
          state = loadState(CHILD_ID);
          digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);
        void presentation()  {
          debouncer.update();
          // Get the update value
          int value = debouncer.read();
        //  oldValue = value;
          delay(5000);
          if (message.isAck()) {
            // Change relay state
            state = message.getBool();
            // Store state in eeprom
        4 TSM:INIT
        5 TSF:WUR:MS=0
        11 TSM:INIT:TSP OK
        13 TSF:SID:OK,ID=105
        15 TSM:FPAR
        2065 !TSM:FPAR:NO REPLY
        2067 TSM:FPAR
        4117 !TSM:FPAR:NO REPLY
        4119 TSM:FPAR
        6169 !TSM:FPAR:NO REPLY
        6171 TSM:FPAR
        8221 !TSM:FPAR:FAIL
        8222 TSM:FAIL:CNT=1
        8224 TSM:FAIL:PDT
        and in gateway i see:
        sudo mysgw -d
        mysgw: Starting gateway...
        mysgw: TSF:LRT:OK
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: TSM:INIT:TSP OK
        mysgw: TSM:INIT:GW MODE
        mysgw: MCO:REG:NOT NEEDED
        mysgw: MCO:BGN:STP
        mysgw: MCO:BGN:INIT OK,TSP=1
        mysgw: connected to 127.0.0.1
        mysgw: MQTT connected
        mysgw: !TSF:MSG:PVER,3=2
        mysgw: !TSF:MSG:PVER,1=2
        mysgw: TSF:MSG:REL MSG
        mysgw: !TSF:RTE:240 UNKNOWN
        mysgw: !TSF:MSG:PVER,0=2
        mysgw: !TSF:RTE:233 UNKNOWN
        mysgw: !TSF:RTE:51 UNKNOWN
        Where is problem?
        rajeev2301R
        rajeev2301R
        rajeev2301
        @macvictor
        I followed all the step that you mentioned in your post to establish the serial gateway. However I am still not able to receive the message from arduino. Could you please what to do?
        import RPi.GPIO as GPIO
        from lib_nrf24 import NRF24
        import time
        import spidev
        GPIO.setmode(GPIO.BCM)
        pipes = [[0xE8, 0xE8, 0xF0, 0xF0, 0xE1], [0xF0, 0xF0, 0xF0, 0xF0, 0xE1]]
        radio = NRF24(GPIO, spidev.SpiDev())
        radio.begin(0,8)
        radio.setPayloadSize(32)
        radio.setChannel(0x76)
        radio.setDataRate(NRF24.BR_1MBPS)
        radio.setPALevel (NRF24.PA_MAX)
        radio.setAutoAck(True)
        radio.enableDynamicPayloads()
        radio.enableAckPayload()
        radio.openReadingPipe(1 ,pipes[1])
        radio.printDetails()
        radio.startListening()
        radio.GPIO.cleanup()
        Please find below my raspberry code..can you please suggest , if there is any issue with code or am I missing anything ?
        • rajeev2301R rajeev2301
          @macvictor
          import time
          import spidev
          radio.begin(0,8)
          @rajeev2301 please don't split our effort to help you into multiple threads. It wastes people's time when some information is in one thread and some in another thread.
          • wesW
            wesW
            wes
            To upgrade to the latest release, can I use git pull, or is it better to delete the directory and start again?
            Blog: https://www.wes.id.au/
            Nodes: Arduino Pro Mini ATMega328P 3.3V 8MHz, RFM69 433MHz, Canton Power CE024 0.8-3.3V regulator & single AA battery
            Gateway & Controller: Raspberry Pi 3 + Home Assistant
            • wesW wes
              AnticimexA
              AnticimexA
              Anticimex
              @wes you can pull. Just as long as you verify that your working directory is clean or only contains changes you intend to have. And you have the appropriate branch or tag checked out.
              S 1 Reply Last reply
              • M macvictor
                Gateway:
                2. make
                Node:
                #define RELAY_ON 1
                #define RELAY_OFF 0
                int oldValue = 0;
                bool state;
                  // Setup the button
                  debouncer.update();
                  delay(5000);
                4 TSM:INIT
                5 TSF:WUR:MS=0
                11 TSM:INIT:TSP OK
                15 TSM:FPAR
                2067 TSM:FPAR
                4119 TSM:FPAR
                6171 TSM:FPAR
                8221 !TSM:FPAR:FAIL
                8222 TSM:FAIL:CNT=1
                8224 TSM:FAIL:PDT
                sudo mysgw -d
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: MCO:BGN:STP
                Where is problem?
                pepsonP
                pepsonP
                pepson
                @macvictor
                Hi
                Is any chance to add security & signing for radio RFM69HW ? Please help me how ?
                • pepsonP pepson
                  @macvictor
                  Hi
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @pepson signing is radio agnostic. It has nothing to do with the radio.
                    sineverba
                    @anticimex @wes Can I please ask how to update? I mean, the right command to type.
                    I have the folder "MySensors" on documents of my user in Pi:
                    /home/sineverba/MySensors
                    Of course I have all installed and perfectly working now (I'm on the 2.2.0 rc2).
                    I need also to relaunch the ./config command?
                    Thank you to both and all!
                    • S sineverba
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @sineverba https://www.mysensors.org/download
                        Syna
                        Hello, I configure the raspberry gateway to use MQTT. I set mosquitto as the broker. The problem that I encounter is that when I subscribe to test if the gateway publish on the broker, I have empty message. So my first guess is that there is an issue somewhere which cause that only empty message are sent.
                        • Sergio RiusS
                          Sergio RiusS
                          Sergio Rius
                          Regarding the communication issues described in the instructions page with the 2.2 stable version, is that still valid and still recommended to use the development branch?
                              Sergio RiusS
                              Sergio RiusS
                              Sergio Rius
                              @gohan Thank you verys muchos. :+1:
                              • S Syna
                                marceloaqno
                                Code Contributor
                                wrote on last edited by marceloaqno
                                #797
                                #define MY_NODE_ID X
                                  sineverba
                                  Hi to all,
                                  1 - Disable the daemon with
                                  sudo rm -r MySensors
                                  4 - Git the "new" MySensors folder && configure it as usual. Remember to activate the daemon and see on Domoticz (for example) the gateway with new version :)
                                  • O
                                    O
                                    otto001
                                    # -*- coding: utf-8 -*-
                                    LOOKFOR = u"mysgw"
                                        if proc.name() == "mysgw":
                                            #print(proc)
                                            #print(cpu)
                                            #print(proc.cpu_times())
                                            if cpu > 50:
                                            else:
                                    Cheers,
                                    Pula
                                    Nick WillisN 1 Reply Last reply
                                    • O otto001
                                      LOOKFOR = u"mysgw"
                                              #print(proc)
                                              #print(cpu)
                                              if cpu > 50:
                                              else:
                                      Cheers,
                                      Pula
                                      Nick WillisN
                                      Nick WillisN
                                      Nick Willis
                                      @otto001 Thanks for that! I'm also getting this annoying service failure on 2.2 on a RPi 2. It seems to happen at random at night when nothing much is going on in the house. It probably happens once every 1 to 2 weeks.
                                      • alowhumA
                                        alowhumA
                                        alowhum
                                        • O
                                          O
                                          otto001
                                          wrote on last edited by otto001
                                          #802
                                          @Nick-Willis:
                                          from
                                          to
                                          sudo systemctl daemon-reload
                                          followed by
                                          to enable the change.
                                          Cheers,
                                          Otto
